Author Topic: Opinions on 10 keyless kbs?  (Read 12642 times)
Offline kansas city shuffle
« on: Sat, 25 January 2014, 14:56:29 »
Howdy all,
I am in the market for picking up a 10 keyless keyboard, I am leaning towards either the -
Topre Realforce 87U 10 keyless
http://elitekeyboards.com/products.php?sub=topre_keyboards,rftenkeyless
or
Filco Majestouch 2 MX Brown 10 keyless
http://www.amazon.com/Filco-Majestouch-2-Tenkeyless-FKBN87M-EB2/dp/B004WOF7QM
Any other selections I should be aware of that you would recommend? Opinions?
Offline thesentinel
Re: Opinions on 10 keyless kbs?
« Reply #1 on: Sat, 25 January 2014, 14:59:17 »
Those are two really good keyboards but they both use different switches, so I'd say which ever switch you like more, get that one.
Keyboards are the only thing keeping me from consuming human flesh.
« Reply #3 on: Sat, 25 January 2014, 15:09:09 »
filco tkl should be $150 tops..
Right, good to know, now need to find a dealer in the US.
« Reply #4 on: Sat, 25 January 2014, 15:09:40 »
Any recommendations for other brands?
« Reply #5 on: Sat, 25 January 2014, 15:19:22 »
have you tried cherry mx switches yet?
« Reply #6 on: Sat, 25 January 2014, 15:26:37 »
Yes, have the MX blues Majestouch 2 and Realforce 104U, looking to go slim down but am open to hearing about other brands I may not be aware of.
« Reply #7 on: Sat, 25 January 2014, 15:48:46 »
the only other one out there is ducky.. all the others are "g4m3r brands" and have a bit of fluff...
I think ur probably ready for a custom..  hit up the GBs...
Of course I personally recommend the Egdx.. but..... if you must have rectangles, the gh60 / phantom's always there.
Offline mooswa
« Reply #8 on: Sat, 25 January 2014, 17:20:00 »
cm storm quick fire rapid.  i like mine a lot
« Reply #9 on: Sat, 25 January 2014, 18:08:25 »
If you have a RealForce already, so you really like it?  A lot of people who try Topre say they can't ever go back to anything else.  If that is the case, get another RealForce :)
Otherwise, QFR or Ducky would be a strong contender to a Filco.
You might also keep a look-out for the CM Novatouch keyboard, probably coming out soon - Topre with MX-compatible stems.
Offline Linkbane
« Reply #10 on: Sat, 25 January 2014, 18:36:38 »
For affordability, a QFR is a great choice because of its quality (relatively) and price, especially on sale. My favorite at the moment, though, is Ducky; great build quality and some amazing light modes (as well as key repeat) on their Shine series, as well as thick PBT keycaps on their special editions.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #11 on: Sat, 25 January 2014, 20:00:44 »
Yep, I am using the RealForce now, over my Filco MJ2 blues and IBM Model M, just wanted to solicit some opinions and see what's out there. I'll most likely pick up a RF 87U. Never tried the MX Browns, how does that stack up against the blues? Same experience minus the clacky?
« Reply #12 on: Sat, 25 January 2014, 20:06:23 »
browns suck compared to blues. don't even bother going that route.
it's a half assed switch that doesn't know if it's linear or tactile
Offline cmadrid
« Reply #13 on: Sat, 25 January 2014, 20:18:04 »
Yeah.. probably either go with the RF 87U, or if you want to go even smaller, the HHKB Pro
« Reply #14 on: Sat, 25 January 2014, 20:33:06 »
Here we go, this is the type of opinion I want to hear. I'll keep that in mind...cheers!
Offline johndavis33
« Reply #15 on: Sat, 25 January 2014, 20:46:16 »
Switch preference is all personal opinion. A lot of people like browns.
I'm not one of them and personally agree with everything demik said, but hey I hate blues to.
HAVE AND WILL KEEP: HHKB - Printed white | Ducky Banana edition - Whites | Model M13 | Unidentified Goodwill keyboard - Simplified black ALPS
TOO BE SOLD: TG3 BL82 - Clears | Wheelwrite 5 - Buckling Springs typewriter
SOLD: Rosewill RK9000 - Blacks | QFR - Blues | Ducky G2 Pro - Greens |
IT WILL BE MINE: Northgate Omnikey - White ALPS
« Reply #16 on: Sat, 25 January 2014, 23:05:15 »
Any opinions on the Leopold ten keyless? Or is that considered inferior to the Filco MJ2 ten keyless?
