Author Topic: Lightsaber?  (Read 4881 times)
Offline Dr.Chipotle
Lightsaber?
« on: Mon, 25 August 2014, 10:58:23 »
So i want to build a custom lightsaber, but dont know what to do with LED's and sound boards? somone out there wanna help?
Re: Lightsaber?
« Reply #1 on: Mon, 25 August 2014, 11:02:55 »
I bet there are other forums better suited for that.
Re: Lightsaber?
« Reply #2 on: Mon, 25 August 2014, 18:37:58 »
You'll need Kaliburr crystals and an intimate knowledge of the force.
Offline YoungMichael88
  • HHKB Wannabe
Re: Lightsaber?
« Reply #3 on: Mon, 25 August 2014, 18:39:21 »
^This
Re: Lightsaber?
« Reply #4 on: Mon, 25 August 2014, 19:21:10 »
Re: Lightsaber?
« Reply #5 on: Mon, 25 August 2014, 20:47:24 »
http://edition.cnn.com/2013/09/26/us/new-lightsaber-molecule/
I've settled for a sawed off broom handle + imagination + wh0zzeuuummm sound effects made personally by moi.
Budget way ftw..
Re: Lightsaber?
« Reply #6 on: Mon, 25 August 2014, 20:56:02 »
tp4, is that you?
Re: Lightsaber?
« Reply #7 on: Mon, 25 August 2014, 20:58:56 »
I can smell your mom's lightsaber...
Re: Lightsaber?
« Reply #8 on: Tue, 26 August 2014, 01:41:00 »
The worst thing about the "Star Wars Kid" video, is that the whole episode inspired him to become a frakkin' lawyer ...
It is hard to find transfer to Ilum and back.
I suggest The Custom Saber Shop. They have got all supplies you would need. The different "Modular Hilt System" parts just screw together. There is also a forum with lots of info about building and posts of custom designs. Mind you, I have not been active there for several years.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Re: Lightsaber?
« Reply #9 on: Tue, 26 August 2014, 04:30:53 »
**** off chiptole.
A real doctor uses a sonic screwdriver or medical tricorder.
Re: Lightsaber?
« Reply #10 on: Tue, 26 August 2014, 07:33:29 »
tp4, is that you?
I never achieved such p00f-ness..  and I don't look into the camera like that while I do play pretend lightsabers.
Offline The Mad Professor
  • Ex Scientia, Rabies
Re: Lightsaber?
« Reply #11 on: Wed, 27 August 2014, 22:57:32 »
FX-Sabers
Saberforum
Those three sites will have all the info you need.
Mad Science means never stopping to ask "What's the worst that could happen?" - Schlock Mercenary
Offline Dr.Chipotle
Re: Lightsaber?
« Reply #12 on: Thu, 28 August 2014, 13:30:07 »
FX-Sabers
Saberforum
thanks.
Offline Oobly
Re: Lightsaber?
« Reply #13 on: Fri, 29 August 2014, 03:36:06 »
You need a few things:
1. Power source.
2. Power controller.
3. Power crystal.
4. Focus crystal.
5. Cooling and case materials.
6. A button. Very important, this one is.
7. To exist long, long ago in a galaxy far away and have had enough Jedi training to construct your own lightsaber.
And hey presto, custom lightsaber.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline absyrd
  • CPT HYPE PADAWAN
Re: Lightsaber?
« Reply #14 on: Sat, 30 August 2014, 06:09:33 »
Re: Lightsaber?
« Reply #15 on: Sat, 30 August 2014, 06:57:40 »
1. Power source.
3. Power crystal.
4. Focus crystal.
This brings up a good question...  How many watts is a lightsaber...
I'm thinking peak output, probably ~1 Megawatt.. since a basic plasma cutter with no beam formation is already 10Kw..
Re: Lightsaber?
« Reply #16 on: Sat, 30 August 2014, 17:15:48 »
The in-universe saying is that a lightsaber does not expend that much energy unless it is actually cutting ... but everything is relative.  :rolleyes:
The earliest lightsabers used a separate belt-mounted power pack. Later ones used a "nucleonic pill" as power source.
As safety features, the insides of a lightsaber has a mirror surface to reflect stray energy back into the lightsaber's mechanism to make it destroy itself on malfunction before it destroys something else. The casing and emitter shroud / parry plate is often made from a cortosis alloy - cortosis being the only metal known to absorb lightsaber energy instead of being cut by it. It is, however, incredibly rare on Earth.
Back in the Sith Wars, a millenium before the Galactic CIvil War, cortosis was mined on far-away asteroids at a great cost, both in funds and in lives.
« Last Edit: Sat, 30 August 2014, 17:18:28 by Findecanor »
Offline smarmar
  • It don't mean a thing if it ain't got that swing
    • Short Stories from an Old Library
Re: Lightsaber?
« Reply #17 on: Wed, 01 October 2014, 22:09:41 »
I think many of the crystal mines were choked with fill dirt to make way for the new Galactic Highway cutting through the outer rim. Or so tales be told...
1992 IBM Model M | Tesoro Durandal[Browns] | Hi-Tek Series 725[Space Invaders] | Tandy Enhanced[Sliders] | Dell Quiet Keys | Mitsumi[AT]
