Author Topic: Endgame HHKB  (Read 12875 times)
Offline IonutZ
  • Stay awhile and listen
    • SC
Endgame HHKB
« on: Thu, 07 May 2015, 09:28:10 »
I wanted to share with you guys my endgame HHKB :)
* Type-S Dampeners (O-rings)
* 55g Domes
* Novatouch Sliders
Still waiting to install:
* Hasu's BT Controller
* 2x 1600mah batteries
On the side:
* 3x sets of keys (Black & White Unprinted, Black Printed)
* Type-S Sliders
Current setup:
Offline JPG
  • Model F is my new passion!
Re: Endgame HHKB
« Reply #1 on: Thu, 07 May 2015, 09:32:52 »
I am not a Topre fan, but this keyboard is really nice! Good job!
Offline Dee1
Re: Endgame HHKB
« Reply #2 on: Thu, 07 May 2015, 09:40:02 »
Great-looking keyboard! :)
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Endgame HHKB
« Reply #3 on: Thu, 07 May 2015, 09:46:27 »
Great looking board! I'm planning to do something similar, I got 55g domes on hand, going to hop into the JT group buy for the sliders, and then I'm going to DIY silence them with Landing pads. And too finish it all off, a Hasu's controller. For probably my End game keyboard. (I shouldn't say that. I'll probably be buying more keyboards anyways...)
And maybe one day, that HHKB aluminium case if it ever comes to fruition.  :thumb:
Anyways Nice job on everything. Look great.
Offline azhdar
  • Praise the AZERTY god
Re: Endgame HHKB
« Reply #4 on: Thu, 07 May 2015, 09:51:14 »
Great board  :thumb:
Azerty Propagandiste
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #5 on: Thu, 07 May 2015, 10:00:10 »
Thanks guys :D
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Endgame HHKB
« Reply #6 on: Thu, 07 May 2015, 10:06:14 »
You flipped the entire bottom row? Interesting.
Looks awesome.
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #7 on: Thu, 07 May 2015, 10:11:36 »
Looks awesome.
Thanks! I found it a lot more natural for my thumbs with which I usually hit the bottom row.
Offline Air tree
Re: Endgame HHKB
« Reply #8 on: Thu, 07 May 2015, 10:12:09 »
Looks awesome.
Don't show demik this thread...  :))
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #9 on: Thu, 07 May 2015, 10:17:36 »
If you keep your wrists on the table then you'd have to bend your thumb to reach a CMD button that's not inverted... This way, my thumb is straight and I can easily hit the key with the second flange of my thumb as well, and with less than 1cm travel between CMD and Space... it's the best way to go.
Offline absyrd
  • CPT HYPE PADAWAN
Re: Endgame HHKB
« Reply #10 on: Thu, 07 May 2015, 10:22:36 »
stock hhkb = eg
Offline Air tree
Re: Endgame HHKB
« Reply #12 on: Thu, 07 May 2015, 10:41:49 »
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #13 on: Thu, 07 May 2015, 11:00:00 »
rektangle!
Offline FoC_Tow
  • Brokehlicious
Re: Endgame HHKB
« Reply #14 on: Thu, 07 May 2015, 11:52:29 »
* 55g Domes
* Novatouch Sliders
On the side:
* Type-S Sliders
Current setup:
Awesome board IonutZ! Thats one crazy hybrid HHKB you have going on there xD
Regarding your plans on adding bluetooth tho, Im wondering how you are planning on fitting two 1600mAh batteries and how you are planning on connecting two to hasu's controller?
With lithium polymer batteries afaik you could not just wire them up in parallel, nor use two (with half the voltage each) in series without using a balancer to make sure they get charged evenly.
Using two 1600mAh in series also would still result in 1600 (not 3200mAh), and using them in parallel is already not recommended for alkaline batteries and can potentially be very dangerous with lithium ones since one could charge/discharge the other to the point of damaging it or even starting a fire....
You can actually buy lithium polymer batteries configured in parallel, but these have been made from tested to be matching cells and its not recommended to DIY this and even splitting up one of those pre-made parallel ones could potentially unbalance it I think.
