Author Topic: Logitech G710+ Orings?  (Read 10840 times)
Offline Abn
« on: Mon, 30 December 2013, 02:36:09 »
So I love the o-rings on the g710+ but don't know what thickness they are. Does anyone know, and where I can get them?
Thanks.
« Last Edit: Mon, 30 December 2013, 02:51:15 by Abn »
Noppoo Choc Mini Reds | Ducky Shine 3 TKL Browns | Topre Realforce 87U 45gram
Offline terran5992
  • One With The Cup Rubber
Re: Logitech G710+ Orings?
« Reply #1 on: Mon, 30 December 2013, 02:38:48 »
Offline Abn
« Reply #2 on: Mon, 30 December 2013, 02:43:08 »
Ya they have 2, I would want the ones on the G710+ if i knew what thickness they were. I have heard they are 0.1mm but can't confirm.
« Reply #3 on: Mon, 30 December 2013, 04:05:23 »
LOLOL... 0.1mm
Offline Fullcream
« Reply #4 on: Mon, 30 December 2013, 06:39:38 »
Metric Ruler
Offline daerid
    • Rossipedia
« Reply #5 on: Mon, 30 December 2013, 10:40:47 »
Dude... 0.1mm is really thin. Pretty sure those are a bit thicker.
Offline Abn
« Reply #6 on: Mon, 30 December 2013, 12:34:35 »
LOLOL... 0.1mm
Idk why you are laughing...
Iruler.net with an oring right there... its 0.1mm lol
Offline piglickjf
« Reply #7 on: Mon, 30 December 2013, 12:43:01 »
That looks like 1mm to me, not 0.1 (and that's assuming it's to scale, since it seems to be on a monitor and not an actual ruler).
« Last Edit: Mon, 30 December 2013, 12:45:46 by piglickjf »
« Reply #8 on: Mon, 30 December 2013, 12:44:18 »
LOLOL... 0.1mm
Offline Photoelectric
« Reply #9 on: Mon, 30 December 2013, 12:52:41 »
That's just over 0.1cm not 0.1mm.  Look at the units on the ruler.  Looks ~0.15cm or ~1.5mm.
You can use black McMaster-Carr o-rings sold at Amazon:
http://www.amazon.com/dp/B0051XWXCE/ref=biss_dp_t_asn
(that picture is generic, here's an actual picture I took:)
They are a pretty good balance at soft bottoming out and not a dramatic amount of travel reduction.  Some people like even harder varieties like 70A.
« Reply #10 on: Mon, 30 December 2013, 13:02:54 »
photoelectric to the rescue...
Abn, I didn't mean to be malicious or anything... it's quite the Internet-Kodak-moment for you to confuse mm with cm...
I've confused for myself, Khz and hz  and  numerous other units... like nano with micro,
