Author Topic: camera  (Read 2826 times)
Offline frosty
  • jukebox hero
camera
« on: Fri, 05 September 2014, 09:22:16 »
recommend me a good camera that can capture some nice images please!
nice as in dustinhxc nice.
try to keep costs as low as possible, thank you geekhack!
Re: camera
« Reply #1 on: Fri, 05 September 2014, 09:52:03 »
Depending on the type of pictures you want to take....  the lens makes a larger difference usually vs the camera..
Camera bodies are all already quite capable.. and most modern day inventions post 2000s have been Icing on the cake.. but nothing earth-shattering.
Offline vun
  • Just one more thing
Re: camera
« Reply #2 on: Fri, 05 September 2014, 09:55:09 »
Fuji or Sony mirrorless, get the most expensive model you can afford/justify.
Offline absyrd
  • CPT HYPE PADAWAN
Re: camera
« Reply #3 on: Fri, 05 September 2014, 09:58:42 »
Offline ynrozturk
Re: camera
« Reply #4 on: Fri, 05 September 2014, 11:27:50 »
Go for a Canon 600D or 650D. Buy only body. Buy lens depending on what you want to shoot.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline frosty
  • jukebox hero
Re: camera
« Reply #5 on: Fri, 05 September 2014, 11:38:26 »
There is this thread:
http://geekhack.org/index.php?topic=61838.0
thanks absyrd!
and everyone else who posted!
i am a major dumbo when it comes to taking pictures. i normally just use my iPad.
Offline Altis
Re: camera
« Reply #6 on: Fri, 05 September 2014, 21:33:11 »
This is the best bet for OP.
DSLR would only be the way to go if you already have an expensive collection of lenses, or if you're looking to spend a lot and use it to make money.
Otherwise, mirrorless all the way. Sony makes some great ones.
Offline vun
Re: camera
« Reply #7 on: Sat, 06 September 2014, 05:56:00 »
I'd probably lean more towards fuji for the op tho, sony is a bit more on the expensive side.
Offline HipsterPunks
  • Gangnamember
Re: camera
« Reply #8 on: Sat, 06 September 2014, 07:13:07 »
Dustins photos lure in another victim towards a new camera purchase :) recently picked up a nikon d3300 w/ 40mm micro(macro) lens. As a complete novice to photography it has been suiting me well and is relatively user friendly. I agree with the above post that you should pick up just a body and then a seperate lens for your specific needs. Also canon t5's have been going on sale recently i believe kits are around $500 not a bad starter mirrored DSLR from what i hear
sell ass and eat out
Offline Altis
Re: camera
« Reply #9 on: Sat, 06 September 2014, 10:38:50 »
Fuji is micro four-thirds, hence it costs less, and still delivers very well (especially Fuji). Sony uses APS-C sized sensors (and even a couple of full frame), the same that Nikon puts in some DSLRs, so it's more expensive. I'd say Sony makes the highest end mirrorless cameras.
Some (like the NEX 3N) can be had with kit lens for $350 (power zoom compact), which is not unreasonable at all considering the sensor.
Offline tbc
Re: camera
« Reply #10 on: Sat, 06 September 2014, 19:38:02 »
the lens is the most important aspect.
get something in the 30 to 50mm range and make sure it's a macro lens for the sharpest pics.  alao get a dust blower, because you WILL see ALOT of dust that is too small to see with the naked eye and glasses.
Offline anowt
  • "I want you to buckle my spring" ♪♪~
Re: camera
« Reply #11 on: Sun, 07 September 2014, 19:28:54 »
the fujifilm x-pro1 is the camera I want since it's affordable and quite good.  but currently i'm saving for unicomp's tkl buckling spring keyboard this holiday season! ;D
Front Line: IBM Model M SSK
Tactical Team: QFR TKL (MX Blue)
Recon: KUL ES-87 (MX Red)
Special Operations: RF 87U 55g
Offline frosty
  • jukebox hero
Re: camera
« Reply #12 on: Sun, 07 September 2014, 23:50:02 »
once again, thank you all for your inputs! greatly appreciated them! i'm now saving up for a camera before i decide which camera i want. i have a budget around 600usd so i think it's enough... i guess? :)
thank you all!
