Author Topic: Best settings for the Zowie FK1 if you're used to 1200DPI/CPI  (Read 21557 times)
Offline Fragil1ty
  • Abre los ojos.
« on: Mon, 03 November 2014, 11:21:47 »
So as the title implies guys, I'm heavily used to using 1150 - 1200 DPI on all of my past mice and what not.
My current settings for the Zowie FK1 are:
1000hz (default I believe)
800 DPI
7/11 - Windows Sensitivity
Razer Goliathus mousemat
When I put the windows sensitivity down to 6/11 it feels a little too slow and anything above 7/10 is too fast, so is the best that I'm going to get out of Windows and my mouse?
你搞砸了
Offline davkol
  •  Post Editing Timeout
Re: Best settings for the Zowie FK1 if you're used to 1200DPI/CPI
« Reply #1 on: Mon, 03 November 2014, 12:44:25 »
Windows sensitivity above 6/11 isn't the best idea. Better play a bit with lower sensitivity and higher sensor resolution.
Offline CeeSA
« Reply #2 on: Wed, 17 December 2014, 15:29:50 »
DPI 1600
Win 5/11
= 1200dpi
BUT: every 4th count is ignored = inconsistent
Offline pro_LAPSE
  • However, rays of nuclear!
« Reply #3 on: Mon, 12 January 2015, 22:02:06 »
It blows my mind that anyone in their right mind can use a sensitivity that high... Do you play videogames like that too?? I cant imagine being good at them with that kind of sens.
for reference sake, I play CSGO with 400dpi, 6/11 windowns sens, and 1.5 ingame sens (CS:GO)
chopstick cruelty bleeds Aritzia creme.
Offline cephelix
  • to buy or not to buy?
« Reply #4 on: Tue, 13 January 2015, 02:35:23 »
well, i don't know about most people, but i use my fk1 at 3200 dpi....for everything...maybe for fps i tone it down a bit..but for everything else from normal everyday use to games, like witcher i use it at 3200
ALi
Filco MJ2 TKL MX Browns | KC60 Gateron Browns
Offline pro_LAPSE
« Reply #5 on: Tue, 13 January 2015, 04:26:12 »
perhaps I became accustomed to using my forearm for moving the mouse instead of my wrist. I love the feeling of a mouse passing over a large surface area, its very pleasing/satisfying/borderline eroitic. One thing about the FK1 that annoyed me, at first, was the mouse "bottoming out". HAve you gotten that at all? The mouse feet are far too shallow, and they allow for the center of the mouse to catch the cloth of the pad if you even press down on it slightly.
Now that I have used it more I am much more used to that feeling.
Offline cephelix
« Reply #6 on: Tue, 13 January 2015, 09:12:31 »
ahh, you're like one of my friends then..he likes the large swiping motion as well....i personally though find that 3200 dpi is just nice...anything higher and it'll be too sensitive.
i'm trying it out now...maybe i'm doing it wrong. i'm pressing down with my index and middle finger quite hard at the base of the slit, at the highest or thereabouts point of the mouse and i don't get any catching at all. fyi, i'm using a razer goliathus
ALi
Offline Creizai
« Reply #7 on: Tue, 13 January 2015, 19:56:25 »
Majority of FPS players play @ 400dpi (resolution doesn't matter on fps) and a good majority of the SC2 Pros use 800dpi @ 1080p.  However in FPS you can adjust sensitivity with any speed you want.  I personally prefer 800dpi on desktop usage over my EC2.  Anyway random.. but I would stick with the DPI 1600 Win 5/11= 1200dpi.  If you actually can notice a problem then you can go from there, if not then don't look back and enjoy the sensitivity you are use to.
Offline pro_LAPSE
« Reply #8 on: Tue, 13 January 2015, 20:57:15 »
I don't want to be the guy that tells you a certain setting is superior, but I went from nova 4 to LEM/SMFC within a few months after I just changed it and got used to it. That being said, there are quite a few wrist players out there, and they are amazing with a high sens. They are a very small minority though.
what games are you playing?
Offline SavvyBird
  • Savvy Caps
« Reply #9 on: Tue, 13 January 2015, 21:11:05 »
what game are you playing because
1200 dpi is crazy
i use 400 with 7/11 and .98 sens with cs:go
hi
« Reply #10 on: Tue, 13 January 2015, 23:04:17 »
1200 is high? ****, i play 1800. and 900 if i wanna move slow.
Offline cephelix
« Reply #11 on: Tue, 13 January 2015, 23:23:24 »
Oh no no, i'm not saying setting is superior either.i'm just saying what i've seen.everyone has their personal preference and what matters is that they're comfortable with...regardless of settings
ALi
« Reply #12 on: Wed, 14 January 2015, 01:57:16 »
I use 2700dpi  in windows.. because it's more ergonomic to have less wrist movement..
in games I use 800 like all the pr0z..  <-- years ago.. I don't play no more.
The reason for using native/reduced dpi is to lower potential jitter, and input lag..
remember, the sensor has a processor... the more crunching is required, the more the potential latency, and the odds for a hiccup...
Offline awts
« Reply #13 on: Thu, 15 January 2015, 22:29:11 »
I play at these settings with my FK2 in CS:GO:
FK2 DPI: 400
Windows Sensitivity: 6/10
CS:GO Sensitivity: 2.0
In OS X however, I switched to 800DPI so I move less...
