Author Topic: Battlefield causes ping spike....  (Read 1812 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Thu, 07 November 2013, 21:05:11 »
Hi guys I was playing Battlefield 4 thinking that the ping spike problem I got in Battlefield 4 would go away.... Well it didn't. My whole network will slow down to a stutter and then reach 500ping... Any ideas?
Offline jinxedx84
Re: Battlefield causes ping spike....
« Reply #1 on: Thu, 07 November 2013, 21:08:26 »
only when your playing BF4?
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
« Reply #2 on: Thu, 07 November 2013, 21:09:33 »
hmmm...............
errrr....
disable precision timer on mobo, lowers dpc latency
use timer-resolution to force .5ms for lower dpc latency
« Reply #3 on: Thu, 07 November 2013, 21:10:01 »
also if you got an intel nic... check for updated drivers.. and DO NOT install their management software.
Also disable some of the features of the NIC that you're not using.. the often cause problems for routers.
Offline C5Allroad
« Reply #4 on: Thu, 07 November 2013, 21:23:16 »
I don't know what any of that is. But let me to look it up lol.