« Reply #17 on: Sat, 25 January 2014, 23:18:58 »
which leopold? fc700 or 200?
haven't used the 700, but my main problem with it is the non standard spacebar. say good bye to switching your keycaps and including the spacebar.
i also had some disconnection issues when i owned a 200, but the person i sold it to never had that problem (don't worry, i let him know the problem it had).
Offline CatNip :3
  • bouncy bouncy
« Reply #18 on: Sat, 25 January 2014, 23:19:30 »
The Leopold is a great boars. You need to keep in mind that they use Cherry stabilizers. The 700R also comes with fairly rough PBT keycaps. Other than that, they're pretty similar.
Offline CatNip :3
  • bouncy bouncy
« Reply #19 on: Sat, 25 January 2014, 23:19:56 »
The Leopold is a great board. You need to keep in mind that they use Cherry stabilizers. The 700R also comes with fairly rough PBT keycaps. Other than that, they're pretty similar.
Offline SonOfSonOfSpock
« Reply #20 on: Sat, 25 January 2014, 23:57:39 »
Like said earlier, switch preference is personal. It'd be best to try a full board, but if not there are switch testers and samples out there. I think brown switches are fine. I'd get a board with them if I was concerned about noise. Otherwise I prefer blues.
« Reply #21 on: Sat, 25 January 2014, 23:59:13 »
If you like your 104U then buy the Elite Keyboards All 45G Weight RealForce! It is worth the $240 but for some crazy reason they dropped it under $200. Such a steal! :D
Offline Comment
« Reply #22 on: Sun, 26 January 2014, 00:32:46 »
woahhhh the price on that is nutty, for that much id rather buy a realforce
Check out my WTB/WTS/WTTF Thread!
   HHKB Pro 2                 Noppoo Choc Mini
Offline Linkbane
« Reply #23 on: Sun, 26 January 2014, 01:08:47 »
There's a reason that people pay $500+ for custom boards, because they're simple better than the standard. Same with Filco, it's relative build quality is supposed to be quite a bit higher than Realforce boards (subjectively, the case has a really ugly amount of extra bezel attached to it as well).
Offline Comment
« Reply #24 on: Sun, 26 January 2014, 01:09:48 »
Its not so much the price of the Filco in general, just the fact that I've seen them in a bunch of other places for cheaper.
Offline Linkbane
« Reply #25 on: Sun, 26 January 2014, 01:15:47 »
I see what you mean. It's slightly overpriced in my opinion, and I wouldn't get a standard TKL MX board for that price, it just is no different than any other TKL board. Maybe if it was somewhere like $120 or so it would be reasonable.
« Reply #26 on: Sun, 26 January 2014, 12:27:11 »
Cheers all, I've ordered a RealForce 87U White, thanks for all the feedback and opinions!  :thumb:
Offline Candyflip
« Reply #27 on: Sun, 26 January 2014, 12:43:08 »
Nice choice, did you go for the 55 gram one or the one with different weights across the letter area?
Offline tbc
« Reply #28 on: Sun, 26 January 2014, 14:01:38 »
this is why ducky > filco when it comes to standard type boards.  they're much more innovative and they charge you for it.  much better than not beung innovative and charging you for their brand name.
also, i laughed at $150 realforce joke lol.
Offline Comment
« Reply #29 on: Sun, 26 January 2014, 15:25:42 »
Ive seen them for 150 in classifieds a couple of times let alone theyre only 199 right now... not seeing the joke when its a legitimate price
Offline tbc
« Reply #30 on: Sun, 26 January 2014, 15:32:16 »
you're comparing buying used to buying new.  not a valid comparison the slightest.
Offline Comment
« Reply #31 on: Sun, 26 January 2014, 15:41:13 »
Youre misunderstanding. They are new for 199 as we speak right now. In a purchase as big as a realforce compared to a filco, im sure that 50 dollar difference is minimal. Hence my comparison.
Offline Linkbane
« Reply #32 on: Sun, 26 January 2014, 15:52:06 »
It's actually quite large. Perhaps you're well off and it doesn't matter to you, but spending $120 on a Filco (or often <$100 for used, compared to almost no reduction in used Topre boards) is a huge difference from spending about twice that on a Topre board.
