Author Topic: Ergo Clears vs Vintage Blacks  (Read 5175 times)
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« on: Sat, 13 December 2014, 11:12:02 »
I currently have a set of lubed stickered vintage blacks. after reading through a lot of posts on here i'm thinking i might like ergo clears. Before I get my hand dirty installing these vintage blacks I was wondering is there anywhere I can try Ergo clears? maybe somewhere I can buy just a few of the components to make one?
Re: Ergo Clears vs Vintage Blacks
« Reply #1 on: Sat, 13 December 2014, 11:36:52 »
I went from Ergo clears to vintage blacks..
I did it out of boredom..   how they compare.. well..... obviously blacks are smoother.. but... as far as performance...   My skill transcends the miniscule differences in response timing from the keys.
« Reply #2 on: Sat, 13 December 2014, 11:45:22 »
I like vintage blacks over clears. Only thing that bugs me about my KUL.
Offline zennasyndroxx
  • It's good to be back!
« Reply #3 on: Sat, 13 December 2014, 11:48:20 »
blacks is like doing it with your hand. vintage blacks is like doing it with a fleshlight.
Offline Lurch
« Reply #4 on: Sat, 13 December 2014, 11:49:15 »
Neither of you answered OPs question... :rolleyes:
Bromono, you should be able to buy a small pack of MX clear switches, and swap the springs out with something lighter, say from Originative, to get an idea of what Ergoclears are like.
Quote from: Flyersfan1
« Reply #5 on: Sat, 13 December 2014, 11:50:39 »
Sherry's sketchy, don't order from originative. Get some springs from the classifieds, and I'm pretty sure sprit is taking orders for round 3 of his spring GB.
Offline yasuo
  • spanengan puyeng newbie
« Reply #6 on: Sat, 13 December 2014, 11:51:36 »
i like linear than tacticle of mx
Logitech MK220 Colemak DH
Offline Bromono
  • Wanabe Cicerone
« Reply #7 on: Sat, 13 December 2014, 11:59:34 »
hmmm the only experience I have with my vintage blacks is putting a cap on it and using my thumb and index finder to compress it. I think I will just install them.
Offline cphead
« Reply #8 on: Sat, 13 December 2014, 12:10:52 »
You can always mount them on the plate without soldering and try typing to see how it would feel
Offline berserkfan
« Reply #9 on: Sun, 14 December 2014, 03:07:00 »
How about just get 45g springs from me? I have lots.
Offline frosty
  • jukebox hero
« Reply #10 on: Sun, 14 December 2014, 03:42:12 »
I HAVE  VINTAGE BLACK AND ERGO CLEAR BOARDS. They're the only boards I have, I like the ergos but I somehow still go back to my vintage blacks... I think the smoothness of the ergos just don't cut it. I lubed them already though...
« Reply #11 on: Sun, 14 December 2014, 08:26:04 »
What about vintage clears :eek:
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #12 on: Sun, 14 December 2014, 09:55:05 »
If you must change springs on vintage black try put in clear springs. If your vintage blacks are already buttery smooth feeling like they should be, don't ruin it with lubes.
Offline Battou62
« Reply #13 on: Sun, 14 December 2014, 12:18:40 »
I have been lucky enough to try both. My favorite switch has always been linears, but I found Clears(65g) to be enjoyable as well. They are just so different it is hard to tell which you will like without trying them both. With that being said, all roads lead to the linear master switch :P My Kmac w/ 75g Vintage Blacks feels completely different from my Filco with MX Blacks.
Offline Oobly
« Reply #14 on: Mon, 15 December 2014, 05:04:04 »
ErgoClears won't really compare well to vintage Blacks until they're worn in. Even then, they're different beasts. I like tactile switches, so for me, ErgoClears get the nod, but I wish they wore in quicker. Even the 'E' key on my board still has a slight scratchiness to it after 6 months of heavy use.
You can buy some Clear switches from here: http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=58
They have them in bundles from 5 to 110 in a pack.
62g springs from here: https://geekhack.org/index.php?topic=55888.0
If you do make some ErgoClears, I recommend trying the stock Clear springs in your vintage Blacks :D Those are my top tier tactile and linear switches (62g ErgoClears and vintage Ghost Blacks).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Battou62
« Reply #15 on: Mon, 15 December 2014, 08:15:52 »
That explains a lot. I thought the clears I had typed on felt really scratchy. I need to try some of those vintage ghost blacks :)
Offline Sygaldry
  • Edema Ruh
« Reply #16 on: Mon, 15 December 2014, 09:20:41 »
I love Ergo Clears but ended up switching to Vintage Blacks as well...
Both are great switches but in the end I think a nice, buttery-smooth linear switch takes the cake.
(I like Topres for this reason too; because the tactility of the Topre is at the top of the keypress, the majority of the keypress feels linear to me)
null
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #17 on: Mon, 02 March 2015, 17:22:48 »
Sygaldry, did you end up swapping out the springs of the vintage blacks?
