Author Topic: Topre Type Heaven Mini-Review  (Read 11088 times)
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« on: Tue, 14 January 2014, 20:04:18 »
Offline epzy
  • HHKB Fiend
  • ded
Re: Topre Type Heaven Mini-Review
« Reply #1 on: Tue, 14 January 2014, 20:07:17 »
Great review!!!1
Offline HPE1000
  • Keycap Paparazzo
« Reply #2 on: Tue, 14 January 2014, 20:12:22 »
Reminds me of my model m
« Reply #3 on: Tue, 14 January 2014, 20:14:56 »
Why that one spot?
Offline kmiller8
« Reply #4 on: Tue, 14 January 2014, 20:15:48 »
Offline kmiller8
« Reply #5 on: Tue, 14 January 2014, 20:26:41 »
D F G H J K L :
Offline 127001
« Reply #6 on: Tue, 14 January 2014, 20:30:12 »
Are they all crooked or is it just me...
« Reply #7 on: Tue, 14 January 2014, 20:30:56 »
hahahahahahahahahahahhahahaaaaaaaaaahahahahahahahahahah
Offline kmiller8
« Reply #8 on: Tue, 14 January 2014, 20:31:02 »
Some of them are noticeably more crooked than the rest.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #9 on: Tue, 14 January 2014, 20:31:39 »
That sounds is horrid.
Also looks like the G and K are crooked
Offline kmiller8
« Reply #10 on: Tue, 14 January 2014, 20:32:04 »
Hence the italic letters.
« Reply #11 on: Tue, 14 January 2014, 20:32:24 »
Should be in the reviews section?
Offline kmiller8
« Reply #12 on: Tue, 14 January 2014, 20:33:07 »
I plan on just criticizing it, not actually writing anything close to a proper review.
« Reply #13 on: Tue, 14 January 2014, 20:37:07 »
crooked caps is a known issue with topre. sadly. some are worse than others.
Offline eddie
« Reply #14 on: Tue, 14 January 2014, 20:50:01 »
Wow, This is a great review. Thank you for this.
« Reply #15 on: Tue, 14 January 2014, 20:51:32 »
yup, when you make large round plastic cylinders, ur bound to get some twisting..
Not something that can't be overcome, but there's the cost issue..
Offline BlueBär
« Reply #16 on: Tue, 14 January 2014, 20:52:53 »
Finally clicky Topre!
« Reply #17 on: Tue, 14 January 2014, 20:53:02 »
But this seems like an easy fix if you have to fix it.. just put a little sliver of foam in there.. it should fill in most of the gap..
« Reply #18 on: Tue, 14 January 2014, 21:20:31 »
Or superglue?
« Reply #19 on: Tue, 14 January 2014, 21:22:09 »
Shouldn't this be in the review subforum?
« Reply #20 on: Tue, 14 January 2014, 21:29:41 »
What I said up there, and what kmiller has already refuted :p
Offline kmiller8
« Reply #21 on: Tue, 14 January 2014, 21:29:58 »
« Reply #22 on: Tue, 14 January 2014, 21:31:01 »
Stopped reading at the title, since its a review but not in reviews so therefore it must be advertising.
« Reply #23 on: Tue, 14 January 2014, 21:32:56 »
On a different subject, kmiller 2 posts to reach 2000!
Offline kmiller8
« Reply #24 on: Tue, 14 January 2014, 21:34:40 »
I already have 2500, that number under my name is a lie.
« Reply #25 on: Tue, 14 January 2014, 21:53:00 »
It's the number of posts that "count".
Offline terran5992
  • One With The Cup Rubber
« Reply #26 on: Wed, 15 January 2014, 03:31:49 »
Now burn it
« Reply #27 on: Wed, 15 January 2014, 03:36:27 »
Now burn it
Only after you pour acetone over it!
Offline fuzzybaffy
« Reply #28 on: Wed, 15 January 2014, 04:46:19 »
D F G H J K L :
It probably looks worse in the picture, than it does in RL. Of course, this is just a guess, and I can't really speak for the photograph, given this is someone else's photo. =P
But do note the bottom line of the keyboard isn't completely straight, so I'm thinking there is some (lens) distortion in the photo, that makes it look worse than it really is. Unless the bottom line of the keyboard really IS indeed crooked like that. D=
« Last Edit: Wed, 15 January 2014, 04:48:10 by fuzzybaffy »
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #29 on: Wed, 15 January 2014, 06:32:37 »
Any photos taken on the underside of the keyboard?  ;D
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline Hyde
  • White Tofu Extraordinaire
« Reply #30 on: Wed, 15 January 2014, 08:16:14 »
lol ok I'm at work typing on my Type Heaven now.  I don't notice any crooked letters on mine, however if I do tap the bottom edge it does make a sound.
