Author Topic: The Living Joke Thread  (Read 3949 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Mon, 11 August 2014, 03:16:20 »
Post your favorite jokes.  Let's try to keep this thread semi clean.
Subject: Technical Support
18 months ago I upgraded to Girlfriend 1.0 from DrinkMates 4.2, which I had used for many years without any trouble.
However, there are apparently conflicts between these two products and the only solution was to try and run Girlfriend 1.0 with the sound turned off. To make matters worse, Girlfriend 1.0 is incompatible with several other applications,such as LadsNightOut 3.1, Football 4.5, and Playboy 6.9. Successive versions of Girlfriend proved no better.
I tried a shareware program, Slapper 2.1, but it had too many bugs and left a virus in my system, forcing me to shut down completely for several weeks. Eventually, I tried to run Girlfriend 1.2 and Girlfriend 1.0 at the same time,only to discover that when these two systems detected each other they caused severe damage to my hardware.
I eventually upgraded to Fiancée 1.0, only to discover that this product soon had to be upgraded further to Wife 1.0. While Wife 1.0 tends to use up all my available resources,it does come bundled with FreeSexPlus and Cleanhouse 2007.
Shortly after this upgrade,however I found that Wife 1.0 could be very unstable and costly to run. Any mistakes I made were automatically stored in Wife 1.0's memory and could not be deleted. They then resurfaced months later when I had forgotten about them. Wife 1.0 also had an automatic diary, Explorer and E-mail filter, and can, without warning, launch TurboStrop and Multi-Whinge. These latter products have no Help files, and I have to try to guess what the problem is.
Additional problems are that Wife 1.0 needs updating regularly, requiring ShoeShopBrowser for new attachments and Hairstyle Express which needs to be reinstalled every other week. Also, when Wife 1.0 attaches itself to my Saab 93 Convertible hard drive, it often crashes.
Wife 1.0 also comes with an irritating pop-up called MotherinLaw, which can't be turned off. Recently I've been tempted to install Mistress 2011, but there could be problems. A friend of mine has alerted me to the fact that if Wife 1.0 detects Mistress 2011, it tends to delete all your Money before uninstalling itself.
Offline paicrai
  • mindblank
Re: The Living Joke Thread
« Reply #1 on: Wed, 13 August 2014, 10:46:04 »
so none of my dark jokes? well, only the1onewolf knows what im talking about here
THE FEMINIST ILLUMINATI
« Reply #2 on: Wed, 13 August 2014, 10:55:38 »
Knock Knock
Who's There?
Boo.
Boo Who?
Why you crying?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Wed, 13 August 2014, 10:57:32 »
Knock knock.
Who's there?
Orange.
Orange who?
Orange you glad I didn't say Spamray?
 :p
« Reply #4 on: Wed, 13 August 2014, 10:59:04 »
Knock knock.
Who's there?
Orange.
Orange who?
 :p
Offline paicrai
  • mindblank
« Reply #5 on: Wed, 13 August 2014, 11:07:29 »
the entire joke is hidden for a reason, you know what you're in for
i'm getting real tired of the "statistically, 9 out of 10 people enjoy gangrape" joke now
i'd say it's 8 out of 10, her dad must be feeling guilty by now
« Reply #6 on: Wed, 13 August 2014, 12:42:05 »
Here is an iteration of the OP joke that went around in 2005:
Dear Tech Support:
Last year I upgraded from Girlfriend 7.0 to Wife 1.0 I soon noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. In addition, Wife 1.0 installed itself into all other programs and now monitors all other system activity. Applications such as Poker Night 10.3, Football 5.0, Hunting and Fishing 7.5, and Racing 3.6. I can't seem to keep Wife 1.0 in the background while attempting to run my favorite applications. I'm thinking about going back to Girlfriend 7.0, but the uninstall doesn't work on Wife 1.0. Please help!
Thanks,
Troubled User
REPLY:
Dear Troubled User:
This is a very common problem that men complain about.
