Author Topic: Blank keyboard  (Read 6290 times)
Offline favorite54
Blank keyboard
« on: Wed, 23 April 2014, 01:36:50 »
Hi, I am total newbie. Saw beautiful blank keyboard and spent whole night looking for one to buy.
Is it cheaper to buy blank keyboard or normal and than get blank keycaps?
Cherry G80-3000 is fantastic :)
Thank you guys and greetings from the Czech Republic ;)
Offline blackbox
Re: Blank keyboard
« Reply #1 on: Wed, 23 April 2014, 01:43:59 »
You have das keyboard that has blank keycaps on their keyboards:
http://www.daskeyboard.com/daskeyboard-4-ultimate/
It is certanly cheaper to buy blank keycaps and change it on an keyboard with cherry mx switches.
http://www.wasdkeyboards.com/index.php/products/keycap-set.html
The LAN table!
Offline Oobly
Re: Blank keyboard
« Reply #2 on: Wed, 23 April 2014, 01:51:45 »
You don't need to spend much to have blank caps:
http://www.banggood.com/PBT-87-Blank-White-Key-Caps-For-Cherry-MX-Keyboard-p-84084.html
http://www.banggood.com/POM-84-Set-Blank-Key-Caps-Black-Keycaps-For-Cherry-MX-Keyboard-p-84082.html
Or just search for "blank keycaps" on eBay.
All you need is a board with Cherry MX or Cherry MX-compatible switches.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: Blank keyboard
« Reply #3 on: Wed, 23 April 2014, 02:14:24 »
Welcome to Geekhack!
Blank keycaps can easily be found.
More important questions are: What type of switch do you want?  What layout (fullsize, TKL, 60%) do you want?  Backlighting?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Blank keyboard
« Reply #4 on: Thu, 24 April 2014, 13:23:19 »
If you want nice blank keys as stock and like the G80-3000... then the G80-3000LPCXY or LPCXX is the one for you!
Re: Blank keyboard
« Reply #5 on: Thu, 24 April 2014, 20:06:58 »
this! It's the one for you! cherry blank POM keycaps are excellent: the best.
Sadly, it looks like keyboardco no longer stocks them.
Offline minho
  • i'm kind of back
Re: Blank keyboard
« Reply #6 on: Thu, 24 April 2014, 21:51:15 »
They're supposed to be "coming soon" to Banggood. Can't attest to the quality of them though - knowing Keycool and the quality of their blank PBT set, it will also probably be pretty thin.
Offline Pacifist
  • on hiatus
Re: Blank keyboard
« Reply #7 on: Thu, 24 April 2014, 21:56:39 »
Cherry blank POM?
Offline minho
  • i'm kind of back
Re: Blank keyboard
« Reply #9 on: Fri, 25 April 2014, 01:01:50 »
Cherry blank POM?
Nevermind, I thought you meant MX-stem compatible, not made by Cherry :p
Re: Blank keyboard
« Reply #10 on: Fri, 25 April 2014, 08:47:37 »
An older version of the Das Keyboard was essentially a rebranded G80-3000 with blank black POM keycaps and blue switches. Might be found on the second-hand market.
Re: Blank keyboard
« Reply #11 on: Fri, 25 April 2014, 15:09:14 »
That is true. The DAS II aka G80-3485LWNUS is actually a better choice since it is an NKRO model unlike the G80-3000LPCX* which are only 2KRO. They do pop up in used market now and then if you want to hunt or don't mind waiting for an indefinite period.
Offline iLLucionist
  • Topre is Love.
Re: Blank keyboard
« Reply #12 on: Sat, 03 May 2014, 16:25:10 »
Just installed these today (Ducky PBT Black Blanks):
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=98
Made some pics: https://flic.kr/s/aHsjXM9Au9
Really like them so far.
Re: Blank keyboard
« Reply #13 on: Sat, 03 May 2014, 20:35:05 »
Your first "mold visible through caps" picture just shows the sprue marks.  This is a side-effect of the manufacturing process, and most keycaps have this - perfectly normal.
Re: Blank keyboard
« Reply #14 on: Sat, 03 May 2014, 20:36:48 »
What rowdy said.
You know how model planes have all the plastic bits on one piece of plastic? That's how keycaps are made.
Re: Blank keyboard
« Reply #15 on: Sat, 03 May 2014, 21:43:47 »
but they are right for the second picture.
https://www.flickr.com/photos/124284328@N08/14094594472/in/set-72157644442606616
You can see a depression in the top of the cap from where it cools in the mould.
Offline iLLucionist
  • Topre is Love.
Re: Blank keyboard
« Reply #16 on: Sun, 04 May 2014, 05:07:20 »
Thanks about the sprue marks, will change that in the pic's description. I noticed them also on my HHKB and Filco ABS caps, but those sprue marks were at the bottom, barely noticeable.
The depression in the top of the cap I find unacceptable, but perhaps I have too much OCD :P Anyway, you can barely see it from a distance, only up close.
Offline dodzylla
Re: Blank keyboard
« Reply #17 on: Sat, 03 January 2015, 06:16:14 »
Hello Guys!
I want to buy a blank keyboard, with cherry mx brown, and with iso layout! I want to use this keyboard for work, gaming, typing... so , for everything:)
I saw das keyboard 4 professional  but thats a little bit expensive, and i don't know its repairable, because they have no guarantee here in EU.
If you can give me more keyboard ideas, i would be grateful :D
Thanks,
Dod
Offline Ngt
Re: Blank keyboard
« Reply #18 on: Sat, 03 January 2015, 07:22:26 »
Hello Guys!
Thanks,
Dod
Basically I'd say you could get any keyboard w/ MX Brown and then buy a blank keycaps set. You could get the PBT keycaps set made by Ducky. They sell for ~50€.
