Author Topic: LED desk back lighting  (Read 11102 times)
Offline jinxedx84
« on: Sun, 24 November 2013, 01:39:23 »
So this evening i got dragged along to Home Depot (wife wanted at fake christmas tree) anyways. So i was off, not lookin at trees and came accross some RGB(W) peel and stick LED lighting. I have seen other people use light to accentuate the battlestations. So I figured i would post at picture and see if anyone else did anything similar to the BS.
http://www.homedepot.ca/product/118-inches-3m-rgb-led-flextape-with-plug-in-dirver-remote-and-controller/844236
I know i probably payed to much but oh well
Dont mind my wires im just lazy
45669-0
Remote, and this produces all the colours on the remote
45671-1
-filco TLK MX Blue & IMSTO thick blank blue keycaps
- White Poker II MX Blue
Offline Pacifist
  • on hiatus
Re: LED desk back lighting
« Reply #1 on: Sun, 24 November 2013, 01:40:29 »
Snazzy
How much in USD is it?
Offline jinxedx84
« Reply #2 on: Sun, 24 November 2013, 01:41:06 »
i imagine homedepot in the states has it
« Last Edit: Sun, 24 November 2013, 01:56:03 by jinxedx84 »
Offline Photoelectric
« Reply #3 on: Sun, 24 November 2013, 01:41:30 »
I like your desk arrangement, though that heavy computer case up on a shelf scares me a bit ;)
Offline jinxedx84
Offline jinxedx84
« Reply #5 on: Sun, 24 November 2013, 01:42:51 »
I assure, the shelf was not easy to come by, and is lag bolted to the wall, and Isnt going anywhere. I appreciate your concern tho  :thumb:
« Last Edit: Sun, 24 November 2013, 01:56:28 by jinxedx84 »
« Reply #7 on: Sun, 24 November 2013, 01:43:37 »
I'd also recommend IKEA Dioder--half the price for 4 LED strips.  I have 3 of those in various locations.
Offline jinxedx84
« Reply #8 on: Sun, 24 November 2013, 01:45:41 »
totally, but i needed 120 inches, and those 4 would totally make more of a mess, wiring wise
« Last Edit: Sun, 24 November 2013, 01:57:09 by jinxedx84 »
Online tp4tissue
« Reply #9 on: Sun, 24 November 2013, 01:59:48 »
You can buy LED Christmas lights after christmas. for WAY cheaper...
Offline jinxedx84
« Reply #10 on: Sun, 24 November 2013, 02:01:49 »
actually, i have LED blue christmas lights, and they didnt give the effect i wanted, they were "spotty" and not as bright
Online tp4tissue
« Reply #11 on: Sun, 24 November 2013, 02:09:11 »
well there's more work involved in lining them up of course.... brightness.. mmm.. u just need M0re...
Offline jinxedx84
« Reply #12 on: Sun, 24 November 2013, 02:14:12 »
You under estimate the severity of my laziness  :p
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #13 on: Sun, 24 November 2013, 03:00:01 »
I use the same ones...
But consider to replace the trasformer unit (super cheap POS), one (out of my 3) melted O.o
A Ghost From The Past
Offline jinxedx84
« Reply #14 on: Sun, 24 November 2013, 03:04:42 »
What did you replace it with??
  • ~ BOOO ~
« Reply #15 on: Sun, 24 November 2013, 03:13:12 »
Good quality one with same specs...
I'm from Europe tho (230V @ 50Hz)
Offline zoolzoo
« Reply #16 on: Sun, 24 November 2013, 07:51:36 »
blue hurts your eyes d00d.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline Capitalistix
  • Cherry MX Green Disciple
    • Uncanny Electronics
« Reply #17 on: Tue, 26 November 2013, 01:16:40 »
You put your PC on a damn shelf! Thats brilliant! How come I didnt think of that? Ive been looking for a way to get my damn tower off my desk/floor.