Offline Comment
« Reply #33 on: Sun, 26 January 2014, 17:34:56 »
No we are talking about a 150 dollar filco. This is why this started. Now you say that used boards have no place in this conversation and now you compare them. It has nothing to do with being well off. You took a 150 to 200 dollar comparison and tried to make it a <100 to 200 comparison. You cant possibly say I cant bring a used topre into the equation and then bring a used filco in... the original statement still stands. The difference between the new filco that OP referenced and the realforce is 50 dollars. If youre picking up this mech keyboard hobby, you have spending money. My original statement said that if I was spending 150 on a filco (like the one OP referenced) that id rather buy a realforce. Surely you could say that a used filco would be less but I also say a used topre could be as well. I was only telling you it wasnt a joke. Case closed. Enjoy your day.  :thumb:
Offline Pacifist
  • on hiatus
« Reply #34 on: Sun, 26 January 2014, 17:36:14 »
if $50 breaks your bank you probally shouldn't buy a $150 board anyways
Offline Candyflip
« Reply #35 on: Sun, 26 January 2014, 17:43:02 »
You say that more than a 30% raise on the price on an already expensive keyboard is small amount? Or that the Realforce is more worth it I don't understand...
Offline Comment
« Reply #36 on: Sun, 26 January 2014, 17:47:45 »
Just that theyre both expensive and that it wouldnt be wrong to pay 50 more on a highly regarded board
Offline Linkbane
« Reply #37 on: Sun, 26 January 2014, 18:04:59 »
What? Show me a legitimate Realforce that's not half-dead for $150 (not including the Type Heaven) and I'll accept it as truth. Until then, make less bad jokes please.
Offline Comment
« Reply #38 on: Sun, 26 January 2014, 18:10:37 »
Dont be naive, if the new one is coming in at 199, and youve used one for a couple of months and had to sell it, what would you list it at reasonably? Also please dont digress to previous comments when were in mid conversation. I explained all of my points thoroughly.
Offline tbc
« Reply #39 on: Sun, 26 January 2014, 18:13:35 »
$175. the selling point of topre is to be able to resell it for next to no loss.
please show this 150 board you said you saw.
Offline Candyflip
« Reply #40 on: Sun, 26 January 2014, 18:14:20 »
While I get your point I have to agree with him that they never go that low, on the other side I have seen recently a Filco for 85 shipped.
Offline Comment
« Reply #41 on: Sun, 26 January 2014, 18:20:02 »
This is the "joke" we have at hand here. I said if I am spending 150 for a filco.... id rather rather spend the 199 on a brand new realforce... show me the joke. This is getting out of hand.
Offline Comment
« Reply #42 on: Sun, 26 January 2014, 18:22:16 »
The 25 dollar difference is enough to be worlds apart apparently. Could you honestly say that youd spend 150 on a filco instead of a 175 (as you put it) realforce? Thats the point. Its not outrageous.
« Reply #43 on: Sun, 26 January 2014, 18:24:17 »
Good choice sir!!!!!  :thumb:
Offline Candyflip
« Reply #44 on: Sun, 26 January 2014, 18:24:21 »
Offline tbc
« Reply #45 on: Sun, 26 January 2014, 18:34:41 »
i'm not sure at any point in time did i say anything about the value of a filco being worth it at $150.
i just said that expecting a realforce at $150 was funny.
Offline Comment
« Reply #46 on: Sun, 26 January 2014, 18:36:01 »
But at 175 its not?
Offline tbc
« Reply #47 on: Sun, 26 January 2014, 18:38:55 »
that's a 50% difference.  imo, that's significant.  also in line with what rfs sell for (retail - $25)
Offline Comment
« Reply #48 on: Sun, 26 January 2014, 18:41:43 »
50% of what? Its a $25 difference.
Offline noons
« Reply #49 on: Sun, 26 January 2014, 18:49:46 »
Funny you say that, I hate blues and love browns. To each their own..
Tofu65 Turquoise Tealios | Drop ALT LP Alpacas | 2X Leopold FC750R MX Brown | KUL MX Brown w/Cherry Stab MOD | Leopold FC660C BLANK | REALFORCE 87U 45G | HHKB PRO2 | Leopold TKL MX RED | Filco Majestouch 2 TKL MX BLUE
