Author Topic: Ergodox..  (Read 4978 times)
Ergodox..
« on: Mon, 08 September 2014, 18:57:58 »
Antique cars are nice too look at, but a pain in the ass to drive..
The same goes for rectangular keyboards.
Offline saturnotaku
Re: Ergodox..
« Reply #1 on: Mon, 08 September 2014, 21:06:09 »
Only if you don't know how to handle them.
Offline Premonition
  • HHKB Elite
Re: Ergodox..
« Reply #2 on: Mon, 08 September 2014, 21:10:16 »
How is the ergodox for the hands? Seems like a great design.
Re: Ergodox..
« Reply #3 on: Mon, 08 September 2014, 21:12:54 »
I got some ergodox pcb's today.....i just unpacked them and held them for a little while.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Re: Ergodox..
« Reply #4 on: Mon, 08 September 2014, 21:22:02 »
An ergodox is like a fiat.
It's small, tiny, ugly and it's not a real car is for women.
« Last Edit: Mon, 08 September 2014, 22:50:09 by the1onewolf »
Offline Oobly
Re: Ergodox..
« Reply #5 on: Tue, 09 September 2014, 03:31:33 »
Seems more like a Caterham to me.
Requires construction before use, is small and nimble and can be great fun to use once you're used to it, but requires some commitment. Not for people trying to compensate for something....
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: Ergodox..
« Reply #6 on: Tue, 09 September 2014, 03:56:58 »
Re: Ergodox..
« Reply #7 on: Tue, 09 September 2014, 03:57:25 »
Look forward 1wolf,  don't turn around...
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Ergodox..
« Reply #8 on: Tue, 09 September 2014, 04:13:58 »
Keep on preaching the preach, Tp...
Re: Ergodox..
« Reply #9 on: Tue, 09 September 2014, 05:34:41 »
Here's the thing.. I've tried so very hard to do that.. On my TKL, I modified the layout to a split layout, I completely changed my typing technique..
All of which HELPED..
However the ultimate missing component was the ability to TENT the keyboard to fit one's natural wrist angle..
And if you have broad shoulders, split also greatly alleviates the inward rotation stiffness.
Re: Ergodox..
« Reply #10 on: Tue, 09 September 2014, 08:15:52 »
Have yet to see tp4's ErgoDox in pics. Need proof of life photos, tp4! Until then, I don't believe you actually even own an ErgoDox... :P
Re: Ergodox..
« Reply #11 on: Tue, 09 September 2014, 18:05:48 »
Offline Novus
  • Mondai nothing~
Re: Ergodox..
« Reply #12 on: Tue, 09 September 2014, 18:20:58 »
Wtf is a caterham ... let me google it...
oh
Remember my fellow decimeter size cocks, it's not size that matters. Width is more important.  :thumb:
Offline paicrai
  • mindblank
Re: Ergodox..
« Reply #13 on: Tue, 09 September 2014, 18:26:13 »
THE FEMINIST ILLUMINATI
Offline AKmalamute
  • HHKB Scrub
Re: Ergodox..
« Reply #14 on: Tue, 09 September 2014, 18:36:12 »
You know, with USB ... you could just use a second $5 keyboard. Tape them to each other at the 30d tent, and there you go.
HHKB-lite2, Dvorak user
Re: Ergodox..
« Reply #15 on: Tue, 09 September 2014, 20:43:59 »
I DID THIS...  I had 2 TKL, no tape,  I just tented them side by side separately..
The problem was with 2 usb devices.. SOMETIMES, the timing is a bit off..  so the keys might register slightly offset...  I even tried 1000hz on both keyboards simultaneously, didn't really help
Offline steve.v
Re: Ergodox..
« Reply #16 on: Tue, 09 September 2014, 21:58:05 »
I'm gonna be biased, if you type qwerty as a layout, don't get an ergodox. Otherwise it's a very good ergonomic keyboard for sufficient layouts.
Offline PadawanGeek
Re: Ergodox..
« Reply #17 on: Tue, 09 September 2014, 22:30:44 »
I've been offered an Ergodox with Korean 62g springs, lubed Clears, white stickers and Aluminium top....at about 320'ish (USD), worth it? I'm thinking real hard about it....
Offline orangeju1ce
Re: Ergodox..
« Reply #18 on: Wed, 10 September 2014, 00:38:14 »
What layout are you using for your ergodox?
Also, how are you configuring the layout? The only layout configurator I could find is the one on the massdrop website.
Offline sakai4eva
Re: Ergodox..
« Reply #19 on: Wed, 10 September 2014, 00:49:19 »
The joy of the ergodox is in building it. Not worth it IMO.
Offline Grim Fandango
Re: Ergodox..
« Reply #20 on: Wed, 10 September 2014, 00:56:35 »
The problem is that for most of the day, many people are forced to use standard layout keyboards. That is why I am not interested in familiarizing myself with an ergodox, or other non-standard layouts. If I have one at home there is no point, since I do 95% of my typing in different work locations. I would only get it for the novelty.
Though I do use my own keyboards at work. So I guess that if the workspace would allow it, and I would not mind spending the money to buy multiple ergodox, it would be an option.
