Author Topic: Lubing everything..  (Read 6179 times)
Lubing everything..
« on: Wed, 16 December 2015, 05:54:22 »
Do you guys have this problem...
Like..  I just got this new bottle of this lube.. and I'm like putting it on everything that mechanically moves..
Even things that prolly doesn't need it..
For example, I completely took apart my stapler and lubed every moving part..
Then I took apart my wireless mouse and lubed the wheel..
Offline fanpeople
Re: Lubing everything..
« Reply #1 on: Wed, 16 December 2015, 06:01:36 »
I found a box of WD40 at work once. I proceeded to APPLY it to the hinge mechanisms of about 10 storage connexes just for the pleasure of that smooth opening action. Man i crave WD40 now.
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #2 on: Wed, 16 December 2015, 06:02:22 »
TP
Why are you the single weirdest, but yet most endearing person in off topic
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #3 on: Wed, 16 December 2015, 06:04:43 »
There is always time for lube.
Offline zombimuncha
« Reply #4 on: Wed, 16 December 2015, 06:18:35 »
WD40 is not lube. It's a "loosening agent." It has a lubricating effect when first applied but it goes away pretty quickly.
« Reply #5 on: Wed, 16 December 2015, 06:20:59 »
TP
I use up all-the-normal during the day when I have to talk to OTHER-people AFK..
« Reply #6 on: Wed, 16 December 2015, 06:23:57 »
xPERT  Information
Offline Leslieann
« Reply #7 on: Wed, 16 December 2015, 06:51:43 »
It's not a good idea to lube mechanical things that should not be lubed, especially if exposed to the environment.
For example your stapler is probably going to gunk up, and your mouse will probably die a tragic death due to the dust that gets trapped by the lube. A dry lube (graphite, wax based, etc...)  is a better option for exposed parts as it doesn't attract or retain dust. The dust, besides gumming things up, can also act as grit and cause increased wear. In a few weeks the hinge (or the mouse) may feel even more gritty and have more friction that even before you lubed it, and once that wear starts, it's a loosing battle from then on.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline jaffers
« Reply #8 on: Wed, 16 December 2015, 07:05:43 »
inb4 tp gets di** infection/allergic reaction because he used dry lube
« Reply #9 on: Wed, 16 December 2015, 07:06:27 »
hahaha..
I'm pretty sure the mouse is supposed to be lubed, otherwise it wouldn't already haz the lube on it..
The stapler perhaps..  but I do notice that all the moving mechanisms are "covered"
So dust buildup is going to be insignificant.
Offline VinnyCordeiro
« Reply #10 on: Wed, 16 December 2015, 07:20:42 »
« Reply #11 on: Wed, 16 December 2015, 09:10:46 »
tp4 is turning into mkawa.  :eek:  I swear, that guy lubed everything he could get his hands on.  :))
And yeah don't use WD40 for lube.  WD = Water Displacement.  It's great for getting into little nooks and crannies and cleaning things out, and technically does contain an oil which would lube things temporarily but it's not very long lasting and is very far from the ideal lube/oil in most scenarios.
Offline fanpeople
« Reply #12 on: Wed, 16 December 2015, 09:38:08 »
Myth: WD-40® Multi-Use Product is not really a lubricant.
Fact: While the “W-D” in WD-40® stands for Water Displacement, WD-40® Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
The website appears to hint that the formula contains lubricant. So although i understand what you are saying, part of that loosening effect is caused by lubricant
 therefore still relavent if you consider the lunrication of dirt for the purpose of removal as lubrication.
« Reply #13 on: Wed, 16 December 2015, 18:27:12 »
Hrrrm..............
I've used WD40 before, and it stops being "smooth" after only a few days..
But this may be because  I've used it in rusty situations where the rust would -re-gunk- ?
Not totes sure.
« Reply #14 on: Wed, 16 December 2015, 19:09:35 »
Hrrrm..............
Not totes sure.
I'm pretty sure it's all just fairly volatile components, so they evaporate quick.
Offline Leslieann
« Reply #15 on: Thu, 17 December 2015, 20:00:50 »
hahaha..
There's a reason they were lubed how they were (or not lubed), you didn't add anything except change the dynamics, and probably for the worst in the long run.
Being covered is like handing someone a hat in a rain storm, it might keep their head dry, but it's not protecting much else.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline retrochick
  • goodbye my wallet
« Reply #16 on: Thu, 17 December 2015, 22:40:11 »
I lubed my ball today... er that is my CST Trackball. It's now even more glorious.
