Author Topic: Picture loading issues?  (Read 2437 times)
Offline tigersharkdude
« on: Mon, 01 June 2015, 12:04:14 »
Im having an issue that only affects this forum. Whenever I open a picture heavy page it always crashes and it will give me an Imgur error message or a Chrome error message. This happens on pc and mobile, it only happens on Geekhack.
Anybody else having this issue?
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
Re: Picture loading issues?
« Reply #2 on: Mon, 01 June 2015, 12:09:59 »
I have this problem when I'm using Chrome on my mobile. I usually use Firefox on my laptop and don't have any trouble there.
« Reply #3 on: Mon, 01 June 2015, 16:28:03 »
have you tried firefox.
I dislike Firefox, I always had loading issues with it (through 4 different computers).
« Reply #4 on: Mon, 01 June 2015, 16:30:32 »
Are you using an SSD or HDD ?
« Reply #5 on: Mon, 01 June 2015, 17:05:32 »
Both .. lol
SSD for OS and programs
SSHD for storage
and my phone is a Note 3
The issue is across devices, its not just on the pc or just the phone .. it's on both
« Reply #6 on: Tue, 02 June 2015, 05:21:48 »
I get that at work, but I put it down to a crappy work internet connection.
Seems to work much better at home.
« Reply #7 on: Tue, 02 June 2015, 08:55:00 »
maybe you got some weird antivirus..  or malware,  or bad dns...
I run Firefox on my OLD and slow x120e,   and everything works fine..
Probably a software issue..  but since it affects your mobile device, i'm thinking it's either ur ISP or your router..
Of course it could also be that you're on some sort of NSA watch list, and therefore they're screenin' ur stuff..
Been a bad.. boy..?
« Reply #8 on: Tue, 02 June 2015, 20:27:46 »
maybe you got some weird ... malware
Actually yeah, it doesn't work when I run Windows.
Works fine on Mac.
Offline tbc
« Reply #9 on: Tue, 02 June 2015, 20:30:26 »
if you have adblock on, disable it for geekhack.org
adblock on chrome completely trashes firefox when an image heavy page has to render.  i'm pretty sure it's doing the exact same thing in chrome.
