Author Topic: What's Bothering You? (The thread about what is bothering you.)  (Read 5076570 times)
0 Members and 8 Guests are viewing this topic.
Re: What's Bothering You? (The thread about what is bothering you.)
« Reply #30501 on: Wed, 17 July 2024, 17:10:32 »
Also,  Indian food is just too greasy.
Oily, is what you're looking for. Not greasy.
Oily =/= Greasy ?
there are a lot of healthy oil options, but no healthy grease options
Offline TomahawkLabs
« Reply #30502 on: Thu, 18 July 2024, 11:10:53 »
I would argue that an oily dish comes from adding "too much" cooking oils during the cooking process and greasy foods are naturally fatty/oily foods that release additional fat/oil when cooked.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
« Reply #30503 on: Thu, 18 July 2024, 13:31:18 »
Tp4 no eat meat no more. But stil can't understand why people continue to eat beef briskets. They're just dry and gross.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #30504 on: Thu, 18 July 2024, 13:36:26 »
Clearly you've only had garbage brisket
« Reply #30505 on: Thu, 18 July 2024, 13:54:26 »
If your brisket is dry whoever cooked it ****ed it up. Brisket is dead ass simple. Put on smoker at 225. When internal temp hits 165 you remove, add moisture (tallow, butter, or water), wrap, place back on until temp is 201-203, rest for several hours to overnight. Brisket is like 30%+ fat.
SA: Camping
« Reply #30506 on: Thu, 18 July 2024, 17:24:45 »
Brisket is inherently tough, so care must be taken when cooking it. 2 critical concepts are "low and slow" and "keep it moist"
There are many ways to do it, but you must not let it dry out.
"Starting in 2011, the deficits again started to shrink. During Obama’s term  the deficit was reduced by $900 Billion  before finally in 2015 the GOP managed to wrangle a “reconciliation” bill out of Obama where he again cut corporate taxes, as well as made permanent some of George W. Bush’s original tax cuts. This is the year everything reversed. Before this, under Clinton, Bush and Obama the deficit in almost every year was gradually decreasing. The balance we had of taxes and the economy was bringing the deficit down, the money coming in was slowly catching up with the money going out until 2015. Trump’s subsequent tax cut has continued the new trend even after the rest of Bush’s cuts have since expired. Obama had an average GDP of 2.3%, with 11.6 million jobs created and unemployment peaking at 10% in 2009, then falling to 4.3% in 2016. If we had continued on that downward deficit track, we would have again reached balance and another surplus in 2017-2018.
– Frank V Walton 2025-07-01
« Reply #30507 on: Thu, 18 July 2024, 19:01:09 »
No matter how well brisket is cooked. The texture is just bad//dryish even doused in sauce.
« Reply #30508 on: Thu, 18 July 2024, 20:34:46 »
Generally brisket is cut 2 different ways, aptly named 'lean' and 'moist'
Moist brisket has a larger fat cap that melts into the meat as you cook. Also many places will oven cook, then smoke it to make it faster, vs low and slow all-day smoking.
    • WTB/WTTF Thread
« Reply #30510 on: Thu, 18 July 2024, 22:27:33 »
Ha
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #30511 on: Fri, 19 July 2024, 10:02:46 »
Nah that's wrong. Brisket was one of the best things I had before I stopped eating meat. Does need to be cooked correctly, otherwise it is pretty bad.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
« Reply #30512 on: Sat, 20 July 2024, 01:28:33 »
Man, exercise is absolutely ****ing awful. Every single time after I workout, forget anything planned for the rest of the day, that day is done. It makes me dizzy, nauseous, gives me a headache, makes me extremely sweaty and uncomfertable, makes my left arm tendons hurt like hell, I'm just pissed off and angry for the entire rest of the day, and can't sleep well any day I exercise intensely.
