Author Topic: Any get the Anniversary Pentium? Nekkid Photo  (Read 7777 times)
« on: Tue, 01 July 2014, 15:47:38 »
$105 Microcenter bundle.. still LIVE...
MSI- Z97 PC Mate (open-box), $40
+ 2yr warranty on motherboard, $5
Pentium G3258 Anniversary Edition, $60
http://www.microcenter.com/product/435187/G3258_32_GHz_LGA1150_Boxed_Processor
http://www.microcenter.com/product/433127/Z97_PC_Mate_Socket_LGA_1150_ATX_Intel_Motherboard
Add both items to cart.. no tricks.. no rebates.. just get there.. before they sell out..
Bundle price will be reflected in cart.. the mobo is $91 without the bundle.
Unlocked Core Multiplier..
69956-0
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
Re: Any get the Anniversary pentium?
« Reply #1 on: Tue, 01 July 2014, 16:00:04 »
Cheap enough to play with.
If you have the cash, do it. :thumb:
|||My other keyboards :
x
« Reply #2 on: Tue, 01 July 2014, 16:03:31 »
The thing I'm most conflicted about is because I have 2 concepts within me that are Fighting..
Concept 1, Gotta-catch'm-all....
Concept 2, Price to performance..
The numbers work out to..
6855 cpu points/ $70 (pentium Anniversary 4.8ghz OC)
10936 cpu points/ $170  (4670k 4.8ghz OC)
Now if you add in the cost of a SOLID, Overclocking motherboard + approx $100..  the ratio no longer favors the Anniversary Edition..
so you're looking at
6855/$170.... Pentium...  40 points per dollar
10937/$270.... 4670k... 40 points per dollar
So basically... Intel set the price exactly such that you get about the same performance/ dollar....
There's really no point in buying a slower chip... if you get the SAME performance per dollar on a Higher end chip... 'within affordability of-course'...
But.. freakin'  it says Anniversary on the Damn box.. and Concept 1 makes me go I WANT IT.........!!!!!!!!!
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #3 on: Tue, 01 July 2014, 16:49:41 »
DO IT!!  :D
« Reply #4 on: Tue, 01 July 2014, 16:50:21 »
Fvk it... Going to Microcenter... see ya'll there..
NJ Patterson store...
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #5 on: Tue, 01 July 2014, 17:06:28 »
Why not just get the original Pentium from 1994? Those work perfectly fine and can be had for much cheaper.
Offline Zeal
    • Zeal Generation Inc.
« Reply #6 on: Tue, 01 July 2014, 17:14:02 »
Oh, didn't even know Intel released an anniversary Pentium!
« Reply #7 on: Tue, 01 July 2014, 21:09:52 »
Yup...
I just got home.. microcenter is like an opium den for 1337 people..
Although while I was there, there were a sufficient number of n00bers asking the dumbest questions..
Snagged mobo and cpu for $105 total..
Overclock time...
Offline HPE1000
  • Keycap Paparazzo
« Reply #8 on: Tue, 01 July 2014, 21:25:48 »
Sounds fun, what are you going to use to cool it? I dont think it should take a ton even if it is overclocked a ton.
Offline Air tree
« Reply #9 on: Tue, 01 July 2014, 22:34:10 »
Yup...
Overclock time...
Now you just need a watercooling loop for Über overclocking potential.  ^-^
« Reply #10 on: Wed, 02 July 2014, 00:00:12 »
just a zalman cooler I got for $10 at some point...  Honestly I don't think i need much..  I'm just waiting for people to delid before I do, so that i know where to NOT cut...
But i'm typing from it now... seems pretty solid..
Offline HPE1000
  • Keycap Paparazzo
« Reply #11 on: Wed, 02 July 2014, 00:03:10 »
They can be delidded as well? I thought that was an advantage of them, that they were actually soldered on from the factory again.
Offline Badwrench
  • ummmm.....I forgot
« Reply #12 on: Wed, 02 July 2014, 00:06:40 »
Which mobo did you end up going with?  You don't need a super high-end unit as the A.E. Pentium is only 53W, and most people are running into a voltage wall around 1.4.  From there they seem to scale very poorly, but still, an OC from 3.2 to roughly 4.6ish is quite fun.
« Reply #13 on: Wed, 02 July 2014, 00:10:17 »
i got the microcenter bundal,  MSI z97 pc-mate,  the board was open-box $45 out the door with 2 year warranty
and the cpu was $60 out the door
i also don't think u need a supa-board for ocing this cpu... i'm googling the MSI settings currently, they're different from asus bios that i'm used to.
Offline Badwrench
« Reply #14 on: Wed, 02 July 2014, 00:13:06 »
Nice deal, especially with the warranty.
Offline Air tree
« Reply #15 on: Wed, 02 July 2014, 00:15:00 »
Give us some performance tests before and after the overclock pls.
« Reply #16 on: Wed, 02 July 2014, 01:03:11 »
haha.. it's not really a surprise anymore  these days..  just take cpu bench and multiply by your percentage OC..
right now i have 40%oc..   will push more
I am on 4.5 right now 1.3v  and it's linpack peaking at 62C...
this might not even need delid.... hahaha
some of these msi configurations are confusing though..
Offline Lanx
« Reply #17 on: Wed, 02 July 2014, 01:10:12 »
tell me if they fixed the roads yet.
