Author Topic: Need advice: what to ask for Christmas  (Read 3939 times)
  • Live long and prosper
« on: Tue, 05 November 2013, 09:08:27 »
So I am trying to decide what I should ask to get for Christmas. The two main things I am debating over:
-Leopold F660C (cuz I wanna try Topre)
-Upgraded processor for my rig (minimum of an i5)
The F660C I want, but the processor I really could use since I only have a dual-core Pentium in my box right now.
Need opinions plz!
tp thread is tp thread
Offline Tym
Re: Need advice: what to ask for Christmas
« Reply #1 on: Tue, 05 November 2013, 09:09:34 »
i5
or a train, everyone likes trains.
Offline MKULTRA
  • telling it how it is
« Reply #2 on: Tue, 05 November 2013, 09:10:51 »
If you have the right socket, get the i5
« Reply #3 on: Tue, 05 November 2013, 09:13:20 »
Yeah my mobo is upgrade-able to an i7, forget what the socket is off the top of my head tho... LGA 1150 is it?
Offline Tym
« Reply #4 on: Tue, 05 November 2013, 09:14:38 »
My i5 is an '55 socket, not 50
Offline vun
  • Just one more thing
« Reply #5 on: Tue, 05 November 2013, 09:15:56 »
Haswell is 50, older i5 is 55 afaik
Offline llovro
« Reply #6 on: Tue, 05 November 2013, 09:16:54 »
buy a new processor since I believe you already have a mechanical  keyboard.
« Reply #7 on: Tue, 05 November 2013, 09:18:10 »
That's what my thought process was as well, but I was still on the fence...
Maybe I'll ask for both! :))
Offline Tym
« Reply #8 on: Tue, 05 November 2013, 09:20:17 »
Sounds right, mine is the old but gold sandybridge.
Offline tufty
« Reply #9 on: Tue, 05 November 2013, 09:22:13 »
Socks and a jumper.
Oh, what you'd /like/.
« Reply #10 on: Tue, 05 November 2013, 09:26:24 »
42642-0
I got this little guy  :thumb:
Offline baldgye
  • Will Smith Disciple
« Reply #11 on: Tue, 05 November 2013, 09:39:45 »
but its not even December!
Offline Oobly
« Reply #12 on: Tue, 05 November 2013, 09:40:01 »
My initial response was:
Ask for an i7! "Nothing succeeds like excess" - Oscar Wilde
BUT the Leopold will last you a lot longer than a CPU and it's more "tactile" (no pun intended, really) and more visible. Nicer for a gift than a CPU which is hidden away inside your PC. Will give you more warm fuzzies feeling the oneness with cup rubber and remembering the generosity and love of the giver.
Well, at least IMHO.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline MTManiac
« Reply #13 on: Tue, 05 November 2013, 09:43:06 »
logic dictates you ask for both, while stipulating the processor over the keyboard if you only get one
« Reply #14 on: Tue, 05 November 2013, 09:43:40 »
Well the pup was ready at the breeders so didn't really have much choice as to when to get it ;)
Offline JPG
  • Model F is my new passion!
« Reply #15 on: Tue, 05 November 2013, 09:47:09 »
Depends on the version of the processor. i5 and i7 means nothing if you don't specify the processor itself. It's just marketing. If you want a good processor for the money, look at benchmarks. My i5 2500K was around 4% slower than a 100$ premium i7 2600K, so I got the i5 and didn't regret it one piece. More so since my cpu is idle most of the time on most of it's cores...
« Reply #16 on: Tue, 05 November 2013, 09:47:53 »
Well said! :thumb:
I might ask for both considering I get like three Christmases every year (one with family, one at my mom's, and one at my dad's)
« Reply #17 on: Tue, 05 November 2013, 09:48:10 »
I7 :)
I want to try a Leopold too !
« Reply #18 on: Tue, 05 November 2013, 09:48:57 »
Yeah was thinking of asking for a i5 2500k, I have heard nothing but good things about those chips...
Offline iri
« Reply #19 on: Tue, 05 November 2013, 10:35:13 »
i7. and buy my realforce.
-Ray Bradbury
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #20 on: Tue, 05 November 2013, 10:57:15 »
If you need to know exactly what socket you mobo is download CPU-Z from www.cpuid.com
Offline JPG
« Reply #21 on: Tue, 05 November 2013, 11:01:42 »
My i5 2500K is amazing, but already 2 years old. I suggest going to Tom's hardware and look fore the monthly "best cpu for X$" and you will probably find the best one for your $ at the moment. 2500K is outdated for sure, but there's probably an equivalent right now. Still, if you motherboard does not support new ones, then I don't know that is best! I usually change all my stuff at once so that everything is balanced and keep it for like 4 years
« Reply #22 on: Tue, 05 November 2013, 11:43:20 »
you wouldn't get a 2500k "at this point"  unless for $100-120.....  which will be rare... and the board will still prob run $120-150
So you're better off with a 4770...
Offline MKULTRA
« Reply #23 on: Tue, 05 November 2013, 11:43:56 »
2500k doesn't even fit in 1150 lol