People say you get an endorphin rush? Absolute horse ****. They say it improves your mood? Literally the opposite. They say it gives you more energy for the rest of the day? Literally ruins the entire rest of my day. Then I just feel like garbage for the next 48hrs and that just gets worse from not being able to sleep.
Exercise is just 100% sheer torture, zero redeeming qualities other than you kinda need to do it to stay healthy and fit. Just terrible.
People who exercise 1st thing in the morning need to be institutionalized.
« Reply #30513 on: Sat, 20 July 2024, 08:19:55 »
I won't attempt to speak to most of your points, but I will respond to these 2.
Nights after exercising I sleep much better than nights that I don't.
Regardless of how I feel immediately after exercise, it improves my spirit to know that I am striving to improve my health. Placebo effect?
edit - "exercise" is a loose term - to me it would include mowing the yard, going on a hike, etc - not just gym or track efforts
« Last Edit: Sat, 20 July 2024, 09:12:06 by fohat.digs »
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #30514 on: Sat, 20 July 2024, 11:29:56 »
I can relate to some of your complaints and think that the answer to your complaints is to modify your workouts until you reach a sweet spot.
First, morning workouts definitely sap my energy for the rest of the day but I’m retired and don’t need to be as productive as in the past. As important as regular exercise is, it may be better to workout after all of your other responsibilities. Later workouts also will help your sleep as long as it’s not too close to bedtime.
Second, you may be pushing yourself too hard. Joint issues are a good sign of either doing too much volume or intensity. Relax. You’re young and don’t need to meet all of your health and fitness goals in three months. Consistency is the key to lasting good health and fitness.
Third, realize that we all progress at different rates. Don’t think that you need to improve at the same rate as the next person. Even a slight improvement is better that doing nothing and regressing. You need to find a way to enjoy exercising or you wil not be able to keep it as a regular part of your life. The gym may not be your thing. Maybe you’ll find your best fit on the track or court, hiking in the hills, moving on the dance floor, or in a pool.
The important thing to remember is that these wonderful bodies of ours are made to move, rest, and be fed. Ignore any of these areas and they will let us know , one way or another.
« Reply #30515 on: Sat, 20 July 2024, 16:06:06 »
 You're right, I shoulda qualified. Specifically aerobic exercise - I'm recently into boxing, which gets you real sweaty and tired real fast. Plus one of the training exercises is jogging, one of my least favorite activities to do ever.
Lifting weights is actually not so bad, you can kinda zone out doing it.
« Reply #30516 on: Sat, 20 July 2024, 17:20:01 »
I used to enjoy jogging until my knees started losing their mojo.
Ideal for zoning out, plus fresh air and sunshine.
    • WTB/WTTF Thread
« Reply #30517 on: Sat, 20 July 2024, 20:21:41 »
If you're nauseous after a workout, you need to hydrate more and probably are salt depleted which isn't helping. It's gonna suck until you adjust and you're not making the adjustment easier
« Reply #30518 on: Sat, 20 July 2024, 20:46:42 »
This is why Tp4 recommends never exercising, ever, for any reason, short of life-threatening fattitude.
« Reply #30519 on: Sat, 20 July 2024, 21:10:37 »
The difference between regular and purified air is very stark. Especially the typical hotel-air, it's so bad.
« Reply #30520 on: Sat, 20 July 2024, 22:12:04 »
I missed my shot asking out the woman I was interested in, she transferred to a different city shortly after I left my last job. Dammit.
Offline Leslieann
« Reply #30521 on: Sun, 21 July 2024, 10:23:57 »
It's not so much purified as the mount of fresh air pumped in.
More fresh air means more power to heat/cool and therefore more money.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #30522 on: Sun, 21 July 2024, 12:54:53 »
However unfresh that air is, it's dusty. Open the shades early morning with the lights off, and you can see how ridiculously hazy it is in the rooms. Every hotel from 2-5 stars.
« Reply #30523 on: Sun, 21 July 2024, 12:55:47 »
The positive interpretation is, you saved all this cash for a new 5090. Loneliness = 5090, a worthwhile trade indeed.
