Author Topic: Keyboard works on Linux, Windows and Mac but does not work in the bios or GRUB  (Read 5385 times)
Offline lcs
  • Lover of Grape Drank
  • はやく
Anyone ever seen this?
Offline lcs
  • はやく
Is there a fix, tp?
Is there a fix, tp?
Usually no..
Try the usb legacy settings in the bios..
but in most cases, the reason certain boards don't work is because they pull too much power, or they take too long to startup, so the bios rejects/(does not detect) it.
if it's startup, you can increase the bios startup time, that may work, but who would keep changing this setting on and off just to use their bios..
Offline lcs
  • はやく
I tried the legacy thing to no avail.
Yeah, maybe you're right, because another usb board works :(
Damn, what a bummer.
Offline Soarer
Which keyboard doesn't work?
Hmm my HHKB works fine in GRUB
Offline terran5992
  • One With The Cup Rubber
One question. What is GRUB?
Offline Soarer
GNU GRand Unified Bootloader.
Offline lcs
  • はやく
A GON. It has an Aikon controller.
GRUB is the linux bootloader. You use it to select the OS you want to boot into. There is a windows counterpart that I forgot the name.
Offline Soarer
Hmm, IIRC it presents as a standard 6KRO keyboard with no frills, so it should be pretty compatible. OTOH, I think it uses software USB... can't think why that would upset the BIOS/bootloader if it works elsewhere though.
Offline lcs
  • はやく
Yes, the NKRO option is disabled as well :(
Offline 127001
GRUB is much later than the BIOS/UEFI.
Also UEFI != BIOS
Offline hasu
  • @tmk
Aikon uses V-USB, right? I think it can not conform to the spect completely due to software and hardware limitation. V-USB is great enough in most case, though.
Aikon also supports PS/2? Aikon is not  ps2avr? Korean things is confusing to me.
Offline tuxsavvy
  • 白HHKBの魔法使い
I suppose this is on a machine with no PS/2 ports as well?
Some older machines may not recognise USB keyboards on boot and if they have PS/2 ports, that is a possible avenue for one to try. However if it does not have PS/2 ports as well then I guess I am pretty stumped.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline lcs
  • はやく
It does have a PS2 port, but a ****ty USB board works just fine :(
« Last Edit: Tue, 17 December 2013, 23:46:44 by lcs »
Offline 127001
Is it UEFI or BIOS? How old is it? Is the USB in the main board or an add in card? Have you tried all USB ports? USB 3.0?
Offline osi
Can you access BIOS on other machines with the GON?
Offline TheSoulhunter
  • ~ BOOO ~
My HHKB (and my Poker as well iirc) doesn't work in BIOS, but my Filco does...
A Ghost From The Past
Offline lcs
  • はやく
BIOS, the pc is about a year old, main board, yes, 2.
Offline Wildcard
  • When caffeine isn't enough
What does GNU stand for
/jk
Offline lcs
  • はやく
/jk
What does it stand for? What doesn't it stand for?
It stands for ... it stands for commitment. It stands for audacity. It stands for courage in the face of ...
What do you think it stands for?
Oh, sorry, that was IT.
Offline mr2009
maybe try to delay the post screen in bios? mostly once the post screen ended then only the keyboard start to functioning. this happen to me with my quickfire tk. 1 delay the post screen to 10sec so that my keyboard can bootup before the post screen dissappear and press DEL to enter the bios...
Offline tuxsavvy
  • 白HHKBの魔法使い
I don't think that is actually doable. Most bootup processes are usually fairly quick and even if one tries to slow down the bootup sequence it is not likely that it will enable USB keyboard in the time in between. Think of it as following a receipe book for making things, you can't have other things happening that easily when you don't have the base done.
Offline lcs
  • はやく
GON said to me that the Aikon controller does not work on the BIOS indeed.
Thank you guys for the help.
