Author Topic: Recruiting for scrub CS:GO team  (Read 285528 times)
Re: Recruiting for scrub CS:GO team
« Reply #1100 on: Wed, 04 May 2016, 14:09:27 »
whichever one gives u higher framerate ofc
I'm trying to decide which one gives a more clear image of the enemy..
but perhaps the situations where that helps are too rare to justify the lower framerate.
Offline clacktalk
  • circa 2015
« Reply #1101 on: Wed, 04 May 2016, 14:19:55 »
what's most important besides gun control is being able to control brightness. the rest is preference and not as relevant
diary of a clacktalk
radio_killah: too much frank
« Reply #1102 on: Wed, 04 May 2016, 14:21:07 »
brightness and contrast and digital vibrance (I've heard)..
but I'm on ATI, so I don't have digital vibrance setting..
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #1103 on: Wed, 04 May 2016, 14:37:29 »
You can do the same thing on ATI cards thankfully enough.
http://vibrancegui.com/
AMD has a saturation option that works the same as Nvidias digital vibrance.
Offline clacktalk
  • circa 2015
« Reply #1104 on: Wed, 04 May 2016, 14:56:20 »
propropro
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1105 on: Wed, 04 May 2016, 15:18:09 »
brazil is good at csgo? wut u smoking? hue jk inb4 racist
Offline KatzenKinder
« Reply #1106 on: Wed, 04 May 2016, 15:20:29 »
racist
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1108 on: Wed, 04 May 2016, 15:38:35 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #1109 on: Wed, 04 May 2016, 15:42:12 »
tfw SA still better than NA
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1110 on: Wed, 04 May 2016, 15:48:20 »
I'm not racist my tv is colored.
I don't have a tv OnO
I also have 4 black tires...
where da face at?
Offline HPE1000
  • Keycap Paparazzo
« Reply #1111 on: Wed, 04 May 2016, 16:25:27 »
Offline clacktalk
  • circa 2015
« Reply #1112 on: Wed, 04 May 2016, 16:28:08 »
vesper u big ole b
smurf up my games so i can reach dmg for once ****
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #1113 on: Wed, 04 May 2016, 16:32:25 »
vesper u big ole b
we should sometime. i haven't played in foreverrrr. i feel bad bc i always turn down the late games these days T_T I LOVE YOU MUNCH AND SLICKMAMBA.
« Reply #1114 on: Wed, 04 May 2016, 16:45:18 »
Seems like digital vibrance isn't the same as saturation on ATI cards.
Vibrance does not overblow the already saturated colors..
Whereas on ATI, if you crank the saturation it influences ALL of the colors..
Sigh............ My computer is the Suck...
Offline bcredbottle
« Reply #1115 on: Fri, 06 May 2016, 15:22:39 »
You guys are ****s. I sent out like 20 friend requests on Steam and no one added me back.
Offline drewba
« Reply #1116 on: Fri, 06 May 2016, 15:29:25 »
I'm 99% sure you and I are already friends, but I don't recall playing together. Maybe our ranks are way off? I'm MG1
Offline clacktalk
  • circa 2015
« Reply #1117 on: Fri, 06 May 2016, 16:12:38 »
what the **** you added me this morning or some **** what do u want from me
« Reply #1118 on: Fri, 06 May 2016, 17:43:35 »
u didnt add the kommander
Offline appleonama
  • Trollo en USA
« Reply #1119 on: Fri, 06 May 2016, 18:02:04 »
**** this game im ****ing garbage.
Offline slickmamba
« Reply #1120 on: Fri, 06 May 2016, 18:13:13 »
why are we talking and not playing?
Hi :)
Offline bcredbottle
« Reply #1121 on: Fri, 06 May 2016, 18:47:56 »
whats your username???
Offline Air tree
« Reply #1122 on: Fri, 06 May 2016, 18:52:14 »
I'm gonna jump on in like 10 minutes... Steam name is the same as my user name on here...I'm only silver elite right now, though...
