Author Topic: I Hope I Will Be Doing the Right Thing, Cooler Master  (Read 2835 times)
Offline deazncy
« on: Sat, 07 June 2014, 04:50:23 »
Dang, I miss Topre switches. I remember when I sold my fc660c I felt this.. void inside me. I'm running a yellow edition ducky shine 3 with reds atm and I thought I was finally done with the kb game, but I heard CM will be releasing their new Novatouch keyboard in the near future.
Now, what this means is that I will have to sell my shine 3 in order to purchase the Novatouch (I don't want the shine to gather dust like my pokerX). I'm just really hoping that CM's take on electro-capacitive switches matches that of Topre (the fc660c felt amazing).
I hope I will never have to buy another keyboard again after this; I'm counting on you, Cooler Master.
“Do not pray for an easy life, pray for the strength to endure a difficult one” -Bruce Lee
Offline blackbox
Re: I Hope I Will Be Doing the Right Thing, Cooler Master
« Reply #1 on: Sat, 07 June 2014, 04:54:54 »
I think It would be better to post it here:
http://geekhack.org/index.php?topic=58576.0
The LAN table!
« Reply #2 on: Sat, 07 June 2014, 06:58:00 »
Topre feels identical to rubber dome keyboards..
Because most people grow up on rubber dome boards, they are naturally tuned to Topre switches..
As for Coolermaster's TAKE...  how hard is it to make rubber domes...  considering we already HAVE rubberdomes...
SEriously...  What are you expecting...   It's m0re of the same thing we've had since childhood..
Not a bad thing...   I'm just confused as to why you're hoping for Change when it's Familiarity that generally convinces people to stay on Topre..
Offline dante
« Reply #3 on: Sat, 07 June 2014, 11:54:53 »
Offline Frenir
  • HHKB Viking
« Reply #4 on: Sat, 07 June 2014, 12:00:28 »
Offline JinDesu
« Reply #5 on: Sat, 07 June 2014, 12:02:48 »
I just got a Realforce 45g (101) and I have dell rubber domes at work. They are nowhere near similar in feel.
Someday somebody will best me, but it won't be today, and it won't be you.
Proud owner of a Filco Majestouch Cherry MX Blue Tenkeyless, KBT Race S, & Realforce 101
Offline Jagriff
« Reply #6 on: Sat, 07 June 2014, 12:05:12 »
I just want to know if they will be compatible with PCBs created for Cherry MX switches. I'd love to try topre, but I won't risk the conflict of liking it and not being able to put it on my ErgoDox.
« Reply #7 on: Sat, 07 June 2014, 14:25:43 »
Super Serious!
Offline Oobly
« Reply #8 on: Sat, 07 June 2014, 14:44:38 »
It should since it says "Topre" on the Novatouch PCB: http://geekhack.org/index.php?topic=56838.msg1286708#msg1286708
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #9 on: Sat, 07 June 2014, 14:50:00 »
Its a topre PCB with topre springs and domes just like other tore boards, the only difference seems to be the plunger which has been made compatible with MX caps and the stabilizers.
Offline deazncy
« Reply #10 on: Sat, 07 June 2014, 15:22:30 »
Ah, I was led to believe that CM would manufacture everything from the pcb to the springs to domes. This makes me happy :)
