Author Topic: Urg to build a new keyboard.  (Read 3485 times)
Offline luky7evens
« on: Sat, 02 May 2015, 10:31:54 »
I have recently had to urg to build an new keyboard but I need some help on were I can go to get supplies. SO if you guys could help buy suggesting were to get pcb switches and what not that would be greatly appreciated. Also would like recommendations on a good soldering iron since my radioshack on is dead.
Re: Urg to build a new keyboard.
« Reply #1 on: Sat, 02 May 2015, 10:32:50 »
step 1: read moar geekhack
Offline daerid
    • Rossipedia
« Reply #2 on: Sat, 02 May 2015, 10:37:44 »
I really hate doing this, but it bothers me to no end...
It's spelled "urge".
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Sat, 02 May 2015, 10:43:47 »
Urg is the sound I make before I yak.
And like metalliqaz said, just try to delve into the "Making Stuff Together" subforum to begin your learning process. You can also check out Group Buys to learn what parts go into certain custom builds.
Offline Defect
« Reply #4 on: Sat, 02 May 2015, 12:26:34 »
Cheapest way to get switches is to check the classifieds here.  And they are usually used, which is even better (worn cherry switches > new ones, unless you're talking blues).
Otherwise, I use MechanicalKeyboards.com
For PCB's, I like going with Korean Custom PCB's, so you would want to check classifieds and group buys for those.
Soldering equipment...make sure your iron has temp control (try not to spend less than $40 on it), and get a solder sucker.
« Reply #5 on: Sat, 02 May 2015, 16:18:07 »
Precisely my thought when I saw the title.
What is the compulsion for newbies to re-invent the wheel?
- D Trump 2026-10-24
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #6 on: Sat, 02 May 2015, 19:06:15 »
Welcome to geekhack.   You might be best off to start by modifying an existing keyboard rather than starting from scratch. There is a lot to learn and the experience will likely improve your choices on your ultimate board. It will also help you to know what specific questions to ask.
Nothing wrong with that as long as they keep the new version round.
Offline njbair
    • nickbair.net
« Reply #7 on: Sat, 02 May 2015, 19:27:56 »
In any discipline, one of the last things you learn is how little you know.
My boards:
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #9 on: Mon, 04 May 2015, 16:38:20 »
Offline daerid
    • Rossipedia
« Reply #10 on: Mon, 04 May 2015, 22:10:45 »
Don't you mean "Urgdox"?
Offline WolfTickets
« Reply #11 on: Tue, 05 May 2015, 21:34:11 »
I highly recommend the Hakko 888d soldering iron.  Read up on all this and know what you're getting into first.  Stuff stats adding up quick and will be more expensive than you thought it would be.
Offline daerid
    • Rossipedia
« Reply #12 on: Wed, 06 May 2015, 01:11:02 »
+1 on the Hakko 888
« Reply #13 on: Wed, 06 May 2015, 06:29:05 »
http://dictionary.reference.com/browse/Erg :P
Switches: 7bit, or check out the next Gateron group buy. I heard there might be one on Massdrop
Maybe some people who got in on an old one would have bought too many and would sell off some soon...
