Author Topic: HHKB Pro 1 case is really creaky, halp  (Read 2370 times)
Offline burn1nsun
    • My stupid YouTube Channel
« on: Thu, 26 March 2015, 13:19:09 »
It feels solid when typing on it, but when I press the sides it feels like there was a screw missing or something, does anyone know how to fix this?
feature=youtu.be#_=_
HHKB Pro 2 l Pok3r Gateron Blacks
Offline Valen
Re: HHKB Pro 1 case is really creaky, halp
« Reply #2 on: Thu, 26 March 2015, 21:34:24 »
Lubricating those creaky parts?
« Reply #3 on: Thu, 26 March 2015, 21:39:59 »
if it's out of warranty , take it apart and see what's up.
Offline hasu
  • @tmk
« Reply #4 on: Thu, 26 March 2015, 22:27:58 »
Ha, I found one of mine also croaks like frog :D
Code: [Select]
( >__< )
« Reply #5 on: Fri, 27 March 2015, 01:50:34 »
Code: [Select]
( >__< )
So hasu is confirming, this is "mcrip" effect.
Offline burn1nsun
« Reply #6 on: Fri, 27 March 2015, 11:04:28 »
I Fixed it really easily! Actually typing on it feels more solid aswell now!
Just by adding some paper slabs between the case in front and back, I havent cut em shorter yet, I have a feeling that they will fall inside the case when I do that, if someone has a better idea what to do than this then hit me with it!
Offline Valen
« Reply #7 on: Fri, 27 March 2015, 21:38:11 »
Use double sided thin foam tape instead of paper.
