Author Topic: Quick question about LED lifetime and my Ducky Shine 3  (Read 4841 times)
Offline Dimentio
« on: Wed, 20 November 2013, 06:13:07 »
Hey guys,
I recently purchased a Ducky Shine 3 (blue LEDs) with brown switches and it's super awesome, so awesome that I'm worried about how long some of its awesomeness will last.
I love how bright the LEDs are on the board, but I'm concerned that they'll fade over time. Is it enough of a concern to actually bother turning the LEDs off when I'm not using them? Or will they remain equally bright over a long period of time, even if I leave them constantly on at 100% power?
Dim
Offline BakaPhoenix
Re: Quick question about LED lifetime and my Ducky Shine 3
« Reply #1 on: Wed, 20 November 2013, 06:57:26 »
LED have a quite long lifespan.
Probably not as much as a switch, but long enought to buy another keyboard because the shine is too old XD
(but remember that sometime they can die prematurely)
Offline BlueBär
« Reply #2 on: Wed, 20 November 2013, 07:01:25 »
LEDs do fade over time, but that really takes long, LEDs generally have a long lifetime. You probably wouldn't even notice it since it's a gradual process. And even if you would start noticing it you could always replace them, it's not too hard.
Offline laffindude
« Reply #3 on: Wed, 20 November 2013, 07:09:05 »
lifespan is rated to 50% brightness of original. If you use it, it is constantly getting dimmer. So turn it off. Blue light is not good for your eyes anyways.
« Reply #4 on: Wed, 20 November 2013, 07:09:30 »
This will not be a problem..
They will last longer than it takes for you to become bored with them, and turn them off indefinitely...
Bright-blue lights is a youngster's fascination..
It is the Adult-path to exist in darkness except for which is necessary to survive..
« Reply #5 on: Wed, 20 November 2013, 17:11:40 »
Welcome to Geekhack!
I have two Ducky Shine version 1 bought more than a year ago.  One has had almost constant use at work, and is still as shiny as it was the day I got it.
The other one sees much less use at home (been supplanted by Model M and HHKB), but it still as shiny as.
Offline Candyflip
« Reply #6 on: Thu, 21 November 2013, 06:40:31 »
On this forum sometimes you don't know if shine is a good or a bad thing  :p
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Thu, 21 November 2013, 07:00:14 »
Changing the leds will not be that difficult if it really does happen
« Reply #8 on: Thu, 21 November 2013, 07:11:01 »
problem is color matching.. so you'd have to change ALL of them...
Offline terran5992
« Reply #9 on: Thu, 21 November 2013, 07:36:18 »
LOL , How many shades of white are there?
Offline laffindude
« Reply #10 on: Thu, 21 November 2013, 07:44:57 »
Too many. White LEDs aren't white, they are blue with yellow phosphor. Different wavelength of blue and different amount of phosphor will change the color temperature.
Offline terran5992
« Reply #11 on: Thu, 21 November 2013, 07:50:32 »
Woahh i had no idea
« Reply #12 on: Thu, 21 November 2013, 20:53:36 »
A shame the manufacturers don't throw half a dozen spare LEDs in the box with the keyboard.
