Author Topic: Building my Own Rice Cooker  (Read 3352 times)
« on: Sat, 07 February 2015, 03:31:53 »
So...  guys..
I've run into a problem with cooking ma wice..
The "Question"..
Which -microcontroller- controller would ya'll recommend that could control multi-stage induction coils  AND have room for multiple temp sensor feedback.
Also
If I could eventually narrow it down to just 1 set of coils and a few temp sensors..
--Which microcontroller would you recommend in "this" ^^^^ case..
Basically, Even if I get the liquid ratio perfect in theory..
The waterline will drop below the rice itself, which ultimately makes the bottom rice slightly m0re wet than the top rice..
So I've reasoned to build my own rice cooker as a fun project.
Super Thanks
  • Live long and prosper
Re: Building my Own Rice Cooker
« Reply #2 on: Sat, 07 February 2015, 19:44:20 »
pretty sure this sub is reserved for making keyboard things...
« Last Edit: Sat, 07 February 2015, 19:47:58 by Computer-Lab in Basement »
tp thread is tp thread
« Reply #3 on: Sat, 07 February 2015, 20:29:43 »
Offline dimmu
« Reply #4 on: Sat, 07 February 2015, 20:32:58 »
paleo master race.
Offline fendent
« Reply #5 on: Sat, 07 February 2015, 20:35:19 »
what kind of switches are you putting on that bad boy
Offline Mandolin
  • Crystal Connoisseur
« Reply #6 on: Sat, 07 February 2015, 20:35:44 »
Put a panic button in it.
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline jonathanyu
« Reply #7 on: Sat, 07 February 2015, 22:12:25 »
Offline engicoder
« Reply #8 on: Sat, 07 February 2015, 22:20:09 »
If you once use a Zojirushi, you will never want to use anything else. They are the best! I was given one by my sister about 10 years ago. I use it at least twice a week and it shows no signs of trouble.
Offline neverused
« Reply #9 on: Sat, 07 February 2015, 22:36:51 »
Google "arduino sous vide"  that may be a decent starting point
« Reply #10 on: Sat, 07 February 2015, 23:06:28 »
Yea.. I was considering the $1000 rice cooker with the clay pot insert thing...
But I Looked at that design and I think I can improve on it..
So..
you think arduino is enough for this ?   I need to control multiple sets of coils..
Offline neverused
« Reply #11 on: Sat, 07 February 2015, 23:09:51 »
The arduino should only trigger things. I'd use a relay shield or other shield to actually control things.
« Last Edit: Sun, 08 February 2015, 08:39:29 by neverused »
Offline hasu
  • @tmk
« Reply #12 on: Sun, 08 February 2015, 08:00:50 »
I don't think Atmel and Microchip know anything about rice. Renesas knows.
http://www.renesas.com/applications/consumer/home_appliance/ih_rice_cooker_high/index.jsp
Offline wolfv
« Reply #13 on: Sun, 22 February 2015, 17:17:12 »
Teensy-LC (low cost Teensy) 62K flash, 8K RAM $11.65, Release is scheduled for March 10th
pin-compatible with Teensy 3.0 and 3.1 http://www.pjrc.com/teensy/teensyLC.html