« Reply #30525 on: Thu, 25 July 2024, 17:02:43 »
They is locked down the office supply room. Now Tp4 can't stealz ne more dat Tape.
« Reply #30526 on: Sat, 27 July 2024, 07:13:35 »
Smithfields Chicken and Barbecue.
What can one say, if y'all are in the North Carolina, Try this place, it's a major chain serving square on mediocrity.
Basically, the restaurant is dedicated to the flavor of Sugar.  Literally everything taste like it was dipped in white powder.
Tp4 didn't eat ne of the meat, but the other guys did, one word, sugar, seriously, this place, omg, this is why humanity is doomed, the fact that this place exists, that they have hundreds of seats, means tons of people actually eat here.
« Reply #30527 on: Mon, 29 July 2024, 19:51:00 »
47 job applications for positions I am well qualified for = 47 rejection emails, and no interviews
« Reply #30528 on: Mon, 29 July 2024, 21:46:47 »
Tp4 , 0 job applications,  qualified for nothing,  receives adult babysitting job that involves mostly drinking.
Tp4 would rather go back to Job=0 and dat Arm0red c0r3.
Offline phinix
« Reply #30529 on: Tue, 30 July 2024, 03:37:15 »
Seriously...
Where did they get those clowns?
First I thought I must have switched to some recap of Eurovision...
Bunch of drag queens, a guy with his balls sticking out of his pants and that ginger smerf. WTF people?!
12100 | 9070XT | 2TB SSD | ROG STRIX B760-I ITX | 32GB RAM | SFX 850W | NR200p | Ruark Audio MR1 Mark II | LG OLED 42C4
Realforce 87u55 | CM QuickFire Rapid MX Blacks | Filco TKL 85g Gateron Oil Kings | Tiger Lite 85g Oil Kings | Logitech Pro Superlight
GSA: Retro High-light  HSA: Hyperfuse  XDA: Canvas  PBS: MV Classic
« Reply #30530 on: Tue, 30 July 2024, 07:46:30 »
It's a bit disconcerting.
There is culture and there is "that".
Even though we know there are no hard-rules in the universe on how something aught to look. We do know to some degree that certain body / aesthetic configurations are indicators of sub-optimal/ negative life choices/ consequences.
Because human society is in the mean-time homeostatic, there is large accommodation for non-pragmatic specs,  this is likely to change very soon, prejudice will rise significantly when food becomes scarce again, and tolerance is significantly reduced to align with resource goals.
« Reply #30531 on: Tue, 30 July 2024, 08:04:42 »
There are only so many hours and dollars in a person's lifetime, and I feel sorry for people who spend theirs on/in "events" like this ....
« Reply #30532 on: Tue, 30 July 2024, 15:41:19 »
So Tp4 doing the rice today.  And thought, You know, the countertops are probably not level, The rice might not cook evenly in the rice cooker.
Make sure you guys are leveling the inner "bowl", and not the external fixture.
Yes this is absurd, the autism is getting worse, if that's even a thing.
Offline iri
« Reply #30533 on: Wed, 31 July 2024, 08:42:21 »
Seriously...
what's this?
-Ray Bradbury
« Reply #30534 on: Wed, 31 July 2024, 10:07:55 »
These god damn kuriyans aren't drinking their ramen soup, instead dumping it in the mountain ecosystem on their hikes.
""South Korea’s highest mountain is facing environmental damage from an unexpected source – instant noodles.
The National Park Office of Mount Halla has started a campaign to encourage hikers not to dump ramyun broth on the mountain or in its streams in order to preserve a “clean environment,” according to a press release. "
“Ramen broth contains a lot of salt, so discarding it along the valley’s water stream makes it impossible for aquatic insects to live in contaminated water,”"
« Reply #30535 on: Wed, 31 July 2024, 15:55:07 »
Have you ever been almost animalistically attracted to someone you are not mentally or physically attracted to? Like, you don't find them particularly good looking/not your type, or have anything interesting to talk to or click with personality wise, but your body wants to **** them so bad?
