Author Topic: Any typing tips for reds?  (Read 4771 times)
Offline Lazerxzz
« on: Thu, 15 January 2015, 02:14:21 »
I used blue switches for about 4 years and most recently switched to reds. (1 year ago) I also still bottom out very  hard. Anyone have any tips to be a more light typist? I make a ton of typos still and pretty much slam my fingers into the keyboard.
Re: Any typing tips for reds?
« Reply #1 on: Thu, 15 January 2015, 02:33:50 »
only tip i have is to not use them
Offline hoggy
  • * Ergonomics Moderator
« Reply #2 on: Thu, 15 January 2015, 02:46:00 »
I used to have the same problem.  The kinesis advantage has an option for a beep when you activate the key (which is half way down), which helped me a lot.  I wonder if there some software that will do the same thing...
Offline Fragil1ty
  • Abre los ojos.
« Reply #3 on: Thu, 15 January 2015, 03:03:43 »
I guess it's just going to be one of those things that you learn to get better with over time unfortunately. Reds are one of the best key switches in my honest opinion, as for bottoming out, I have never been a big user on not bottoming out my keys, I really do not care either way to be honest with you.
你搞砸了
Offline Macsmasher
« Reply #4 on: Thu, 15 January 2015, 04:26:32 »
Sure do. Sell it on craigslist. Seriously, it's a decent switch for gaming. But for typing, you're denying yourself the pleasure of a tactile switch. The tactile feedback really does help.
If you like light switches MX browns or Topre variable are good choices.
« Reply #5 on: Thu, 15 January 2015, 05:39:34 »
This comes down to technique
Switches may affect you "IF" you let them..  but ultimately how a switch feels and responds is just dressing..
The key to fast and accurate typing IS indeed to Bottom out.. and disregard switch feel all together..
Which is why I keep telling the n00bs that switches don't matter.. AT ALL... you should disregard them and process the information as closely as possible.
There are cases where you may be able to roll  the (inner column )keys  less than all the way down..  Rolling them this way may increase fluidity but ultimately decreases precision.
The majority of slower typists also do not have very good finger-freedom.. You sometimes see them hold their pinky and ring finger, up high in the air..
This is the result of poor motor control due to lack of training..
The key to overcoming this is to type SLOWLY, 1 key at a time, while making an effort to relax ALL other  hand muscles/fingers/wrist NOT currently in use..
Engaging fingers independently this way will greatly improve control-accuracy.
Offline azhdar
  • Praise the AZERTY god
« Reply #6 on: Thu, 15 January 2015, 06:47:55 »
and get an ergodox right ?
Azerty Propagandiste
Offline ynrozturk
« Reply #7 on: Thu, 15 January 2015, 07:05:22 »
Can't believe he forgot that part.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline Lurch
« Reply #8 on: Thu, 15 January 2015, 07:11:11 »
Quote from: Flyersfan1
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10 on: Thu, 15 January 2015, 08:19:08 »
You sound like a perfect candidate for O-rings.
- D Trump 2026-10-24
Offline derb2k2
  • Something of a Topre ****..
« Reply #11 on: Thu, 15 January 2015, 08:46:28 »
Exactly this. Try to find the 0.4mm rings which would decrease distance required.
If you're making a lot of typos, try to decrease the typing speed. It helped me lots with reds since they're so easy to actuate.
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline Geroximo
« Reply #12 on: Thu, 15 January 2015, 08:56:01 »
PRO-TIP: After using reds -> switch to MX Blacks -> no more bottoming out -> win
Offline drewba
« Reply #13 on: Thu, 15 January 2015, 09:18:48 »
You missed an opportunity to convert an MX user to Topre
Offline Hypersphere
« Reply #14 on: Thu, 15 January 2015, 10:06:24 »
I don't see any problem with bottoming out, regardless of the switch you are using. Because mx reds have no tactile bump near the actuation point, I especially bottom out on reds -- bottoming out is my sure signal that actuation has occurred. My typing style is to bottom out on every keystroke, and so I tend to favor switches for which the force needed for continuing the keystroke past actuation decreases rather than increases. Therefore, I seldom use Cherry mx switches.