Many people upgrade from Girlfriend 7.0 to Wife 1.0, thinking that it is just a Utilities and Entertainment program. Wife 1.0 is an OPERATING SYSTEM and is designed by its Creator to run EVERYTHING!!! It is also impossible to delete Wife 1.0 and to return to Girlfriend 7.0. It is impossible to uninstall, or purge the program files from the system once installed. You cannot go back to Girlfriend 7.0 because Wife 1.0 is designed to not allow this. Look in your Wife 1.0 manual under Warnings-Alimony-Child Support.
I recommend that you keep Wife 1.0 and work on improving the situation. I suggest installing the background application "Yes Dear" to alleviate software augmentation.
The best course of action is to enter the command C:\APOLOGIZE because ultimately you will have to give the APOLOGIZE command before the system will return to normal anyway.
Wife 1.0 is a great program, but it tends to be very high maintenance. Wife 1.0 comes with several support programs, such as Clean and Sweep 3.0, Cook It 1.5 and Do Bills 4.2. However, be very careful how you use these programs. Improper use will cause the system to launch the program Nag Nag 9.5. Once this happens, the only way to improve the performance of Wife 1.0 is to purchase additional software. I recommend Flowers 2.1 and Diamonds 5.0 !
WARNING!!! DO NOT, under any circumstances, install Secretary With Short Skirt 3.3. This application is not supported by Wife 1.0 and will cause irreversible damage to the operating system.
Best of luck,
Tech Support
- D Trump 2026-10-24
« Reply #7 on: Wed, 13 August 2014, 12:44:23 »
Not exactly "jokes" but funny anyway:
Famous Predictions...by "Experts"
"Everything that can be invented has been invented."
           - Charles H. Duell, Office of Patents, 1899
"There will never be a bigger plane built."
- A Boeing engineer, after the first flight of the 247, a twin engine plane that carried ten people.
"Ours has been the first, and doubtless to be the last, to visit this profitless locality."
           - Lt. Joseph Ives after visiting the Grand Canyon in 1861.
"There is not the slightest indication that nuclear energy will ever be obtainable. It would mean that the atom would have to be shattered at will."
           - Albert Einstein, 1932
"We don't like their sound. Groups of guitars are on the way out."
           - Decca executive, 1962, after turning down the Beatles.
"It will be years- not in my time- before a woman will become Prime Minister."
           - Margaret Thatcher, 1974
"With over 50 foreign cars already on sale here, the Japanese auto industry isn't likely to carve out a big slice of the US market."
           - Business Week, August 2, 1968
"Computers may weigh no more than 1.5 tons."
           - Popular Mechanics, 1949
"There is no reason anyone would want a computer in their home."
           - Ken Olson, president of Digital Equipment Corp. 1977
"This telephone' has too many shortcomings to be seriously considered as a means of communication."
           - Western Union memo, 1876
"No imaginable commercial value. Who would pay for a message sent to nobody in particular?"
- David Sarnoff's associates in response to his urging investment in the radio in the 1920's.
"Who wants to hear actors talk?"
           - H.M. Warner, Warner Brothers, 1927.
"I'm just glad it'll be Clark Gable who's falling on his face and not Gary Cooper."
- Gary Cooper, after turning down the lead role in Gone With The Wind.
"Market research reports say America likes crispy cookies, not soft and chewy cookies like you make."
           - Response to Debbi Fields' idea of Mrs. Fields' Cookies
"We don't need you. You haven't got through college yet."
- Hewlett Packard excuse to Steve Jobs, who founded Apple Computers instead.
"I think there's a world market for about five computers."
           - Thomas J. Watson, chairman of the board of IBM.
"The bomb will never go off. I speak as an expert in explosives."
           - Admiral William Leahy, U.S. Atomic Bomb Project.
"Airplanes are interesting toys, but they are of no military value whatsoever."
- Marechal Ferdinand Fock, Professor of Strategy, Ecole Superieure de Guerre
"Stocks have reached a permanently high plateau."
           - Irving Fisher, Professor of Economics, Yale University, 1929
"No matter what happens, the U.S. Navy is not going to be caught napping."
           - U.S. Secretary of Navy, December 4, 1941
"While theoretically and technically television may be feasible, commercially and financially it is an impossibility."
           - Lee DeForest, inventor
"Radio has no future. Heavier-than-air flying machines are impossible. X-rays will prove to be a hoax."
           - William Thomson, Lord Kelvin English scientist, 1899
« Reply #8 on: Wed, 13 August 2014, 12:48:09 »
Blonde GUY Joke!
