Author Topic: Why does quoting certain members freeze this site?  (Read 4180 times)
« on: Sun, 25 January 2015, 10:33:40 »
When I reply to a thread, all is well. When I attempt to quote someone's comment, that usually works properly, too.
However, there are certain members, at least a half-dozen of them, who, when I attempt to quote them, freezes the screen with and interminable "Loading .... " message at the top.
What is the cause of this, and why does it pertain only to certain members?
- D Trump 2026-10-24
Re: Why does quoting certain members freeze this site?
« Reply #1 on: Sun, 25 January 2015, 10:34:23 »
I get this, too. Seemingly at random.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #2 on: Sun, 25 January 2015, 10:34:52 »
Which members so I can try? I have never experienced this issue, it might be you.
  • Live long and prosper
« Reply #3 on: Sun, 25 January 2015, 10:47:45 »
I've gotten this several times... usually I just try again until it works.
tp thread is tp thread
« Reply #4 on: Sun, 25 January 2015, 12:05:52 »
It pretty much always happens with jacobolus, nubbinator, intelli78, just off the top of my head.
Offline azhdar
  • Praise the AZERTY god
« Reply #5 on: Sun, 25 January 2015, 12:13:05 »
:octagon:
Azerty Propagandiste
Offline iri
« Reply #6 on: Sun, 25 January 2015, 12:24:10 »
Never had such problem, even when quoting the mentioned members.
-Ray Bradbury
Offline intelli78
« Reply #7 on: Sun, 25 January 2015, 12:25:11 »
=O
Never had this happen.
« Reply #8 on: Sun, 25 January 2015, 12:32:29 »
:octagon:
What does "octagon" mean?
By the way, after suffering with an abominable AT&T DSL line for years, I just changed over to a Comcast cable modem, which seems blindingly fast in comparison. I assumed that the problem would go away with a better connection, but it has not seemed to change.
« Reply #9 on: Sun, 25 January 2015, 12:38:07 »
« Reply #10 on: Sun, 25 January 2015, 13:39:20 »
:octagon:
It's making fun of the :triangle: thing TS does.  azhdar should know better though, it should be :square:.
I wonder what causes that.  I haven't had any issues like that.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #11 on: Sun, 25 January 2015, 13:42:36 »
that one user with the 0s and 1s in his name seems to break quotes
Offline 0100010
  • Not Sure
« Reply #12 on: Sun, 25 January 2015, 15:36:38 »
People tells me it happens to them when they quote me; enough so that I added a disclaimer in my signature.
Offline azhdar
« Reply #13 on: Sun, 25 January 2015, 15:39:58 »
testing
Offline azhdar
« Reply #14 on: Sun, 25 January 2015, 15:40:19 »
testing
"Wrong value type sent to the database. Array of integers expected. (quoteids)"
indeed
Offline ideus
  • Björkö.
« Reply #15 on: Sun, 25 January 2015, 16:00:36 »
Testing.
Offline iri
« Reply #16 on: Sun, 25 January 2015, 16:19:49 »
test
-Ray Bradbury
« Reply #17 on: Sun, 25 January 2015, 16:21:08 »
testing for myself...
INTERESTING...
« Reply #18 on: Sun, 25 January 2015, 16:26:47 »
I've had this issue as well.
« Reply #19 on: Sun, 25 January 2015, 16:59:29 »
No problem here.
« Reply #20 on: Sun, 25 January 2015, 17:06:38 »
I think it's when You try to quote too fast.. too quickly after the person just wrote it..
so the serve doesn't know what you're quoting because the post is not in the system yet.
« Reply #21 on: Sun, 25 January 2015, 17:08:35 »
That makes absolutely no sense...
If you can see the post, then it's obviously in the system.
« Last Edit: Sun, 25 January 2015, 17:10:44 by Computer-Lab in Basement »
« Reply #22 on: Sun, 25 January 2015, 17:12:23 »
Not in the WHOLE system..
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #23 on: Sun, 25 January 2015, 17:17:11 »
Computers are way too fast for that to happen.
« Reply #24 on: Sun, 25 January 2015, 17:20:23 »
And is this conclusion based on your extensive knowledge of the GH servers and SMF?
« Reply #25 on: Sun, 25 January 2015, 17:27:43 »
Yes..
« Reply #26 on: Sun, 25 January 2015, 17:32:54 »
A freeze on quoting trolls would be a huge benefit to the forum.
« Reply #28 on: Sun, 25 January 2015, 22:11:10 »
GH's SMF implementation uses AJAX to copy the text from the post you are quoting.
It does this after you click the Quote button.
There is a slight delay whilst your browser sends the AJAX request to the server, then waits for the response.
Once the response is received, the browser places the text in the Quick Reply box with quote tags before and after, sets focus to that control, and then waits for your input.
(At least from my experience writing web applications probably something like this happens.)
If there is anything goes wrong or takes too long during that time, that might result in the delay.
I get this a fair bit, but usually put it down to my relatively poor internet connection.  Usually I need to reload that page and quote again before it will work properly.  Very rarely will it actually quote, even if I leave it waiting for 10 minutes or more.
