Author Topic: ErgoDuck  (Read 39265 times)
Offline BlueBär
Re: ErgoDuck
« Reply #50 on: Sun, 16 March 2014, 16:49:14 »
I just hope this does not cost a fortune. The renders show what appears to be an aluminum case. Awghh!
It will have an aluminum case. It's basically an ergo version of the Orion TKL (or the LightSaver), so expect a similar or higher price.
Offline Pacifist
  • on hiatus
Re: ErgoDuck
« Reply #51 on: Sun, 16 March 2014, 16:53:19 »
Its going to be at least $300, more towards $500 range.
Duck is pretty much 100% aluminum, and while for other boards he made you could get a different case, this one you can only get from him
Offline ideus
  • Björkö.
Re: ErgoDuck
« Reply #52 on: Sun, 16 March 2014, 16:53:41 »
My dreams had blown away. I'll stick with my humble Leo then.
Re: ErgoDuck
« Reply #53 on: Sun, 16 March 2014, 17:27:34 »
This is the first so called ergonomic keyboard I really like. Does someone have a link to a place with information on the board in English?
^ +1
You guys do realize that there is only one post on this anywhere. Translate the page, but as you can see the verbal information is sparse; the pictures tell the story. This is relatively common to see on the Korean keyboard forums and websites.
I hope it does get made. If so you'll be able to see lots more information and pictures. Lots of pictures.
Closer to the orion than the lightsaver. The orion has a two piece case (and a price to match) whereas the lightsaver and duck mini have just a single piece "tub" case. This will be awesome, but not cheap
You will likely be able to get just the PCBs at a reasonable price. Duck (in partnership with kbd4u) has offered this in the past on all their models
Offline Pacifist
  • on hiatus
Re: ErgoDuck
« Reply #54 on: Sun, 16 March 2014, 17:29:30 »
The problem with that is where are you going to get a case? DIY it? At least with the 60% and tkl duck sets you can easily get cases elsewhere
Re: ErgoDuck
« Reply #55 on: Sun, 16 March 2014, 17:30:51 »
Of course.
I would just get some metal bolts and make legs for it out of those. You can also tent it to your specification.
Offline tbc
Re: ErgoDuck
« Reply #56 on: Sun, 16 March 2014, 17:37:03 »
did he forget cables?
I was under the impression metal cases were really annoying for BT keyboards.  not that wireless boards are even very popular.
Re: ErgoDuck
« Reply #57 on: Sun, 16 March 2014, 17:53:41 »
It is likely not possible to properly render the cables, and they were simply omitted.
Offline tbc
Re: ErgoDuck
« Reply #58 on: Sun, 16 March 2014, 18:10:19 »
well, i don't see any cutouts for them either.  did anyone else see them?
Offline daerid
    • Rossipedia
Re: ErgoDuck
« Reply #59 on: Sun, 16 March 2014, 18:12:32 »
It is a nice looking board. Super simple. I wonder if they'll make a version without the left hand cluster (those always screw me up whenever I try to hit control or escape).
Offline Pacifist
  • on hiatus
Re: ErgoDuck
« Reply #60 on: Sun, 16 March 2014, 18:14:33 »
What about those SP locks?
Re: ErgoDuck
« Reply #61 on: Sun, 16 March 2014, 18:16:20 »
Oooo. Perhaps this will make up for me missing out on the Lightsaver :)
Offline mrmillsy
Re: ErgoDuck
« Reply #62 on: Mon, 17 March 2014, 04:32:22 »
I'm with you on the left hand cluster.  I'm sure I COULD learn to handle it, but even a larger than normal base tends to screw with my ESC-mashing so I'm not 100% confident.
Offline BlueBär
Re: ErgoDuck
« Reply #63 on: Mon, 17 March 2014, 06:42:36 »
You could always remap Esc to the top left key. Are these fully programmable btw?
Offline daerid
    • Rossipedia
Re: ErgoDuck
« Reply #64 on: Mon, 17 March 2014, 11:09:15 »
Hmmm maybe, but then I have non-functioning keys on my board, and that would dive me crazy
Offline daerid
    • Rossipedia
Re: ErgoDuck
« Reply #65 on: Mon, 17 March 2014, 11:10:23 »
If they are, that would definitely be a viable solution.
