Author Topic: Please help me build my own computing rig  (Read 3658 times)
Offline vivalarevolución
« on: Wed, 21 October 2015, 22:11:19 »
I decided that I want to build my computing rig.  But I don't have a clue what I'm doing.  So I figure Geekhackers could help me build my own computing rig.  I know there are other forums where people can help me build my rig, but I like this place and figure lots of people here have built their own rig.  Any advice you could offer will help.  Feel free to call me a newb/buffoon/idiot/etc.
Here is what I want, in brief:
-make it as compact as possible
-have lots of the latest and greatest for future proofing/performance/just because (probably will be overpowered for my needs, I know)
-keep total cost under $1000 (don't know if that is realistic)
Here is what I have figured out that I want to buy:
Processor: one of those fancy new Intel 6th gen/Skylake quad core processors
Memory: 16 GB of DDR4 ram will do
Storage: 256GB MCIe SSD (will be supplemented with SATA drives for storage)
Motherboard: Mini ITX motherboard that is compatible with the above (should I just go with a Micro ITX so space/options aren't so constrained?)
Operating system: I plan on just running Linux rather than buying a Windows license, but wondering if Linux will have the proper drivers for the parts
-graphics card??
-smallest case possible
-fans and power adapter, but don't know which is which
-whatever the heck else that I need and have no clue that I need
I looked at barebones devices like the Intel NUC or Gigabyte Brix, but they fell short in performance and customizability.
I know that I could go cheaper with older tech that will be completely fine for my computing needs, but I want the latest and greatest if it is within my price range.  I went over to NewEgg and browsed around with some items, but I don't really know what I'm looking at, for the most part.
So what the heck should I buy?  Any suggestions?
« Last Edit: Thu, 22 October 2015, 09:51:50 by vivalarevolución »
Re: Please help me build my own computing rig
« Reply #1 on: Wed, 21 October 2015, 22:19:13 »
Also noticed this other thread and I've been taking a look:  https://geekhack.org/index.php?topic=75584.0
« Reply #2 on: Thu, 22 October 2015, 07:51:41 »
I'm not sure there are that many mcie + mitx boards..
Also,,  mitx is CUTE today,   but a HASSLE tomorrow..  Also, if you don't splice your own wires,   most mitx builds look like **** because the wires are too damn long..
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Thu, 22 October 2015, 07:53:35 »
Nobody has to see the internals.
« Reply #4 on: Thu, 22 October 2015, 10:02:21 »
Did you mean PCIe? A few of the motherboards seem to have slots for PCIE, but I'm not sure if those are only intended to connect wifi and graphics cards and not for SSDs.  I probably won't even notice the difference in speed between a Sata drive and PCIe drive, just like the form factor better.
Offline whentheclouds
« Reply #5 on: Thu, 22 October 2015, 10:26:17 »
the $1000 budget is severely lacking if you're aiming for the kind of specs described in your post. i guess it's possible if you're not purchasing a discrete GPU, but then there would be no point getting skylake and 16gb of ram if that were the case
as for the housing, check these out:
http://hardforum.com/showthread.php?t=1799326
http://hardforum.com/showthread.php?t=1832126
http://hardforum.com/showthread.php?t=1851126
« Reply #6 on: Thu, 22 October 2015, 11:05:21 »
Yea, that's what I figured.  So you're saying that I shouldn't worry about a fancy new processor or lots of ram if I don't have a discrete GPU?
« Reply #7 on: Thu, 22 October 2015, 11:12:33 »
Actually, I'm going to do some more research and lock this thread.   I may not need another project in my life right now. Thanks to those that have commented so far.
« Last Edit: Thu, 22 October 2015, 11:18:54 by vivalarevolución »
