Author Topic: Happy hacking professional 2 Vol_dn and vol_up, mute, eject doesn't work yet  (Read 5988 times)
Offline slenderman1
So I just received this new topre keyboard in the mail and right out of the box, those keys do not work. I have switches 1 and 3 on and I cannot use the volume control by fn+a or fn+s for vol_dn and vol_up. Anyone know how?
Offline AKIMbO
  • HHKBro
Those only work on mac computers.
| KBD75 (box reds)
Offline slenderman1
are you absolutely sure? That's strange
And then only if you install the driver.
Offline slenderman1
Is there a way to remap those keys to work on windows?
Offline slenderman1
tried it on windows, did not work
Offline tuxsavvy
  • 白HHKBの魔法使い
They send out a different keycode, which I guess can be mapped within windows environments. For that you will need something like autohotkey for windows in the very least.
I sort of documented on my other forum post (albeit on linux): http://geekhack.org/index.php?topic=52123.msg1152290#msg1152290
Which reminds me. I need to go update that little config of mine.. finally figured out some more things.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Have you tried aquakey to see what, if any, scan code the keys return?
Also remember to unplug HHKB, change dip switch, then plug back in.
Offline slenderman1
yeah I looking at aquakey not sure how to interpret the results I'm seeing here. I also did unplug and replug after chaning the dip switch as well.
Offline tuxsavvy
  • 白HHKBの魔法使い
Ideally you should unplug (or disable keyboard if you can from computer side), change the DIP switches as needed then plug the keyboard back in (obviously re-enable the keyboard if you disabled it before). Not changing DIP switches whilst the keyboard is still plugged in. I am not sure if the keyboard will still send out same results on Aquakey as when the keyboard is set to windows mode via DIP switch.
Anyway, check both ways and make sure to unplug the keyboard _before_ you change DIP switches.
get a griffin powermate!
Offline hasu
  • @tmk
It looks like Windows doesn't recognize those keys. I didn't see any key codes on both AHK and Aquakeytest. To use those keys on Windows you will need some hack.
Autohotkey funtime
You can place the volume control some where more comfortable
Offline Rooneye
My HHKB volume/eject functions worked straight out of the box when in Mac mode. On my Mac that is.
Documentation suggests that you need to install drivers on the Mac.
Which version of Mac OS are you using?
Maybe Apple included some drivers or something in the OS.
Offline esoomenona
  • Gnillort?
I've done some Googling in this regard, and I've run across something that seems interesting, but I'm not sure if it may work like I would hope.
Apparently, if you dual boot Windows on a Mac and wish to run Boot Camp on Windows, there are drivers that do something. I'm just not entirely sure what, and I haven't tried to find and install them yet.