Offline slickmamba
« Reply #1123 on: Fri, 06 May 2016, 19:17:29 »
you can play with clacktalk, hes great
Hi :)
Offline clacktalk
  • circa 2015
« Reply #1124 on: Sun, 08 May 2016, 04:23:56 »
1v1 headshots only how dare u
Offline Venatorious
  • Gotta Start Somewhere
« Reply #1125 on: Mon, 09 May 2016, 14:39:03 »
Tfw you get hacked bcuz you took the bait and don't want anything to do with cs anymore
Sent from my ONE E1005 using Tapatalk
« Reply #1126 on: Fri, 10 June 2016, 08:50:57 »
heya..
Is the consensus to Cap fps or not to cap..
I am using raw input 1
Offline nugglets
« Reply #1127 on: Fri, 10 June 2016, 09:23:48 »
heya..
Depends on your setup, honestly. Refresh rate, average fps, how often it dips and how low, etc.
There are instances where you should cap it under the default, some instances when you should cap it over the default, but exactly zero instances where you should set it to 0.
Just to clarify, instead of setting it to 0 set it to 999. Anything over that and the engine starts to lag terribly. This basically only every happens in kz/surf maps, but also during server loading which can cause lag spikes joining servers.
« Last Edit: Fri, 10 June 2016, 09:34:31 by nugglets »
« Reply #1128 on: Fri, 10 June 2016, 10:34:54 »
heya..
Hrrrmm wouldn't 998 be safer than ?
Offline Bigpock
« Reply #1129 on: Fri, 10 June 2016, 10:36:26 »
I was under the impression you cap to 144 fps when u play on a 144hz monitor
« Reply #1130 on: Fri, 10 June 2016, 10:40:12 »
I dont' have a 144hz monitor,
But from what I can tell Capping frames lowers minimum fps as well.
Which is why I'm unsure what the setting should be..
« Reply #1131 on: Fri, 10 June 2016, 10:45:05 »
So, here's the weird oscillation I'm seeing, when the Frames are capped vs uncapped..
Uncapped
139414-0
Capped
139416-1
Offline nugglets
« Reply #1132 on: Fri, 10 June 2016, 11:04:06 »
This is widely circulated information, but it's incorrect for a couple of reasons.
For one, no one has perfected syncing refresh rate with FPS yet. So if you go 1:1 refresh:fps, the frames aren't synced and you can still end up with tearing and other issues. So you always want to add some frames to that equation, but I would only even roughly use this concept in single player games. If you can get enough FPS, you actually should go for double your refresh rate + some buffer frames.
The other reason is that your FPS is directly related to your input lag as well. So the higher the FPS, the more quickly movements register on your screen. Meaning that not only will your aim be more precise, but you will see enemy player movement earlier. We're talking about differences under 20ms, but I can personally notice an input lag difference of ~10ms the last time I tested it.
Offline nugglets
« Reply #1133 on: Fri, 10 June 2016, 11:07:14 »
Uncapped
Capped
Without seeing the actual numbers, the images alone are a bit hard to decipher.
That said, some people do report an increase in microstutter with fps caps. I haven't personally experienced this, but it's a relatively common complaint with any game using the Source engine.
If you set it to 999, it won't go over 998 =p
« Last Edit: Fri, 10 June 2016, 11:09:51 by nugglets »
« Reply #1134 on: Fri, 10 June 2016, 12:33:46 »
Ok these images should be more clear..
I'm not sure if the Fluctuation in the Capped Graph constitutes micro-stutter..
Capped 145FPS
139423-0
Capped   Fps max 999
139429-1
Uncapped   Fps max 0
139431-2
Offline nugglets
« Reply #1135 on: Sat, 11 June 2016, 00:11:27 »
Did you have frametimes checked when you ran these? I'd like to see those plots if you have them.
If not, mind running them again and uploading the frametime and fps charts for runs? Will give a much more complete picture.
Just from looking at what you posted, the 999 and 0 runs are close enough that the variance is almost assuredly the result of non-repeatable test conditions.
145 is definitely too low of a cap for you, though. That's well below your 1% and 0.1% rates on the other two runs, try 200-300 and see how it looks with the frametimes as well.
