Author Topic: Stickykeys?  (Read 4635 times)
Offline Pacifist
  • on hiatus
Stickykeys?
« on: Fri, 01 November 2013, 00:28:28 »
So what's your opinion on sticky keys? A godsend? Useful? Hindering? Outright stupid?
Re: Stickykeys?
« Reply #1 on: Fri, 01 November 2013, 00:29:48 »
Are you referring to the Windows accessibility option, or keyboards with sugary liquid spilled on them?
Offline Pacifist
  • on hiatus
Re: Stickykeys?
« Reply #2 on: Fri, 01 November 2013, 00:34:53 »
The windows option. But I should try keyboards with actual sticky keys... :confused:
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
Re: Stickykeys?
« Reply #4 on: Fri, 01 November 2013, 00:48:15 »
never in my life has sticky keys been anything more than an extreme irritation.
"Obviously, windows are central to Windows. But what is a window?"
Offline Matias
  • * Commercial Vendor
    • http://matias.ca
Re: Stickykeys?
« Reply #5 on: Fri, 01 November 2013, 00:52:10 »
Sticky Keys is essential if you're a one-handed typist.  :-)
Re: Stickykeys?
« Reply #6 on: Fri, 01 November 2013, 01:23:19 »
Haven't used it, although I have triggered it accidentally a few times.
I tend to idly tap the same key several times while thinking sometimes, so I would have to say for me it is a minor irritation.  Very minor.
Offline Oobly
Re: Stickykeys?
« Reply #7 on: Fri, 01 November 2013, 03:11:04 »
^^ This. Usually I hit shift 5 times in a row to get it to pop up, then go into settings and turn off all the accessibility stuff. Job done.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Re: Stickykeys?
« Reply #8 on: Fri, 01 November 2013, 09:11:22 »
I don't think I've ever really used StickyKeys before. I guess it would come in handy when typing with one finger though.
Re: Stickykeys?
« Reply #9 on: Fri, 01 November 2013, 09:14:32 »
I accidentally turned it on putting on keycaps once
Re: Stickykeys?
« Reply #10 on: Fri, 01 November 2013, 09:37:39 »
This.  Although the first time it happens on a new computer, I go into accessibility settings and disable it.
Offline Asininity
Re: Stickykeys?
« Reply #11 on: Sat, 02 November 2013, 12:38:32 »
No. I'm not a neanderthal.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Stickykeys?
« Reply #12 on: Sat, 02 November 2013, 14:24:21 »
As a gamer it is ultra annoying if I forget to disable it on fresh install as it always seem to activate at a most inopportune time. I never understood why the **** it's on by default. For those that want to use it they should have to go and enable it on purpose.
Re: Stickykeys?
« Reply #13 on: Sat, 02 November 2013, 14:41:55 »
picture of your only hand...
Re: Stickykeys?
« Reply #14 on: Sat, 02 November 2013, 19:50:03 »
That's the thing - those that need it would probably have difficulty enabling it in the first place.
Offline Tym
Re: Stickykeys?
« Reply #15 on: Sat, 02 November 2013, 19:53:57 »
I know a guy with one hand who swears by it understably.
Offline inteli722
Re: Stickykeys?
« Reply #16 on: Sat, 02 November 2013, 21:36:12 »
He's probably referring to his company's one-handed keyboard. Not ALPs-based, unfortunately, but there.
Waiting for: Phantom Plate
Offline catnipz0098
Re: Stickykeys?
« Reply #17 on: Sun, 03 November 2013, 16:10:06 »
NEVER
Offline SUPER432
Re: Stickykeys?
« Reply #18 on: Wed, 13 November 2013, 01:52:52 »
It's good for some fun:
http://carnal0wnage.attackresearch.com/2012/04/privilege-escalation-via-sticky-keys.html
Otherwise, I've never really used it.
Re: Stickykeys?
« Reply #19 on: Wed, 13 November 2013, 03:16:55 »
I turned off all sticky key.. filter key features... the keyboard seems much more responsive because I'm not waiting so long for key repeat.
Offline baldgye
  • Will Smith Disciple
Re: Stickykeys?
« Reply #20 on: Wed, 13 November 2013, 11:12:00 »
this