Blonde guy gets home early from work and hears strange noises coming from the bedroom. He rushes upstairs to find his wife naked on the bed, sweating and panting. "What's up?" he says. "I'm having a heart attack," cries the woman.
He rushes downstairs to grab the phone, but just as he's dialing, his 4-year-old son comes up and says: "Daddy! Daddy! Uncle Ted's hiding in your closet and he's got no clothes on!"
The guy slams the phone down and storms upstairs into the bedroom, past his screaming wife, and rips open the wardrobe door. Sure enough, there is his brother, totally naked, cowering on the closet floor. "You rotten bastard," says the husband, "my wife's having a heart attack and you're running around naked scaring the kids!"
and one of my favorites:
« Last Edit: Wed, 13 August 2014, 19:51:33 by fohat.digs »
« Reply #9 on: Wed, 13 August 2014, 13:04:09 »
Below is a copy of a letter that won a competition in UK as complaint letter of the year...have a laugh and
read on.
Complaint Letter of the Year. The British do have a way with words.... A real-life customer complaint
letter sent to NTL (to their complaints dept....)
Dear Cretins,
I have been an NTL customer since 9th July 2001, when I signed up for your 3-in-one deal for cable TV, cable modem, and telephone. During this three-month period I have encountered inadequacy of service which I had not previously considered possible, as well as ignorance and stupidity of monolithic proportions. Please allow me to provide specific details,so that you can either pursue your professional perogative, and seek to rectify these difficulties - or more likely (I suspect) so that you can have some entertaining reading material as you while away the working day smoking B&H and drinking vendor-coffee on the bog in your office: My initial installation was cancelled without warning, resulting in my spending an entire Saturday sitting on my fat arse waiting for your technician to arrive. When he did not arrive, I spent a further 57 minutes listening to your infuriating hold music, and the even more annoying Scottish robot woman telling me to look at your helpful website....HOW?
I alleviated the boredom by playing with my testicles for a few minutes an activity at which you are no-doubt both familiar and highly adept. The rescheduled installation then took place some two weeks later, although the technician did forget to bring a number of vital tools such as a drill-bit, and his cerebrum. Two weeks later, my cable modem had still not arrived. After 15 telephone calls over 4 weeks my modem arrived... six weeks after I had requested it, and begun to pay for it. I estimate your internet server's downtime is roughly 35%... hours between about 6pm -midnight, Mon-Fri, and most of the weekend. I am still waiting for my telephone connection. I have made 9 calls on my mobile to your no-help line, and have been unhelpfully transferred to a variety of disinterested individuals, who are it seems also highly skilled bollock jugglers.
I have been informed that a telephone line is available (and someone will call me back); that no telephone line is available (and someone will call me back); that I will be transferred to someone who knows
whether or not a telephone line is available (and then been cut off); that I will be transferred to someone (and then been redirected to an answer machine informing me that your office is closed); that I will be transferred to someone and then been redirected to the irritating Scottish robot woman...and several other variations on this theme. Doubtless you are no longer reading this letter, as you have at least a thousand other dissatisfied customers to ignore, and also another one of those crucially important testicle-moments to attend to. Frankly I don't care, it's far more satisfying as a customer to voice my frustration's in print than to shout them at your unending hold music. Forgive me, therefore, if I continue.
I thought BT were ****, that they had attained the holy piss-pot of godawful customer relations, that no-one, anywhere, ever, could be more disinterested, less helpful or more obstructive to delivering service to their customers. That's why I chose NTL, and because, well, there isn't anyone else is there? How surprised I therefore was, when I discovered to my considerable dissatisfaction and disappointment what a useless shower of bastards you truly are. You are sputum-filled pieces of distended rectum incompetents of the highest order. British Telecom - wankers though they are - shine like brilliant beacons of success, in the filthy puss-filled mire of your seemingly limitless inadequacy. Suffice to say that I have now given up on my futile and foolhardy quest to receive any kind of service from you. I suggest that you cease any potential future attempts to extort payment from me for the services which you have so pointedly and catastrophically failed to deliver - any such activity will be greeted initially with hilarity and disbelief quickly be replaced by derision, and even perhaps bemused rage. I enclose two small deposits, selected with great care from my cats litter tray, as an expression of my utter and complete contempt for both you and your pointless company. I sincerely hope that they have not become desiccated during transit - they were satisfyingly moist at the time of posting, and I would feel considerable disappointment if you did not experience both their rich aroma and delicate texture. Consider them the very embodiment of my feelings towards NTL, and its worthless employees.