Realistically, for CS you want a minimum of 200fps. Anything below that is going to effect your input lag. That's the unofficial 'standard' competitive players have come to.
« Last Edit: Sat, 11 June 2016, 00:17:30 by nugglets »
« Reply #1136 on: Sat, 11 June 2016, 01:19:32 »
Looked into Frame times...
It would seem that  Uncap 0 vs Capped 350 has a difference of around 1ms for me..
So essentially, regardless of what I cap it to.. I get wider fluctuation and higher response time with the Cap.
Uncapped fps max 0
139466-0
Capped fps max 350
139468-1
Offline nugglets
« Reply #1137 on: Sat, 11 June 2016, 01:47:40 »
Ya, it definitely appears like the caps are having a negative effect on your frametime spikes and FPS.
Really not sure how to explain that, but it's present. That said, a 1-2ms difference is well below noticeable levels so as long as 999 isn't giving you the same spikes seen in the 350 plot I would personally stick with that. But it's up to you.
Again here, the number discrepancies themselves could easily just be due to the fact there is no benchmark for CSGO and so you are never going to be able to repeat the same exact video test twice. There will always be fluctuations.
But the number of spikes is the issue here, and it certainly seems to be related to the fps_max.
I wonder, have you tried limiting FPS through other means? Something like Nvidia Inspector or MSI Afterburner? I wonder if it would have the same results or if this is something buggy in the engine code.
« Last Edit: Sat, 11 June 2016, 01:52:07 by nugglets »
Offline ANightOnCloudNine
« Reply #1138 on: Sat, 11 June 2016, 18:46:31 »
I would join this cause i used to be pretty MLG  but my cancer has gotten in the way and I'm sure I suck now.
« Reply #1139 on: Sat, 11 June 2016, 19:15:09 »
nawhhh... u never forget how to ride a bike.
Offline HPE1000
  • Keycap Paparazzo
« Reply #1140 on: Sat, 11 June 2016, 19:21:28 »
I'd say cs is less a bike and more one of these
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #1141 on: Sat, 11 June 2016, 19:24:20 »
One of those where people a lot better than you are trying to shoot you as you cycle down the freeway.
« Reply #1142 on: Sat, 11 June 2016, 19:39:57 »
i get it cause going back into it the community is like crashing and smashing your face into cement
Offline HPE1000
  • Keycap Paparazzo
« Reply #1143 on: Sat, 11 June 2016, 19:48:00 »
lol
Casual lobbys over the past 6 or so months are as bad if not worse than my cod days on the console. Almost everyone is a kid yelling terrible things at other kids/players and LOTS of cheaters.
« Reply #1144 on: Sat, 11 June 2016, 19:50:28 »
lol
yeah its pretty bad i've been on cs go since early days and it sucks to see the game went mainstream honestly cause the community is even more ****ty than cs:s and previous titles
« Reply #1145 on: Sun, 12 June 2016, 09:20:09 »
Finally made private rank 3
/watch out geekhack...  I'mma noob gun all ya'll...
« Reply #1146 on: Sun, 12 June 2016, 12:46:13 »
Could someone recommend some good professional play videos to get started on..
Offline slickmamba
« Reply #1147 on: Sun, 12 June 2016, 13:20:56 »
lol
play community servers, not official.  Edgy cool kids get bullied in those.  If you played older versions it was all about community servers
« Last Edit: Sun, 12 June 2016, 13:26:28 by slickmamba »
Hi :)
« Reply #1148 on: Sun, 12 June 2016, 17:59:08 »
Is anyone playing csgo with a 4.7, 4.8 ghz using an intel 6700k
Are you getting consistently ~500 fps ?
I am considering getting into z170, because my 4790 and both 3xxx are doing other things.. I only have a 2600 and 2500 for games.. and they're stuck at ~350fps
« Reply #1149 on: Sun, 12 June 2016, 19:53:32 »
Really ?
No one on Geekhack haz a 4.7ghz 6700k ?
