Author Topic: Fattie sweat trick!!  (Read 2712 times)
« on: Wed, 13 August 2014, 09:43:28 »
I found this out just now..
Workout really hard 20-30mins right before taking a shower @ night....
Really break a sweat..
Drink some water..
Then go take your normal hot shower...  You won't sweat at all afterwards...  because transitionally,  it is still much cooler than when you were working out..
  • Live long and prosper
Re: Fattie sweat trick!!
« Reply #1 on: Wed, 13 August 2014, 09:44:43 »
I saw the term "fattie" and immediately thought something completely different...
tp thread is tp thread
Offline osi
« Reply #2 on: Wed, 13 August 2014, 09:46:20 »
This is interesting. I'll give this a try if I think about it. Nothing worse than the lingering sweat of game/work out follow you out of the shower
« Reply #3 on: Wed, 13 August 2014, 15:43:14 »
It's the same principle as when if you just got out of the desert, and into a house that's 98*,  but because the desert was 120* , you're body will be like.. OMG I gotz Air-C0nditioning. stop sweating NOW..
« Reply #4 on: Wed, 13 August 2014, 15:53:19 »
Or.... I'll just keep not working out.
« Reply #5 on: Wed, 13 August 2014, 19:19:14 »
The point is, you remember this for when you're stuck in an ever-hot environment..   otherwise.. it's non-stop sweating  EVEN after showering..
Offline keymaster
  • Topre Revolution Theorist
« Reply #6 on: Wed, 13 August 2014, 19:27:34 »
Just turn on the A/C before you shower and you're good to go.
Offline jameslr
« Reply #7 on: Wed, 13 August 2014, 21:34:27 »
Go green and take a cold shower
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
« Reply #8 on: Wed, 13 August 2014, 22:26:00 »
No, do not do this..  I tried this...  As soon as you leave the cool water... You break out in Epic sweat.. because the external temp is significantly higher...
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #9 on: Wed, 13 August 2014, 22:51:12 »
Go green and just don't shower.
« Reply #10 on: Wed, 13 August 2014, 23:41:10 »
It's kinda hard... because at a certain point.. your own filth begins to bother you-yourself...
For me.. this is about 3 days..  If I don't shower in 3 days, I feel a bit sick and sluggish..
I must brush my teeth in the morning... I could do with missing nights,  but I must brush in the morning...
