Author Topic: Cherry MX Clears?  (Read 2199 times)
Offline TheO-RingGuys
  • Hey, my name is Fernand and I sell o-rings. B)
Cherry MX Clears?
« on: Mon, 17 November 2014, 19:23:42 »
I've been hearing awesome things about these switches, and would like to know of any popular keyboards that carry 'em.
Also, I would like to hear your opinions on them as well! So post away~
Re: Cherry MX Clears?
« Reply #1 on: Mon, 17 November 2014, 19:27:39 »
Code, KUL, Ducky are three that spring to mind.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Mon, 17 November 2014, 19:30:31 »
Depends, what size layout are you looking for? For TKL keyed up labs (KUL) is probably your best best. They had pokers (60%) on massdrop with clears, they might have them again. I've heard from some people that the CODE boards were nice except for the serious ping
« Reply #3 on: Mon, 17 November 2014, 19:55:06 »
You may also want to try Mx Red and blacks... before you decide.. or get both..
the typing rhythm is very different  because the lack of feed back gives you a more flowing sensation..
Offline MGH
« Reply #4 on: Mon, 17 November 2014, 20:41:45 »
I think the stem is thicker and it makes pulling off keycaps much harder.
« Reply #5 on: Mon, 17 November 2014, 20:43:33 »
this is correct
but really only DSA is too much harder to pull off. I have no issues with GMK or DCS profile.
« Reply #6 on: Mon, 17 November 2014, 20:48:16 »
this is correct
I understood that SP had resolved the tight DSA issue.
I don't recall any specific problems removing Granite from my QFS.
« Reply #7 on: Mon, 17 November 2014, 20:49:24 »
i don't really use or pay much attention to DSA, so thanks for clearing that up
« Reply #8 on: Mon, 17 November 2014, 21:15:19 »
I love clears and use them daily, used clears are even better.
But I have found GMK caps can be a really tight fit, actually most caps besides DCS and OEM.  I use a hamblet key puller so its not a problem.
« Reply #9 on: Mon, 17 November 2014, 21:30:52 »
Have you tried SA (e.g. Nuclear Green) on clear?  Are they tight too?
I found my Costar stabiliser inserts extremely loose with Nuclear Green SA.
« Reply #10 on: Mon, 17 November 2014, 21:36:12 »
I have not, and it seems like costar inserts are loose in most SP caps.
Offline Oobly
« Reply #11 on: Tue, 18 November 2014, 00:56:25 »
I have tried Penumbra SA on Clears and found them quite tight, similar to GMK.
And the Clear stems are not thicker, they just have some ridges on the stem as seen in this post: https://geekhack.org/index.php?topic=53113.msg1183206#msg1183206
It's even easier to see the bumps on tactile Grey stems: http://deskthority.net/wiki/File:CherryMX_diff_grey_brown_068487.jpg
For some caps, like the Keycool POM ones it helps to use a loose switch and cycle a few times putting the cap on and pulling it off. It widens the gap a touch, but they still fit fine on "normal" stems like Browns and Blacks.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline tbc
« Reply #12 on: Tue, 18 November 2014, 02:44:12 »
as of approximately may this year, SP was still selling blank black pbt dsa caps that could rip the stem and/or top housing off of a switch