So I'm not saying this is impossible, but definitely make sure what you are doing as lithium polymer batteries as hasu mentioned can potentially be very dangerous.
Offline lookitdisnub
Re: Endgame HHKB
« Reply #15 on: Thu, 07 May 2015, 12:14:38 »
* 55g Domes
* Novatouch Sliders
On the side:
* Type-S Sliders
Current setup:
Having your HHKB blow up due to your batteries would be unfortunate
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #16 on: Thu, 07 May 2015, 12:21:43 »
Fair enough friends, I'll read more about balancing. I thought putting them in parallel would be fine.
Offline Lurch
Re: Endgame HHKB
« Reply #17 on: Thu, 07 May 2015, 12:28:45 »
Is there more "wiggle" with the novatouch stems vs the stock stems?
Quote from: Flyersfan1
Re: Endgame HHKB
« Reply #18 on: Thu, 07 May 2015, 12:32:44 »
Cherry on topre is topre blasphemy.
Offline Air tree
Re: Endgame HHKB
« Reply #19 on: Thu, 07 May 2015, 12:41:59 »
demik, man, the Topre world is expanding. Now all those Cherry mx users can never again say topre users don't have keycap options.
Anyways, it's what on the inside that counts, and on the inside it's still the same oneness with cup rubber.
Embrace the change, the times are changing.
Re: Endgame HHKB
« Reply #20 on: Thu, 07 May 2015, 12:49:52 »
I'm just grateful that the stock Topre caps are good enough that the lack of customization isn't a big issue
Re: Endgame HHKB
« Reply #21 on: Thu, 07 May 2015, 12:51:35 »
If we allow this, what next? Alps making a comeback? Cherry on bs? That's not the world I want to live in damn it. Our ancestors stood for something. NOT CHERRY ON TOPRE.
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #22 on: Thu, 07 May 2015, 13:04:43 »
hahaha. Purists these days...
Only the keys requiring stabs have a little more wiggle because the cylinder is slightly smaller. However, I had to drill holes left and right of the cylinder housing in order to get the stabilizers to pop out and allow the stem of the cherry caps to go in the housing.
Offline FoC_Tow
  • Brokehlicious
Re: Endgame HHKB
« Reply #23 on: Thu, 07 May 2015, 13:08:40 »
Glad if I could help IonutZ! =)
Kinda made me feel like a buzzkill bringing this up, but lithium polymer is usually more complicated and dangerous then one would think,
so Its kinda important to be aware of it as well.
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #24 on: Thu, 07 May 2015, 13:36:12 »
Yessir! I started reading about a balancer... well even a 1600mah will do. I bought a 3000mah (that's really slim) thinking I could fit it in. But figured out that 2 halves would work a lot easier.
Offline esoomenona
  • Gnillort?
« Reply #25 on: Thu, 07 May 2015, 13:37:38 »
« Last Edit: Wed, 12 August 2015, 16:05:41 by esoomenona »
Offline appleonama
  • Trollo en USA
Re: Endgame HHKB
« Reply #26 on: Thu, 07 May 2015, 13:46:27 »
55g, gross
flipped bottom row, ruined
Offline illitirit
Re: Endgame HHKB
« Reply #27 on: Thu, 07 May 2015, 20:06:38 »
Hey thats great man, I am about to attempt the novatouch slider mod in a few days on my hhkb
I am just curious though, is your spacebar using the novatouch stabilizers or are you still using your stock HHKB stabilizers?
The Topre standard spacebar size is not the same as cherry standard right?
Did you just leave the spacebar as stock?
Offline Latin00032
Re: Endgame HHKB
« Reply #28 on: Thu, 07 May 2015, 21:43:31 »
Is the spacebar dcs as well or is it the original topre spacebar?
If it's dcs, how did you install the stabilizers for it?
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #29 on: Thu, 07 May 2015, 21:59:03 »
The only thing on the hhkb that has housings is the space bar, so you could replace the spacebar if you wanted to. I however didn't have a 6 spacebar... the GH Nostalgia only came with 6.25 +
It wouldn't be an issue to replace stabs with novatouch stabs on spacebar though.
