Author Topic: Shortcut Keyboard for Photoshop and graphics editing softwares  (Read 3316 times)
Offline kakakowie
  • Make Love not War
« on: Sat, 08 February 2014, 23:48:03 »
What do you guys think of this ridiculously huge "keyboard":
https://www.kickstarter.com/projects/5074048/special-dedicated-editing-keyboard-for-photoshop
I guess it's literally a key for every action. :eek:
Offline angelic_sedition
Re: Shortcut Keyboard for Photoshop and graphics editing softwares
« Reply #1 on: Sat, 08 February 2014, 23:50:43 »
Set up modes/ layers instead if you want to use a lot of keyboard shortcuts. This is total overkill imho. Not efficient at all.
QWERTY(104wpm) -> CarpalxQ(modded) -> Colemak(118wpm) -> Colemak-DH
Mouse less.
« Reply #2 on: Sun, 09 February 2014, 01:09:30 »
so what happens when they add a new function...
does this have a removable top plate, so they can add stuff with a reprint?
no.. nuh uh... this won't work...
Look how deep it is....  lets say you are using  many of the further away functions..
You'd have to  look down every time, because you'd have to jump-key.. even with a homing bar system, the distance is too far to accurately transition...
the forward depth would also require someone to hover their shoulders... this is a sure fire way to get RSI...
Offline jacobolus
« Reply #3 on: Sun, 09 February 2014, 01:57:37 »
The default shortcuts for photoshop kind of suck, but damn this looks terrible.  If you have to hunt around and move your hand a large distance to press the key for the tool you want, you might as well just use the mouse.
Ideally you want something that you *don't have to look at* to use, and can access everything you need with one hand while the other is on the mouse. Something like one of those gamer keypads would be alright. But better would be e.g. half an Ergodox. [Well, Ergodox has a ****ty thumb layout, but the overall idea is there.] Multiple thumb key modifiers + the keys in the main letter area to activate all of the common Photoshop tools sounds great.
(Unfortunately, I don’t know any keyboard firmware which easily allows several dozen key macros, which you might need for this kind of thing.)
Offline yasuo
  • spanengan puyeng newbie
« Reply #4 on: Sun, 09 February 2014, 02:04:27 »
i prefer just use mouse :)
Logitech MK220 Colemak DH
« Reply #5 on: Sun, 09 February 2014, 18:08:54 »
Or worse: remove an old one, because they merged it with another.
Offline Lastpilot
  • Power stance
« Reply #6 on: Sun, 09 February 2014, 18:12:23 »
A standard full-size makes more sense to me. Just learn the built in combination shortcuts.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Sun, 09 February 2014, 19:00:21 »
ridiculous............
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline blackbox
« Reply #8 on: Wed, 12 March 2014, 12:11:04 »
Cant imagine how it can be more effective than a usual keyboard. Looking after the right icon isnt exactly more effective than a shortcut.
The LAN table!
Offline BlueBär
« Reply #9 on: Wed, 12 March 2014, 12:47:36 »
Seems like ultra low travel switches or even one of those foil keyboards, which would be terrible...
What I think is useful is the colour-coding, that looks like a good idea to me. However, I don't think searching a key on this huge thing is much faster than looking in the menu for the command. A smaller version with just the common keybinds or multiple layers would probably be more useful.
Not a PS user myself though, so I can't really judge this.
Offline histevenhere
  • Student
« Reply #10 on: Thu, 13 March 2014, 11:24:42 »
I've used PS extensively in school and after memorizing the shortcuts, this board would be a waste of space on the desk imho
HHKB PRO 2, DAS ULTIMATE, SIIG MINITOUCH, KBT PURE, IBM MODEL M, MICROSOFT COMFORT CURVE 2000, CHERRY G84-4100, TG3-TP, QUICKFIRE RAPID, REALFORCE 87u
Offline blackbox
« Reply #11 on: Fri, 14 March 2014, 01:03:04 »
Yup, It must take up loads of space and you cant use it for normal typing. That means that it woud be even more impractical.
The LAN table!