But I've owned this keyboard since August 2013 and still didn't notice this until now, so I don't think it's too bad.  Also all other edges are nicely reinforced I think they just slack off when making connection tabs at the bottom.
:P
Offline fuzzybaffy
« Reply #31 on: Wed, 15 January 2014, 12:16:24 »
:P
The slack is true of all RF87 boards, too, I believe. The top and bottom of my RF87u slides a bit back and forth. That doesn't mean EVERYTHING about the build quality is ****e, though.
Offline Linkbane
« Reply #32 on: Wed, 15 January 2014, 13:11:38 »
:P
I mean, if my MX board shifted that would automatically qualify it as very ****ty.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline Hyde
« Reply #33 on: Wed, 15 January 2014, 14:09:15 »
:P
lol to be fair, aside from the tapping sound (which under normal operation will never happen) I find Type Heaven very solid built.  Like if you tap anywhere else it's rock solid.
Just don't tap under the arrow cluster lol.
Offline kmiller8
« Reply #34 on: Wed, 15 January 2014, 14:39:06 »
HYDE, LOOK AT MY WORK KEYBOARD, DO YOU SEE WHY I WAS RANDOMLY TAPPING THAT EXACT POINT, THAT IS WHERE MY SPACEBAR THUMB HITS THE CASE ON A REGULAR BASIS.
LOOK HOW WORN IT IS HYDE.
« Reply #35 on: Wed, 15 January 2014, 15:35:01 »
That's a bit of an odd habit you have there, kmiller :p
« Reply #36 on: Wed, 15 January 2014, 15:38:42 »
My car shifts. Is it a piece of ****? :(
« Reply #37 on: Wed, 15 January 2014, 15:43:13 »
Do you touch it? Or does it do it all by itself?
Offline fuzzybaffy
« Reply #38 on: Wed, 15 January 2014, 16:57:02 »
:P
I doubt it. If so, you'd have to ignore all the other positive aspects of the keyboard build, which would make no sense. You're just saying that to talk trash.
« Last Edit: Wed, 15 January 2014, 17:08:24 by fuzzybaffy »
Offline Linkbane
« Reply #39 on: Wed, 15 January 2014, 17:57:44 »
:P
You're just saying that to lash out over the internet without any proof.
I'm being truthful. If my MX board had a looseness inside which caused shifting, it would be terrible build quality and would probably break. It doesn't matter how great a board is if it breaks out of the box, which is probably why we put mechanicals above rubber domes, or properly built ones, anyways. Unless you suggest the opposite?
Offline neunelfer
  • HHKB Pro
« Reply #40 on: Wed, 15 January 2014, 18:12:56 »
:P
How do you figure a board is going to break because it makes a cheap noise when you tap your finger on it? I swear the term "build quality" is misused a lot.
Offline Linkbane
« Reply #41 on: Wed, 15 January 2014, 20:13:24 »
:P
Read before you write. He was talking about shifting inside of the case, not a cheap sound. That, like the rest of your argument, was purely imagination.
Offline fuzzybaffy
« Reply #42 on: Wed, 15 January 2014, 20:30:58 »
^ Nope, I was just talking about the plastic case shell shifting. Not the actual insides (ie. the PCB and/or metal plate).
Offline Polymer
« Reply #43 on: Wed, 15 January 2014, 20:53:55 »
The plastic shell shifting is because things aren't lined up right.  The way they've designed the case is so it is easy to open...but as a result of the design, it allows for a lot of twisting which means it won't sit right, the case will be loose in some areas...
BUT, you can fix it all...Put your RF on a flat surface and press on all four corners at the same time really hard..this will set it all in the right position..you may need to twist it around a bit but eventually it'll all sit right.
I'm not sure why they designed it that way but it does cause some confusion and upset people...really though, it is easy to "fix".
Offline neunelfer
  • HHKB Pro
« Reply #44 on: Wed, 15 January 2014, 21:02:57 »
:P
Guess I just have a really good imagination.
« Reply #45 on: Wed, 15 January 2014, 21:16:28 »
lol how odd.
btw neu, i like your sig pic!
Offline Linkbane
« Reply #46 on: Wed, 15 January 2014, 21:21:32 »
:P
Just a really irritable one. I'm starting to feel like tp, enjoying it now. Bring on more idiotic detractors.
Offline neunelfer
  • HHKB Pro
« Reply #47 on: Wed, 15 January 2014, 21:22:18 »
lol how odd.
Thanks man!
« Reply #48 on: Wed, 15 January 2014, 21:36:53 »
hush now, it's just that Topre ping  ;)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #49 on: Wed, 15 January 2014, 22:01:35 »
Let's stop bickering please.