Offline KeypressGraphics
  • Dare to Dream
    • Keypress Graphics
Re: Endgame HHKB
« Reply #30 on: Fri, 08 May 2015, 07:23:37 »
ERGODOX
Why is there no ergonomic Topre keyboard in existence? There'd have to be a demand out there for one.
May all your key presses strike true.
  Choc Mini         HHKB
Re: Endgame HHKB
« Reply #31 on: Fri, 08 May 2015, 07:55:20 »
There is an ergonomic Topre. The uTron
Re: Endgame HHKB
« Reply #32 on: Fri, 08 May 2015, 08:03:16 »
Epic dude, congrats
Offline PieSauruS
Re: Endgame HHKB
« Reply #33 on: Fri, 08 May 2015, 14:01:09 »
First reply ever on this forum: Amazing :eek:
  • Dare to Dream
    • Keypress Graphics
Re: Endgame HHKB
« Reply #34 on: Fri, 08 May 2015, 16:46:26 »
Very interesting, I'd never heard of that keyboard before CPTBadAss. US$400+ isn't cheap!
  Choc Mini         HHKB
Offline esoomenona
  • Gnillort?
« Reply #35 on: Fri, 08 May 2015, 23:24:04 »
« Last Edit: Wed, 12 August 2015, 09:37:38 by esoomenona »
Offline Metr0
  • HHKB or nuttin
Re: Endgame HHKB
« Reply #36 on: Sat, 09 May 2015, 04:49:36 »
Looks awesome dude! Makes me wonder what I can do with my new HHKB...
[WTB] BLANK PINK HHKB ARROW CLUSTER
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #37 on: Sat, 09 May 2015, 11:18:11 »
Thanks guys :D Hasu's controller's about to go inside of it, and then I'll post some more pics!!
Offline tkim
Re: Endgame HHKB
« Reply #38 on: Sun, 10 May 2015, 07:53:01 »
Going with the BT controller?, I am eyeing that too.
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #39 on: Sun, 10 May 2015, 11:37:19 »
Totally man, this is my second HHKB with the BT controller. Just installed it yesterday, it is extremely dope. Pics incoming.
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #40 on: Mon, 11 May 2015, 17:38:53 »
Which one do we like better?!
V1
V2
Offline Air tree
Re: Endgame HHKB
« Reply #41 on: Mon, 11 May 2015, 20:17:40 »
V2 meshes better in my opinion!
Looking good.
Offline Latin00032
Re: Endgame HHKB
« Reply #42 on: Mon, 11 May 2015, 21:01:07 »
Did you use the type-s dampeners with o-rings?
Do the type-s dampeners work well with the novatouch stems?
Re: Endgame HHKB
« Reply #43 on: Mon, 11 May 2015, 22:39:27 »
V1
V2
Neither - the bottom row is broken on both of them.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: Endgame HHKB
« Reply #44 on: Mon, 11 May 2015, 22:40:17 »
V1
V2
QFT , the case of the HHKB is too high for the spacebar to be comfortably flipped
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: Endgame HHKB
« Reply #45 on: Mon, 11 May 2015, 23:02:55 »
V1
V2
2nd one!   1st one looks fancy w orange backspace, 2nd one looks sassy classical.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Endgame HHKB
« Reply #46 on: Mon, 11 May 2015, 23:17:28 »
I like v2
GON NerD TKL DTA Edition
Offline azhdar
Re: Endgame HHKB
« Reply #47 on: Tue, 12 May 2015, 01:30:36 »
V1
V2
V2.
If the 1u on the bottom row where orange that would be even better.
Re: Endgame HHKB
« Reply #48 on: Tue, 12 May 2015, 02:44:06 »
that bottom row is hideous wtf
Offline IonutZ
    • SC
Re: Endgame HHKB
« Reply #49 on: Tue, 12 May 2015, 08:05:23 »
Yes! Even though the novatouch stems are smaller than even the regular HHKB sliders.
To each their own lol. To me it actually makes sense the way I type.
V1
V2
V2.
I know but it didn't come with them :(