Offline jerue
  • (Whenever that happens :P)
« Reply #17 on: Thu, 17 December 2015, 22:53:25 »
This is what happens when you start lubing everything.
Offline Connly33
« Reply #18 on: Fri, 18 December 2015, 17:53:26 »
I have this problem at times, i got some really good teflon based dry lube the other week for my bike that i acctually have a lubing schedule for..... but anyway i proceeded to lube anything that i could think of around the house that would benefit from a dry lube, like my electric shaver, some droor slider's, i acctually did lube the wheel on my corsair M90 because i love the way a smooth scrolling heavy scroll wheel feels. Then i ended pulling a few of my old box fans apart to clean and lube the brass bearing inserts, but they really did need it though i'm not sure if a teflon lube is best for that application. I usually use petroleum jelly on basic motor bearings and reapply fairly often.
Custom 60% with Cherry MX Clear
« Reply #19 on: Fri, 18 December 2015, 17:55:46 »
I've found that petroleum jelly dries too fast..
I think large fans need a higher viscosity lube because they're big and hot in operation.
Offline fanpeople
« Reply #20 on: Fri, 18 December 2015, 18:07:43 »
Fellow cst trackball user reporting in what did you use and was it for the rollers?
« Reply #21 on: Fri, 18 December 2015, 18:10:00 »
if it's low force and low heat,   all you need is a light oil..
Offline fanpeople
« Reply #22 on: Fri, 18 December 2015, 18:13:52 »
What about a synthetic lube like one they use for watches?
« Reply #23 on: Fri, 18 December 2015, 18:22:24 »
Yea watch oil would be fine.
Buhhhhh since you will be touching this stuff,    Do look at the chemical composition to check that its toxicity.
Ofcourse it's gonna say non-toxic on the box,  but long term exposure is different than, will it kill you on contact.
Offline fanpeople
« Reply #24 on: Fri, 18 December 2015, 18:36:09 »
But i have been seasoning ramen with it for years.
« Reply #25 on: Fri, 18 December 2015, 18:38:43 »
hahahahahahahahahahahahahaha
well, they make ramen on machines.. so theoretically, if you've eaten alotta ramen, you've eaten plenty of machine grease..
If it leads to an early demise, so be it.
Offline retrochick
  • goodbye my wallet
« Reply #26 on: Fri, 18 December 2015, 18:43:50 »
I used some leftover thick krytox mix lube for the rollers. But I imagine any synthetic oil should work.
Offline fanpeople
« Reply #27 on: Fri, 18 December 2015, 19:05:36 »
Cool thanks for the response, i will look at watch oil but i think it may cost a fortune (just guessing as i doubt a wattch requires much lube) i need to do the roller on my steel series sensi so can double tap that task
Offline retrochick
  • goodbye my wallet
« Reply #28 on: Sat, 19 December 2015, 10:31:52 »
You could also use some of that Super Lube pen from Amazon. I believe it's like $3.
Offline Bigpock
« Reply #29 on: Sat, 19 December 2015, 10:41:55 »
I have never lubed my keyboard before but i suppose the shift and enter key on my MX clears could use a little lube. Should i do it?
Offline jerue
« Reply #30 on: Sat, 19 December 2015, 14:25:01 »
modern clears and tactile greys feel a thousand times better with lube. DO EET
(no that's not an exaggeration. without lube it's scratchy and terrible)
Offline Connly33
« Reply #31 on: Tue, 22 December 2015, 05:44:17 »
I definitely should get something more purpose made next time i do it, or use something more like the high temp thick bearing grease i have laying around somewhere.
Offline kekstee
« Reply #32 on: Tue, 22 December 2015, 07:29:59 »
WD40 will make gunked stuff move again and can flush out dirt, but you have to lube it with something permanent after you cleaned and dried it.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #33 on: Tue, 22 December 2015, 13:51:00 »
I had this can of spray lubricant. Not wd40 but something else. Man that stuff was amazing. Sprayed in door knobs, car door hinges, a fan, and then afterwards the fridge's door.
Offline bcredbottle
« Reply #34 on: Tue, 22 December 2015, 14:06:03 »
Does the stapler feel any different now that you've lubed it?
« Reply #35 on: Wed, 23 December 2015, 09:51:46 »
The hinge is smoother.. and the magazine seems more responsive now that the inside's slippery-er.