Maybe it happens to 'normal' people more often, but I've never experienced it before.
« Reply #30536 on: Wed, 31 July 2024, 16:08:14 »
You are sick NT,  these thoughts can not be trusted.
For example, women who are on pregnancy medication prefer men they otherwise would NOT have preferred when off the chemicals.
We're living in plastic soup, irradiated air
« Reply #30537 on: Wed, 31 July 2024, 16:48:07 »
See, what's weird is I almost never get those thoughts. I'm bordering a-sex, but once every like 5-6 years or so I'll meet someone who I'm inexplicably attracted to that doesn't meet any of the criteria for my norms.
There is something there, I'd like to get rid of. I'm better off alone anyway.
« Reply #30538 on: Wed, 31 July 2024, 17:18:07 »
This happens to normal people all the time. Modern technology has imperfectly de-coupled sex and reproduction, but the connection is undeniable.
JD Vance is obsessed with the "unwanted children" problem, and for all his horribleness, he understands the need for children to be born into families.
« Reply #30539 on: Thu, 01 August 2024, 17:23:33 »
Tp4 would argue it doesn't happen to normal people,   it's that there aren't many Normal-People left.
The technology has not only decoupled sex and reproduction, more precisely it has isolated Hedonism as the only desired consequence of ALL human endeavor, the problem is far more pervasive and destructive.
Without the mentality / education to regulate desire,  there is indeed only 1 possible outcome in the next 20-30 years.  Annihilation.
« Reply #30540 on: Fri, 02 August 2024, 08:54:54 »
Forgot to cook rice last night. Sigh.. Now Tp4 has no the rice.
« Reply #30541 on: Fri, 02 August 2024, 09:50:48 »
OMG, this stupid rice cooker UI, you have to press Start Twice to initiate cooking.
Tp4 only pressed it once this time,  now must wait another whole hour.
« Reply #30542 on: Fri, 02 August 2024, 16:46:02 »
RX6400 is NOT cheap.
This is the lowest you can go for hdmi 2.1 for movie output. Yet it's $120 on amazon. That's alot just to get a port.
« Reply #30543 on: Fri, 02 August 2024, 19:02:49 »
We have lost electricity here every day this week, and I live inside the city limits of a decent-sized city.
Just now it was an hour, but Tuesday it was 3:30pm to Wednesday 5:00am!
« Reply #30544 on: Fri, 02 August 2024, 19:23:53 »
Move to Las Vegas. They got those cool solar thermal power plants outside the city.
« Reply #30545 on: Fri, 02 August 2024, 20:17:01 »
Got to live near a hospital, or have your own backup generators.
« Reply #30546 on: Sat, 03 August 2024, 13:36:26 »
But Zombie movies clearly predicts that if you live near the hospital, you will be among the first wave to contract the T-Virus.
« Reply #30548 on: Sun, 04 August 2024, 19:31:53 »
Goat epidemic spawns in Greece.  Ovine Rinderpest disease.  80% fatality rate for goats.   All goat travel is banned.
« Reply #30549 on: Sun, 04 August 2024, 19:37:10 »
So low at this point, the past few weeks I've been fasting every other day because I literally do not have enough money for food every day. A college degree, a decade of experience, all the skill and drive in the World, and I have less than $14 to my name. IDK how I'm even going to eat this week.
I just feel so useless, unwanted, and defeated. I did all the things people tell you to as a kid, "Work hard, believe in yourself, learn skills, get a degree" and I have done nothing but fail constantly.
Sorry for the constant pity parade, it makes me sick too. It is so hard to maintain any shred of positivity when it goes on for so long. Just needed someone to hear it, even if it is just some keyboard forum on the Internet. I'll shut up now.
