Author Topic: What does this Mean ?? EE halp...  (Read 3576 times)
« on: Mon, 13 April 2015, 20:19:52 »
Line to Neutral :  122.0v - 122.2v
Line to Ground : 122.0v- 122.1v
Is ... Is this good ?
Offline ghostjuggernaut
Re: What does this Mean ?? EE halp...
« Reply #1 on: Mon, 13 April 2015, 20:28:21 »
Not sure what you are measuring, but it looks fine to me.
« Reply #2 on: Mon, 13 April 2015, 20:28:37 »
Lick it then get back to us.
« Reply #4 on: Mon, 13 April 2015, 20:31:50 »
I wanted to test if my ground is working right..  but I'm not sure what the difference in potential indicates.
I know my ground is hooked up to the water main in the basement...
ALSO......  since the lights didn't go out,   DOES that mean I don't have ground fault protection?
« Reply #5 on: Mon, 13 April 2015, 20:32:34 »
Well, how else are you going to tell if it's live and good?  And we all know it's the amps that kill you.  That many volts will just tingle, it won't do anything.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #6 on: Mon, 13 April 2015, 20:33:11 »
Tp4 reveals mysteries... grants deep perspective... builds the foundation of TRUTH...
« Reply #7 on: Mon, 13 April 2015, 20:34:51 »
Whoever said those things is truly honest and most wise..
« Reply #8 on: Mon, 13 April 2015, 20:38:09 »
To test your ground, you would want to go ground to ground.  In terms of ground fault, unless it is a GFCI outlet, you won't have protection.
« Reply #9 on: Mon, 13 April 2015, 20:40:42 »
Hrrrmmm.... so You mean I need a "very" long cord at 2 locations where I suspect different potentials?
« Reply #10 on: Mon, 13 April 2015, 20:42:34 »
Well, ground is ground.  So if you are measuring from ground to ground, the potential should be zero.  You would also need to be measuring resistance, not voltage.
« Reply #11 on: Mon, 13 April 2015, 20:43:07 »
Where from G2G..   same outlet? or from outlet to ground cable in basement
« Reply #12 on: Mon, 13 April 2015, 20:45:56 »
The easiest would be to test to separate outlets.  The best way to check it though, would be to go from the suspect outlet, to the main ground connection.  If you know how the wiring is laid out in your house, you could go outlet to outlet until you reach the main grounding point.
« Reply #13 on: Mon, 13 April 2015, 20:47:28 »
I know my main grounding point.. it's at the water main.. there's a shunt from the breakerbox to that main pipe
So ur saying.. I want to measure, "resistance"  from my suspect outlet,  TO the water pipe in the basement?
« Reply #14 on: Mon, 13 April 2015, 20:50:26 »
Yup.  You could do it at the shunt as well.  As long as there is ~0 Ω, then the ground is good.
« Reply #15 on: Mon, 13 April 2015, 20:53:21 »
Thx for the nfo GhostJug..
« Reply #16 on: Mon, 13 April 2015, 20:55:07 »
NP, hope you get it all sorted out.
Offline Novus
  • Mondai nothing~
« Reply #17 on: Mon, 13 April 2015, 20:58:40 »
You buy him cowpiss and ramen right now.