Have a nice day - may it be the last in you miserable short life, you irritatingly incompetent and infuriatingly unhelpful bunch of twats.
John
« Reply #10 on: Wed, 13 August 2014, 19:05:17 »
The awesome power of a wife's love:
A very old man lay dying in his bed. In death's doorway, he suddenly smelled the aroma of his favorite chocolate chip cookies drifting up the stairs.
He gathered his remaining strength and lifted himself from the bed. Leaning against the wall, he slowly made his way out of the bedroom, and with even greater effort forced himself down the stairs, gripping the railing with both hands.
With labored breath, he leaned against the door frame, gazing into the kitchen. Were it not for death's agony, he would have thought himself already in heaven. There, spread out up on newspapers on the kitchen table were literally dozens of his favorite chocolate chip cookies.
Was this heaven, or was it one final act of heroic love from his devoted wife, seeing to it that he left this world a happy man?
Mustering one great final effort, he threw himself toward the table. The aged and withered hand, shaking, made its way to a cookie at the edge of the table, when he was suddenly smacked on the knuckles with a spatula by his wife.
"Stay out of those," she said. "They're for the funeral.”
« Reply #11 on: Wed, 13 August 2014, 19:38:16 »
TOP TEN LIES HEARD BY SERVICE ENGINEERS
1.   The company appreciates all of the long hours you put in.
2.   We'll get you an answer today.
3.   It's always run that way.
4.   You're the only one we have who can do this work.
5.   If we paid you for overtime, you would be less of a professional.
6.   We'll have the equipment ready for you when you get here.
7.   Our operators and mechanics will get you anything that you ask for.
8.   If we can just fix it well enough to get by for a year, we'll do a major rebuild.
9.   We don't know why the equipment broke down.
10.   It has been tested at the factory.
TOP TEN LIES TOLD BY SERVICE ENGINEERS
1.   It will take a minimum of eight hours.
2.   I'll send a final report within a week.
3.   I've never worked on one of these before.
4.   I lost the receipt.
5.   None of our other customers have this problem.
6.   I had to rent the big car because they were out of little ones.
7.   I had to drive all day.
8.   That's the way it's supposed to operate, there's nothing wrong with it.
9.   That was the way I received the equipment
10.   I worked through lunch.
Offline paicrai
  • mindblank
« Reply #12 on: Thu, 14 August 2014, 01:14:59 »
a steak pun is a rare medium well done
Offline bazh
« Reply #13 on: Thu, 14 August 2014, 02:19:18 »
A joke I've just known lately
Though I don't know how in the hell a chicken could do a "bach" sound :/ (that's my name too :p)
HHKB Pro2 white
Newbie again
« Reply #14 on: Thu, 14 August 2014, 02:34:33 »
Yea, chickens have no lips.. it's impossible to make B sound without lips I think.
I've always thought it'd be similar to a  Urrruugh... sound...
« Reply #15 on: Fri, 15 August 2014, 17:19:13 »
Come on guys, jump on the bandwagon.
My favorite is # 21
« Reply #16 on: Fri, 15 August 2014, 21:12:56 »
The History of the World - according to students
The inhabitants of Egypt were called mummies. They lived in the Sarah Dessert and traveled by Camelot. The climate of the Sarah is such that the inhabitants have to live elsewhere, so certain areas of the dessert are cultivated by irritation. The Egyptians built the Pyramids in the shape of huge triangular cube. The Pyramids are a range of mountains between France and Spain.
The Bible is full of interesting caricatures. In the first book of the Bible, Guinesses, Adam and Eve were created from an apple tree. One of their children, Cain, asked "Am I my brother's son?" God asked Abraham to sacrifice Issac on Mount Montezuma. Jacob, son of Issac, stole his brother's birthmark. Jacob was a partiarch who brought up his twelve sons to be partiarch, but they did not take to it. One of Jacob's sons, Joseph, gave refuse to the Israelites.