Offline sakai4eva
Re: Ergodox..
« Reply #21 on: Wed, 10 September 2014, 00:59:24 »
Biggest disconnect for me is z-b on the qwerty layout. Otherwise I can swap out between ANSI-likes and the ergo any time.
Offline davkol
  •  Post Editing Timeout
Re: Ergodox..
« Reply #22 on: Wed, 10 September 2014, 03:17:42 »
Easy. Use ISO with the angle mod (i.e. ZXCVB shifted one key to the left).
Offline sakai4eva
Re: Ergodox..
« Reply #23 on: Wed, 10 September 2014, 03:24:05 »
That means getting an additional keycap set and a custom board, at least for me :(
Offline tbc
Re: Ergodox..
« Reply #24 on: Wed, 10 September 2014, 04:36:58 »
the ergodox is sufficiently different from regular layouts that it's possible to maintain separate muscle memory
Re: Ergodox..
« Reply #25 on: Wed, 10 September 2014, 05:22:55 »
This depends on how familiar and developed you are on your BASE layout..
I will not forget qwerty...
I have a non-standard modified qwerty layout on Egdx
I'd think for newer adopters or younger net kids,  they might be consumed by the Egdx, and never be able to pick back up on the rectangle..
Which is just as well, since the Ergodox is >> rectangle.
Offline davkol
Re: Ergodox..
« Reply #26 on: Wed, 10 September 2014, 06:38:24 »
Huh? ZXCVB are all the same profile, as well as the extra ISO key. This means you only turn \ZXCVB into ZXCVB\.
Or do you mean that you don't have an ISO keyboard?
Offline sakai4eva
Re: Ergodox..
« Reply #27 on: Wed, 10 September 2014, 08:31:21 »
ANSI all the way, fortunately or not...
Offline Data
Re: Ergodox..
« Reply #28 on: Wed, 10 September 2014, 12:06:36 »
I'm forced to type on a number of different keyboards throughout the day, so moving from an ErgoDox at home to a TKL at my desk to a random Dell rubber dome or a client's MS Natural KB isn't a problem.  You adjust.  I make a few typos for the first 50-100 characters and then I'm settled in.  I assume it's like this for most people in my position (IT).  I don't have the luxury of using the exact same perfect (for me) keyboard everywhere I go, so I use it when I can and I suck it up the rest of the time.  It's not as hard as some people make it seem.
Offline AKmalamute
  • HHKB Scrub
Re: Ergodox..
« Reply #29 on: Wed, 10 September 2014, 12:11:33 »
I'm forced to type on a number of different keyboards throughout the day [...] I assume it's like this for most people in my position (IT) [...] It's not as hard as some people make it seem.
+1
I've been a dvorak convert for something akin to fifteen years. I can type qwerty just as well, and for the same reason. Now that I have an ergodox, I assume it will be the same ... although the left-hand bottom-row keys, ';', 'j' & 'k' (because who uses q?) seem to trip me up the most -- you use different fingers b/w ergodox, and row-staggard-squares.
Offline madik
Re: Ergodox..
« Reply #30 on: Wed, 10 September 2014, 12:51:23 »
Kind of disappointed that i went with the Ergodox. It was a good experience building it, but writing on it is just pain. Hate that the keycaps in collums are in lines. Would be much better for me if the rows were in lines like on normal keyboards. Accessing the number's row giving me the most troubles because positions of number's keycaps are shifted than what I am used to.
Should have waited for some Phantom groupbuy and make a TKL keyboard with custom switch layout. But yeah i have my ergodox for just about a 2weeks. Will get used to it a bit more..
Offline Arcoril
Re: Ergodox..
« Reply #31 on: Wed, 10 September 2014, 15:19:41 »
I know that feeling. It took me longer than a month of continuous usage until I could sit down with the ErgoDox and have it feel natural without really concentrating on how I was typing. I admit that during the process I cheated and used my old QFR out of frustration from time to time, but I'm glad that I stuck with the ErgoDox. It really does feel more comfortable to me but it definitely wasn't love at first sight.
Offline tbc
Re: Ergodox..
« Reply #32 on: Wed, 10 September 2014, 23:31:37 »
it takes a hell of a long time to get used to edox.
2 weeks is nowhere near enough.  try 6.
probly more if you've never used a filco minila.
for people with typing pain, the benefits are enormous;if you don't have pain, maybe it's not as worth it?
Offline gcb
Re: Ergodox..
« Reply #33 on: Thu, 11 September 2014, 01:41:31 »
i read the other day that learning to brush your teeth with your left hand helped your brain not age too much and prevented Alzheimer or something. of course it was not a scientific paper or anything. was probably bored reading the articles on playboy or GQ.
anyway, now i load random keymaps on each my keyboards every morning! ...i can type 5~7 wpm by 2pm.
Re: Ergodox..
« Reply #34 on: Thu, 11 September 2014, 08:05:40 »
THis is HIGHLY dependent on how well you've mastered Qwerty in the first place.
I just got back from using a standard rectangle qwerty for a whole month.. (no dox @ all)
just did a speed run...    clearly... it's down to overall-mastery..
