Author Topic: Shivering?  (Read 2475 times)
Shivering?
« on: Fri, 07 November 2014, 13:48:15 »
Last night I woke up in the middle of the night to piss, and when I got outta bed my body began shivering violently and uncontrollably. Weird thing was, it wasn't cold in my home at all. After peeing I went back under the covers to warm up but it didn't really help since I wasn't actually cold. After about 5 minutes it stopped as I relaxed back into sleep.
Any idea what that was, or has anyone experienced anything like this before?
Offline Lurch
Re: Shivering?
« Reply #1 on: Fri, 07 November 2014, 13:53:28 »
I've never experienced anything like that, but I have shivered rather intensely from anxiety as a youth.
Quote from: Flyersfan1
Offline ConscienceDrop
  • a-are these pbt?
Re: Shivering?
« Reply #2 on: Fri, 07 November 2014, 13:55:18 »
thats a sign of a billion diferent things
-overusing stimulants: excessive caffeine, cocaine, adderal
-low blood sugar for certain individuals.
-PMS
-fever
-more severe issues like having a mild stroke
be safe.
its hard to diagnose things over the internet so take everything with a hefty grain of salt.
Re: Shivering?
« Reply #3 on: Fri, 07 November 2014, 14:07:49 »
-PMS
-fever
be safe.
Well, I can rule some of those out. Not sure what a stroke feels like, but I'm only 30 and not in atrocious shape so that's pretty unlikely. Someone said it could be a sign of an internal infection but how would you tell?
  • a-are these pbt?
Re: Shivering?
« Reply #4 on: Fri, 07 November 2014, 14:11:37 »
TBH i have zero idea.
i would keep an eye on it, if its happening more then it might be wise to go see a doctor or whatever you have access to.
its really hard to make these calls when a symptom can mean almost anything
if it was an internal infection i would say probably look up other signs of internal infection and keep an eye out for those
Re: Shivering?
« Reply #5 on: Fri, 07 November 2014, 16:27:57 »
This happens when you wake up abruptly from deep sleep..
essentially your body has not fully rebooted.. and the muscle control has not fully been reestablished.
Offline Touch_It
Re: Shivering?
« Reply #6 on: Fri, 07 November 2014, 16:41:39 »
Honestly I wouldn't put much thought into it unless it keeps happening or you notice something else out of the ordinary.  The body does some strange things when you are tired.
  • Live long and prosper
Re: Shivering?
« Reply #7 on: Fri, 07 November 2014, 16:48:58 »
It's probably nothing. But if you think it could be something, ask a doc about it.
tp thread is tp thread
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Re: Shivering?
« Reply #8 on: Fri, 07 November 2014, 16:50:41 »
are you dehydrated or diabetic?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline BlackWidowMan777
Re: Shivering?
« Reply #9 on: Fri, 07 November 2014, 17:04:24 »
Get yourself a thermometer and take a reading again if this happens again.
Chances are you got up too suddenly, after having a nightmare, causing your blood pressure to drop suddenly making blood to go to your heart in response. Then less blood is on the periphery of your body (skin) so you felt cold.
Re: Shivering?
« Reply #10 on: Fri, 07 November 2014, 20:13:48 »
I get this all the time. I have low blood pressure too. getting up to quick with low BP isn't always a workable plan.
Sadly there's much more info online for lowering your BP than raising it.
You mean "need moar Acetylcholine or w/e ?"
« Last Edit: Fri, 07 November 2014, 20:15:42 by dorkvader »
Offline tbc
Re: Shivering?
« Reply #11 on: Sat, 08 November 2014, 01:54:47 »
if it was from sleeping, it might be a pinched nerve.  not a pain nerve that you would notice, temperature nerves don't cause a noticable feeling.
Re: Shivering?
« Reply #12 on: Sat, 08 November 2014, 04:35:53 »
metabotropic GABAB and  ionotropic GABAA/glycine
basically.. your body needs to clean this stuff off before you can MOVE.. those 2 chem are responsible for sleep paralysis
So, it is POSSIBLE to wake up other sections of your brain prior to having enough time to clear everything..
Essentially, it's like turning your computer back on from sleep state, but because you use a mechanical harddrive, it takes some time to spin up..
This phenomenon doesn't usually affect people unless they're prone to disturbed sleep..
Very similar to this is lucid dreaming.. brain functioning in semi-awake states.