Pharao forced the Hebrew slaves to make bread without straw. Moses led them to the Red Sea, where they made unleavened bread, which is bread made without any ingredients. Afterwards, Moses went up on Mount Cyanide to get the ten commandments. David was a Hebrew king skilled at playing the liar. He fought with the Philatelists, a race of people who lived in Biblical times. Solomon, one of David's sons, had 500 wives and 500 porcupines.
Without the Greeks, we wouldn't have history. The Greeks invented three kinds of columns - Corinthian, Doric and Ironic. They also had myths. A myth is a female moth. One myth says that the mother of Achilles dipped him in the River Stynx until he became intolerable. Achilles appears in "The Illiad", by Homer. Homer also wrote the "Oddity", in which Penelope was the last hardship that Ulysses endured on his journey. Acutally, Homer was not written by Homer but by another man of that name.
Socrates was a famous Greek teacher who went around giving people advice. They killed him. Socrates died from an overdose of wedlock.
In the Olympic Games, Greeks ran races, jumped, hurled the biscuits, and threw the java. The reward to the visitor was a coral wreath. The government of Athen was democratic because the people took the law into their onwn hands. There were no wars in Greece, as the mountains were so high that they couldn't climb over to see what their neighbors were doing. When they fought the Parisians, the Greek were outnumbered because the Persians had more men.
Eventually, the Ramons conquered the Geeks. History call people Romans because they never stayed in one place for very long. At Roman banquets, the guestes wore garlic in their hair. Julius Caesar extinguished himself on the battlefields of Gaul. The Ides of March killed him because they thought the was going to be made king. Nero was a cruel tyrany who would torture his poor subjects by playing the fiddle to them.
Then came the Middle Ages. King Alfred conquered the Dames, King Arthur lived in the Age of Shivery, King Harlos mustarded his troops before the Battle of Hastings, Joan of Arc was cannonized by George Bernard Shaw, and the victims of the Black Death grew boobs on their necks. Finally, the Magna Carta provided that no free man should be hanged twice for the same offense.
In medevil times most of the people were alliterate. The greatest writer of the time was Chaucer, who wrote many poems and verse and also wrote literature. Another tale of William Tell, who shot an arrow through an apple while standing on his son's head.
The Renaissance was an age in which more individuals felt the value of their human being. Martin Luther was nailed to the church door at Wittenberg for selling papal indulgences. He died a horrible death, being excommunicated by a bull. It was the painter Donatello's interest in the female nude that made him the father of the Renaissance. It was an age of great inventions and discoveries. Gutenberg invented the Bible. Sir Walter Raleigh is a historical figure because he invented cigarettes. Another important invention was the circulation of blood. Sir Francis Drake circumcised the world with a 100-foot clipper.
The government of England was a limited mockery. Henry VIII found walking difficult because he had an abbess on his knee. Queen Elizabeth was the "Virgin Queen". As a queen she was a success. When Elizabeth exposed herself before her troops, they all shouted "hurrah". Then her navy went out and defeated the Spanish Armadillo.
The greatest writer of the Renaissance was William Shakespear. Shakespear never made much money and is famous only because of his plays. He lived in Windsor with his merry wives, writing tragedies, comedies and errors. In one of Shakespear's famous plays, Hamlet rations out his situation by relieving himself in a long soliloquy. In another, Lady Macbeth tries to convince Macbeth to kill the King by attacking his manhood. Romeo and Juliet are an example of a heroic couplet. Writing at the same time as Shakespear was Milton. Milton wrote "Paradise Lost". Then his wife died and he wrote "Paradise Regained".
During the Renaissance America began. Christopher Columbus was a great navigator who discoverd America while cursing about the Atlantic. His ships were called the Nina, the Pinta and the Santa Fe. Later the Pilgrims crossed the Ocean, and that was called the Pilgrim's Progress. When they landed at Plymouth Rock, they were greeted by Indians, who came down the hill rolling their was hoops before them. The Indian squabs carried their cabooses, which proved very fatal to them. The winter of 1620 was a hard one for the setters. Many people died and many babies were born. Captain John Smith was responsible for all this.