Offline vatin
Re: ErgoDuck
« Reply #66 on: Mon, 17 March 2014, 18:59:47 »
Staggered roll is not ergonomic
HHKB Professional Classic
Offline steve.v
Re: ErgoDuck
« Reply #67 on: Mon, 17 March 2014, 20:17:49 »
I can't wait to buy this!, er oh wait, it's not programmable, staggered keys, nvm no thanks. It should be renamed classicDuck.
Offline BlueBär
Re: ErgoDuck
« Reply #68 on: Mon, 17 March 2014, 20:20:52 »
It is probably programmable, as Duck's other keyboards are as well: http://duck0113.tistory.com/84
Offline blackbox
Re: ErgoDuck
« Reply #69 on: Tue, 18 March 2014, 01:32:54 »
I would had bought it if it wasnt for the estimated price. Thats more pretty expensive...
The LAN table!
Offline tbc
Re: ErgoDuck
« Reply #70 on: Mon, 31 March 2014, 22:25:41 »
um.  any update?
Re: ErgoDuck
« Reply #71 on: Mon, 31 March 2014, 22:33:29 »
um.  any update?
There's a good chance it won't even get made. Even if it does, I wouldn't expect an update for some months.
Offline blackbox
Re: ErgoDuck
« Reply #72 on: Tue, 01 April 2014, 02:26:15 »
um.  any update?
Thats too bad.
The LAN table!
Offline tricheboars
  • Keyboards are Important!
Re: ErgoDuck
« Reply #73 on: Sat, 19 April 2014, 19:05:09 »
Sigh...
It's not Ergo if it's staggered qwerty
i agree. this would be tempting if it wasnt for the staggered layout.  kmac quality and case options are awesome but once you get use to a matrix layout it is just so much better.  who knows maybe these guys will have a pcb variant that is matrix style. doubt it though.
does anyone else have issues trying to access the link on the OP?
Re: ErgoDuck
« Reply #74 on: Sat, 19 April 2014, 19:20:45 »
Sigh...
I think staggered is fine, as long as it's split, because you can just turn the board so it more/less replicates column-ar in terms of key spacing..
I think the primary issue with this board will be Tilting option..  it seems easy enough to do..  but being koreans, and how they're obsessed with right angles...  they might forget...
without tenting capability,  this ergoduck would just be a 2 piece paper weight..
Offline tricheboars
Re: ErgoDuck
« Reply #75 on: Sat, 19 April 2014, 19:49:23 »
stainless steal angled handwells in a two part kustom ergo board with a 62g ergoclear matrix layout and R3 SA Dolch caps.
« Last Edit: Sat, 19 April 2014, 19:51:38 by tricheboars »
Offline tribade
Re: ErgoDuck
« Reply #76 on: Sat, 19 April 2014, 21:31:25 »
Their site is down I guess?  I haven't been able to access it.  I blame you guys  :p
This might be my end game.........
You had better not groupbuy this before the eagle/viper one!  I'm on to you Elton  :))
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline tbc
Re: ErgoDuck
« Reply #77 on: Sat, 19 April 2014, 22:10:22 »
i still say a split board is miles more ergonomic than nothinf.  it might not be everything ergo, but it's something ergo
Offline Permeability
Re: ErgoDuck
« Reply #78 on: Mon, 21 April 2014, 21:57:10 »
Looks good. Duck comes out with so many miles products hopefully this one goes into production.
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline intelli78
Re: ErgoDuck
« Reply #79 on: Mon, 21 April 2014, 22:39:31 »
This kills the wallet.
Offline Wildcard
  • When caffeine isn't enough
Re: ErgoDuck
« Reply #80 on: Mon, 21 April 2014, 22:52:12 »
Sold. "Throws money at screen"
Offline yuktsi
  • Colour my life with the chaos of trouble
Re: ErgoDuck
« Reply #81 on: Mon, 21 April 2014, 22:59:44 »
so much gooding, so little money  :(
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline domoaligato
Re: ErgoDuck
« Reply #82 on: Wed, 21 May 2014, 19:23:54 »
any news on this?