Of course, many people disagree with this approach, and some consider bottoming out taboo. If you are intent on avoiding bottoming out, then you need to train yourself to depress the keys only slightly past the actuation point and then to let up before bottoming out. Some manage to do this with reds, but it is difficult with no tactile bump to warn you that actuation has occurred. It is perhaps easiest with mx clears, which have a pronounced tactile bump and a steep slope of increasing force past the tactile bump that helps to discourage bottoming out.
Offline Huxley2500
« Reply #15 on: Thu, 15 January 2015, 17:47:24 »
There is a reason Clicky keyboards are preferred for typists.
Offline Hypersphere
« Reply #16 on: Thu, 15 January 2015, 18:00:10 »
Yes, I very much agree. I have two KBP V60 Matias switch keyboards. One has Matias Click and the other has Matias Quiet switches. It is difficult to determine this, but I think that the two switches have the same pronounced tactile feedback, but it seems even more pronounced with the Click switches. I also enjoy typing more on the Click switches. On the other hand, when I am within earshot of others who would be annoyed by the clicking, the V60 with Matias Quiet is the quietest mechanical keyboard I have ever used -- it is even quieter than my HHKB Pro 2 Type-S.
« Reply #17 on: Thu, 15 January 2015, 18:38:44 »
I quite like typing on reds.
There's no real trick to it, just use them a lot.
Learn to type on them without bottoming out, too, that's a useful trick for sure.
« Reply #18 on: Fri, 16 January 2015, 00:03:14 »
I bottom out all the time on reds.
And blacks.  And greens.
And buckling spring.
If reds are too light for you, try switching to blacks.  Or greens.
Or greys.
Or superblacks :p
Offline Polymer
« Reply #19 on: Fri, 16 January 2015, 00:41:03 »
But it isn't because it keeps them from bottoming out..
Not sure where that all came from...You don't react to the sound to prevent yourself from bottoming out unless you type VERY slowly...
A lot of people come on here and say they don't bottom out..and the reality is, unless you're typing slowly, you're going to bottom out..maybe not on every stroke but you're going to bottom out...
If you're ok with sacrificing some speed to have lower impact on your fingers, that is truly a VERY good trade off for some people.
A previous regular to this site who liked to practice typing used to claim that bottoming out was necessary for speed..even though he would bottom out on Cherry switches more than he thought..and he now uses Topre which you bottom out all the time...and admitted his speed was the same...
You then have super fast typers like Wrona who obviously bottom out...hard...
Offline Lunatique
  • Writer, Composer, Artist, Photographer, Gamer
« Reply #20 on: Fri, 16 January 2015, 02:13:14 »
I have to agree. Typing on red is just not as satisfying/efficient due to lack of tactile feedback. I think it's great for gaming (especially FPS, which red is so good at for the movement keys--better than any other switch type), but it ranks the lowest on my list for typing--even lower than some rubber domes (since with those, there's at least the collapse of the dome which provides some kind of a snapping sensation).
Personally, I don't "mind" bottoming out, as long as you're not pounding the keys with gorilla strength and causing damage to your fingers/hand/wrist and then develop RSI. HOWEVER, with that said, I think keys that provide tactile feedback before bottoming out allow you to let go of the key as soon as they actuate, which reduces key-travel and feels more efficient/faster/smoother. It may or may not actually translate into faster WPM or more accuracy, but it "feels" more liquid and soothing as you type. I tried to do the same with red switches but without that tactile feedback, I end up not actuating some keys, so I kind of have to bottom out. At least I don't pound the keys with gorilla strength though, so it's not bad at all, but I do type slower and make more mistakes with red than any other switch type.
« Last Edit: Fri, 16 January 2015, 14:53:21 by Lunatique »
« Reply #21 on: Fri, 16 January 2015, 07:26:49 »
Typing techniques are as different as anything else.
I learned to type in high school on a manual typewriter (yes, I am THAT old) where the technique had to be a whip-like thrust downward with the fingertips, snapping the wrist each time to deliver maximum speed and force focused at the bottom-most point of the key's travel.
Today, I like light keys in general but am completely comfortable with medium or heavy ones. Depending on my mood, I might be striking the keys hard and bottoming out, or I might be typing lightly and stopping immediately below activation. Either way works for me, as long as the switches are tactile.