One of the causes of the Revolutionary Wars was the English put tacks in their tea. Also, the colonists would send their pacels through the post without stamps. During the War, Red Coats and Raul Revere was throwing balls over stone walls. The dogs were barking and the peacocks crowing. Finally, the colonists won the War and no longer had to pay for taxis.
Delegates from the original thirteen states formed the Contented Congress. Thomas Jefferson, a Virgin, and Benjamin Franklin were two singers of the Declaration of Independence. Franklin had gone to Boston carrying all his clothes in his pocket and a loaf of bread under each arm. He invented electricity by rubbing cats backwards and declared "a horse divided against itself cannot stand". Franklin died in 1790 and is still dead.
George Washington married Matha Curtis and in due time became the Father of Our Country. Then the Constitution of the United States was adopted to secure domestic hostility. Under the Constitution the people enjoyed the right to keep bare arms.
Abraham Lincoln became America's greatest Precedent. Lincoln's mother died in infancy, and he was born in a log cabin which he built with his own hands. When Lincoln was President, he wore only a tall silk hat. He said, "In onion there is strength". Abraham Lincoln write the Gettysburg address while traveling from Washington to Gettysburg n the back of an envelope. he also signed the Emasculation Proclamation, and the Fourteenth Admendment gave the ex-Negroes citizenship. But the Clue Clux Clan would torcher and lynch the ex-Negroes and other innocent victims. On the night of April 13, 1965, Lincoln went to the theater and got shot in his seat bye one of the actors in a moving picture show. The believed assinator was John Wilkes Booth, a supposedly insane actor. This ruined Booth's career.
Meanwhile in Europe, the enlightenment was a reasonable time. Voltare invented electricity and also wrote a book called "Candy". Gravity was invented bye Issac Walton. Is is chiefly noticeable in the Autumn, when the apples are falling off the trees.
Back was the most famous composes in the world, and so was Handel. Handel was half German, half Italian and half English. He was very large. Bach died from 1750 to the present. Beethoven wrote music even though he was deaf. He was so deaf he wrote loud music. He took long walks in the forest even when everyone was calling for him. Beethoven expired in 1827 and later died for this.
France was in a very serious state. The Frenche Revolution was accomplished before it happend. The Marseillaise was the theme of the French Revolution, and it catapulted into Napoleon. During the Napoleonic Wars, the crowned heads of Europe were trembling in their shoes. Then the Spanish gorillas came down from the hills and nipped at Napoleon's flanks. Napoleon became ill with bladder problems and was very tense and unrestrained. he wanted an heir to inherit his power, but since Josephine was a baroness, she couldn't bear him any children.
The sun never set on the British Empire because the British Empire is in the East and the sun sets in the West. Queen Victoria was the longest queen. She sat on a thorn for 63 years. Her reclining years and finally the end of her life were exemplatory of a great personality. Her death was the final event which ended her reign.
The nineteenth century was a time of many great inventions and thoughts. The invention of the steamboat caused a network of rivers to spring up. Cyrus McCormick invented the McCormick Raper, which did the work of a hundred men. Samuel Morse invented a code for telepathy. Louis Pastuer discovered a cure for rabbis. Charles Darwin was a naturalist who wrote the "Organ of the Species". Madman Curie discovered radium. And Karl Marx became one of the Marx Brothers.
The First World War, caused by the assignation of the Arch-Duck by a surf, ushered in a new error in the anals of human history.
Offline PointyFox
« Reply #17 on: Fri, 15 August 2014, 21:31:42 »
Jesus, Mary and Christ that was bad ;P
« Reply #18 on: Fri, 15 August 2014, 23:16:52 »
Here's one I invented during a recent pilgrimage to iKea (my first!)
We were looking through the Kitchens just before lunch, and got one of these to buy:
My immediate instinct was to get a second, so we could tape them together. That way we could take two cherries and pit them against each other!
Offline paicrai
  • mindblank
« Reply #19 on: Sat, 16 August 2014, 04:30:24 »
assassin's creed provides better history education than these kids got
« Reply #20 on: Sat, 16 August 2014, 19:00:28 »
Gosh, thanks. I knew less than half of this!
Were Voltaire and Benjamin Franklin working together when they invented electricity?
