Author Topic: Are spherical key caps more comfortable for fingers with nails?  (Read 3665 times)
Offline spremino
« on: Mon, 16 December 2013, 10:47:36 »
I type with my fingers curled and even at their shortest, some of my nails always touch the keys together with finger pads. I would prefer to type with my finger pads only, without changing technique.
I wonder whether, by virtue of their smaller surface compared to cylindrical ones, spherical key caps would help.
Any experiences? Thanks.
A long space bar... what a waste of space!
Offline Linkbane
Re: Are spherical key caps more comfortable for fingers with nails?
« Reply #1 on: Mon, 16 December 2013, 10:57:48 »
If you type with only your finger pads and your fingers stretched out, even when I get lazy and have long nails, they never touch the keycaps. The only reason why what you mention would happen is if you have nails several inches long or you type with curled fingers. Typing with curled fingers, while more traditional, is apparently quite a lot worse on the fingers, so you wouldn't want to do it anyways.
Spherical caps aren't supposed to be more comfortable, just better looking (not even, in my opinion). They're not sculptured, so they won't feel good on the fingers like cylindrical.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline yasuo
  • spanengan puyeng newbie
« Reply #2 on: Mon, 16 December 2013, 11:08:58 »
How to DSS keycap?
Logitech MK220 Colemak DH
Offline spremino
« Reply #4 on: Mon, 16 December 2013, 18:32:23 »
http://geekhack.org/index.php?topic=41079.0
Thank you, but I don't wear acrylic nails yet :D
Well, I think that I will adjust my technique a bit. Maybe I will tilt the keyboard as well, to have a better angle.
Where did you learn that typing with your fingers curled could be a lot worse? This is interesting.
« Reply #5 on: Mon, 16 December 2013, 18:46:43 »
watch the sean wrona video..
How he types.. That's how you should type... with the exception of wrist placement.
Offline Linkbane
« Reply #6 on: Mon, 16 December 2013, 21:35:34 »
I remember from a thread which I read within the week. Typing with curled fingers is just typewriter technique and allows for force to be applied more easily, but given that such a large amount of force is not required, it's better for the fingers to be relaxed and stretched out.
Offline spremino
« Reply #7 on: Tue, 17 December 2013, 04:15:53 »
I can see that. The reason I type with curled fingers is that I use buckling springs and -- as you say -- curled fingers help you apply force more easily. But I have watched typing lessons for typewriters again and it seems that I was curling my fingers more than what is required by traditional technique. Definitively something to fix.
Offline Linkbane
« Reply #8 on: Tue, 17 December 2013, 12:59:32 »
Best of luck in practicing. I remember it was difficult to type with stretched fingers on Greens, which are apparently very similar in force to buckling springs, but getting used to it made my typing on Blues much faster.
