Author Topic: Triple Monitor Setups (GPU)  (Read 2917 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« on: Tue, 19 May 2015, 20:01:51 »
About to buy three new monitors (ASUS VX238H-W) and am wondering where I should go GPU-wise? Right now I have a 760, but that's not gonna get me anywhere. I'd like to be running games on mostly high-quality above 50 FPS. I have a birthday in August so any GPUs that might be coming out around there would be great
Re: Triple Monitor Setups (GPU)
« Reply #1 on: Tue, 19 May 2015, 20:31:09 »
Halt...  DO NOT buy those monitors..
Buying 1 good 27"  is better than getting 3x "meh" monitors..
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #2 on: Tue, 19 May 2015, 20:35:34 »
but $280 doe...
« Reply #3 on: Tue, 19 May 2015, 21:00:08 »
but $280 doe...
ALSO.. . consider getting something like a large 1080p TV .. they make great monitors,
You do have to check that it supports 4:4:4 though..
The smaller triple screen "sounds good"  but give it time,  you'd wish You just gotten some bigger screens from the beginning..
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #4 on: Tue, 19 May 2015, 21:10:02 »
but $280 doe...
yea I dunno, the biggest things that put me off the triple are the bezels and having to buy expensive GPUs
Offline ShardZer0
« Reply #5 on: Tue, 19 May 2015, 21:16:57 »
but $280 doe...
I would go with a single curved 34" monitor over 3 monitors with bezels.