My wife, a professional writer and editor who types thousands of words per day, and has for decades, has used the thin metal Apple keyboards (flat rectangular keys and scissor switches) exclusively for years. Her fingers just float over the keys and barely dip down with the slightest of motions to activate the keys.
  • Live long and prosper
« Reply #22 on: Fri, 16 January 2015, 08:10:49 »
tp thread is tp thread
Offline Nai_Calus
  • CLACK
« Reply #23 on: Fri, 16 January 2015, 08:26:58 »
If you aren't happy with how the reds work after all this time... Er, why are you still using them?  o_O
I mean, I could probably get used to reds eventually if I had to use them, but... Every time I've tried typing on a display board at Fry's or somewhere with red switches, I hated it. Using it would be silly because I wouldn't enjoy it and I'd be frustrated because of the lack of tactile feeback.
So I guess my tip is the same thing that keeps getting quoted, which is: Well don't use them, then.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline opensecret
  • 公开的秘密
« Reply #24 on: Sat, 17 January 2015, 22:48:31 »
O-ringed reds are my favorite Cherry switch, and I seem to type a little faster on MX reds than on anything else I use (including Alps, BS, and variable Topre -- and with all those available, I'm typing on reds right now).  The low actuation force does make it a little easier to hit a key unintentionally.  If that's where your errors are, slowing down and practicing a slightly softer keypress may help.
But keyboards are like cars, wines and spouses -- you need to find what works for you.
IBM Model M |Matias Mini Quiet Pro|Plum 84EC-S|RealForce 103U-UW & 87U-UW|Omnikey Ultra T| 2 Omnikey Ultras| WASD V2| Xmit Hall Effect|
Offline Valen
« Reply #25 on: Sun, 18 January 2015, 04:48:34 »
I kept hitting keys unintentionally, even actuated them from time to time when resting my fingers on them to get ready to type. Got frustrated and sold it.
Offline Oobly
« Reply #26 on: Mon, 19 January 2015, 06:30:20 »
Switch to Browns.
Light like Reds, but the tactility allows to get some feedback of when the switch actuates and even you do still bottom out, you start to decrease the pressure at the point you "know" the switch has actuated. If you have no feedback mechanism, you tend to keep "pressing" until you get some, which on linear switches mean you're still accelerating the switch all the way down to the bottom-out point.
Unless you take a lot of effort to train yourself not to, but it's not intuitive and I see no real point to doing that when you could just rather use a switch type that gived you the feedback to intuitively reduce the pressure after actuation.
Sometimes, when you're typing fast, you may not even consciously notice the tactile bump on Browns, but your subconscious still does. It really makes a difference to typing accuracy (and minimises accidental presses) and reduces bottom-out forces considerably.
An audible signal when they actuate can also help, but it's not as intuitive as having some tactility built into the switch.
Or buy a board with Clears and mod them to 62g ErgoClears, the most awesome MX switch type ;)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Zensuji
« Reply #27 on: Mon, 19 January 2015, 07:01:50 »
Offline Merranza
« Reply #28 on: Mon, 19 January 2015, 08:34:21 »
Switch to Browns.
You see, for me, it's the opposite. The tactile feedback was making me skip key actuation because as soon as I felt the bump, I'd stop my downstroke and not press the key correctly. That's how I realized I was typing very lightly. I'm getting used to the actuation point of the reds where I'm beginning to know instinctively where to stop pressing. My reference is the resistance of the switch which grows the more you downstroke. For sure, if I type at my fastest, I will bottom out but I was bottoming out on browns too in that scenario.
Reds is also forcing me to become a much more accurate typist since like you clearly stated, reds are a bit easier for typos.
« Last Edit: Mon, 19 January 2015, 12:08:21 by Merranza »
Offline aceps00
« Reply #29 on: Mon, 19 January 2015, 15:12:13 »
I've used reds a while back, if you really want to use them for typing, try not to bottom them out/ don't put much pressure in your keystrokes.
Type Heaven / IBM Model M
Offline Roibhilin
  • Saver of Humens
« Reply #30 on: Mon, 19 January 2015, 19:03:38 »
QFR | Poker II | Quickfire TK