Offline tbc
Re: ErgoDuck
« Reply #83 on: Wed, 21 May 2014, 19:35:04 »
seems like 3 months will be the earliest possible.  duck seems to want to finish the whole 'lightsaver' stack (lightsaver, orion, eagle/viper).
I REALLY like the look of this, but I'm not sure I want it to go into production and be tempted :S
Offline Zeal
    • Zeal Generation Inc.
Re: ErgoDuck
« Reply #84 on: Wed, 21 May 2014, 20:27:22 »
Ditch your ergodox for ergoduck.  :))
Offline domoaligato
Re: ErgoDuck
« Reply #85 on: Sat, 24 May 2014, 11:30:37 »
I will end up with 3 gh60's in the end, but this would be my ideal perfect keyboard for my office @ work.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: ErgoDuck
« Reply #86 on: Sat, 24 May 2014, 11:32:48 »
Yeah I'd love one of these but I'm pretty sure I'd stick with 60% boards on my other machines, would be a pain having the two pieces plus a mouse when I'm gaming on the telly.
Offline paicrai
  • mindblank
Re: ErgoDuck
« Reply #87 on: Sat, 24 May 2014, 16:17:42 »
whoa, i'd totally get one
THE FEMINIST ILLUMINATI
Re: ErgoDuck
« Reply #88 on: Sat, 24 May 2014, 16:20:49 »
It's atrocious. Stag-werty is such a gross layout.
Qwerty master race
Offline jacobolus
Re: ErgoDuck
« Reply #89 on: Sat, 24 May 2014, 17:17:15 »
Qwerty master race
What’s stag-werty?
Re: ErgoDuck
« Reply #90 on: Sat, 24 May 2014, 17:19:42 »
Qwerty master race
What’s stag-werty?
I believe i's a neologism: a portmanteau of staggered and qwerty.
Re: ErgoDuck
« Reply #91 on: Sat, 24 May 2014, 19:23:26 »
correct
The Ergodox is a good example, though I think it's a better executed one than this.
Offline jacobolus
Re: ErgoDuck
« Reply #92 on: Sat, 24 May 2014, 21:50:05 »
correct
So you mean column-staggered QWERTY? I thought you might mean e.g. a symmetric row stagger.
The particular keyboard we’re talking about seems to just use a standard Sholes (1/2, 1/4, 1/2) key row stagger, so I’m confused by the apparent contradiction between “It's atrocious” and “Qwerty master race”.
Offline domoaligato
Re: ErgoDuck
« Reply #93 on: Sat, 24 May 2014, 22:07:37 »
I was curious about this also. it looks like standard qwerty to me except for the extra left keys, the short right shift and extra right keys.
Offline divito
Re: ErgoDuck
« Reply #94 on: Sun, 27 July 2014, 08:43:53 »
Any updates on this?
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline FrostyToast
  • Litshoard
Re: ErgoDuck
« Reply #95 on: Sun, 27 July 2014, 08:48:10 »
Is that a split spacebar Duck? Help guys, I am dying over here.
Also, split spacebar dolch? Is this heaven?
Quote from: elton5354
Offline domoaligato
Re: ErgoDuck
« Reply #96 on: Sun, 27 July 2014, 17:19:56 »
yeah the spacebars are shift keys :)
Re: ErgoDuck
« Reply #97 on: Sun, 27 July 2014, 17:34:27 »
It's just a render. I'm not sure if GMK can make spacebars in that size.
Offline FrostyToast
  • Litshoard
Re: ErgoDuck
« Reply #98 on: Sun, 27 July 2014, 21:41:43 »
Those spacebars are apparently shiftkey sized, so a flipped blank shift might work....
Offline jacobolus
Re: ErgoDuck
« Reply #99 on: Sun, 27 July 2014, 21:57:29 »
Whatever-size DSA caps work pretty well for spacebars, I find (even if the rest of the caps are cherry or DCS or whatever profile). I’d recommend using those instead of cylindrical-profile shift keys, flipped or not.