Offline berserkfan
« Reply #18 on: Wed, 02 July 2014, 01:28:44 »
Well said!  ;D
I'm not a believer in buying quickly-outdated computer stuff myself.
« Reply #19 on: Wed, 02 July 2014, 01:40:05 »
hahaha.. no NJ roads are in persistent state of repair... they were fixing the same section of route 1 for 20 years
20pass linpack @ 4.6ghz 1.3v
This seems to be the limit of 1.3 (the SAFE voltage w/ regards to haswell)
People online claiming 1.37 required for 4.8
I think i might need to delid for that... because when i turned off my AC, the proc tops out @ 72C for the current 4.6ghz 1.3v
If i push the fan, it might be fine without delid,  but quiet operations is a priority.. so... hrrm......
But overall... This is damn easy...  great freaking value if you have microcenter access
« Reply #20 on: Wed, 02 July 2014, 18:07:16 »
Hmmmmm  thunderstorm outside... should I pause Stability testing?
Offline Oobly
« Reply #21 on: Thu, 03 July 2014, 03:45:24 »
Nah, just combine it with toughness / EMP resistance testing...  :thumb:   :p
<but unplug your ErgoDox just in case...>
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #22 on: Thu, 03 July 2014, 04:00:17 »
That's where it gets fun.  Push it, push it to the extreme, make it go Chernobyl-like and then you'll know you're a serious Overclocker  8) .
« Reply #23 on: Thu, 03 July 2014, 11:15:16 »
The power actually did go out last night..  Computer just turned off.. no surge..
So here's the decision
I've pegged it @ 1.28v for complete stability @ 4.6ghz,  68 Celcius benchtest
I need exactly 1.38v for complete stability @ 4.8ghz, 87 Celcius benchtest
What would you guys pick..
Offline HPE1000
  • Keycap Paparazzo
Re: Any get the Anniversary Pentium?
« Reply #24 on: Thu, 03 July 2014, 11:39:27 »
Just go for the highest possible overclock that you can validate, I found that to be pretty fun since it doesn't really require a golden chip or amazing cooling.  :p
Here was my best
I'd stay at 4.6 if it is just for 24/7 use though, much better temperatures. Are you testing it with prime95, intelburntest, or something else?
Offline Zeal
« Reply #25 on: Thu, 03 July 2014, 11:53:05 »
87C is still fine for a stress test. My personal limit is 90C-92C.
What stress testing software did you use? I found IBT@Extreme to burn way hotter (~10C higher) than Prime95.
« Reply #26 on: Thu, 03 July 2014, 12:00:34 »
IBT only runs hotter if your processor is AVX enabled.
the Pentium anniversary doesn't have avx.. so Prime 95 small ftt still provides the higher temperature.
Offline Zeal
« Reply #27 on: Thu, 03 July 2014, 12:06:33 »
Ah right, good ol' pentiums.  :)
« Reply #28 on: Thu, 03 July 2014, 12:10:37 »
You know what I'm bummed out about?
No freakin' pentium sticker in the box..
Offline Zeal
« Reply #29 on: Thu, 03 July 2014, 12:12:04 »
No way!
Not even an anniversary one?!
« Reply #30 on: Thu, 03 July 2014, 12:15:10 »
No way!
well you get .. A sticker.. but it's not the old cool silver kind..
It's a crappy one, with a sliver of foil on top, and it just says pentium , white on blue.. pretty lame...
They put zero thought into this...
69794-0
Offline HPE1000
  • Keycap Paparazzo
Re: Any get the Anniversary Pentium? Nekkid Photo
« Reply #32 on: Sat, 05 July 2014, 17:53:00 »
Razor or vice?
« Reply #33 on: Sat, 05 July 2014, 17:58:12 »
Razor or vice?
Vice.. of course..  I don't even have a razor. i have exacto, but that's too dangerous.
Offline Elrick
  • Hype Master
« Reply #34 on: Mon, 07 July 2014, 04:11:01 »
Razor or vice?
Beautiful, nothing better than using a Vice & Hammer to remove THEIR foul cooking top :thumb: .
I removed mine off the E3-1270 v3 and it's sitting comfortably at around 25C.
« Reply #35 on: Mon, 07 July 2014, 13:11:07 »
Razor or vice?
does the e3 1270 overclock on bclk?
Offline paicrai
  • mindblank
« Reply #36 on: Mon, 07 July 2014, 15:21:53 »
Razor or vice?
why'd you want something from 744 years ago
THE FEMINIST ILLUMINATI
Offline Badwrench
« Reply #37 on: Thu, 17 July 2014, 00:38:43 »
Thought you might like this one TP - Pentium G3258 @6277MHz  :thumb:
http://hwbot.org/submission/2583371_dhenzjhen_hwbot_prime_pentium_g3258_5000.3_pps
Offline Badwrench
« Reply #39 on: Thu, 17 July 2014, 00:53:13 »
sure makes my 4.6 g3258 look like  a piece of crapp ..
What did you end up getting yours stable at?
« Reply #40 on: Thu, 17 July 2014, 00:56:56 »
I need 1.365v to get it stable at 4.8ghz, 1.4v with the 2400mhz ram...
I need 1.27v to get it stable at 4.6ghz,  1.29v with the 2400mhz ram
given those options, I decided to drop to 4.6 for long time use..
