Author Topic: What happens to keyswitches when they reach/go over/ approach the 50M key press?  (Read 371419 times)
Offline knowsnokb
What happens to keyswitches when the reach/go over/ approach the 50M key press?
Do they just break?
Do the springs snap?
The plastic wear off?
The circuit breaks?
I would say most of the time switches that are good to start with, that is no problems from the factory, outlast the keyboards they are put into.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
The contacts probably wear out.
Offline 3K
They explode.
Offline Bucake
they vaporize
Probably almost half of the Apple Extended Keyboards (AEK "1") that I have bought have had 2-6 dead switches, but otherwise I have found dead switches to be rare.
Technically, I suspect that these would be better described as "broken" rather than "worn out" but there are many ways for a tiny assembly of half a dozen to a dozen parts to fail.
- D Trump 2026-10-24
Offline Rad
So did they have a robot push down on a key 50 million times?
Offline falkentyne
At 50,000,001, you had better stop or this happens....
Offline klennkellon
  • I like bottoming out
The Heat Death of the Universe.
Online Findecanor
For Cherry MX, I suppose that the leaf spring inside it will wear out: bend and possible break. No more circuit and no more tactility.
If it was a tactile switch, the feel should have been diminished already by that time though.
BTW, I have had the top housing break on a switch -- not much used though.
Switches can also wear being pressed all the time... and in case of Alps: suffer greatly from dust.
Offline njbair
    • nickbair.net
Food and medicine have expiration dates, but it's not like the milk turns sour at 12:01 a.m. That's just the latest the company is willing to sell it. I'm sure key switches last even longer than 50 million presses, but at that point any reasonable person is going to have to concede that they got their money's worth.
My boards:
I can imagine the leafs getting thinner and thinner until they just wear away.  But that would take many more than 50M presses.
Basically.. the keypress becomes inconsistent, chattering, or intermittent operation as the leaf spring wears out..
Offline jamster
It would take 10.7 years of non-stop typing at 70wpm to wear out the switch under the letter E (most common letter used in English). I'm pretty sure the keyboard would have been defenestrated well before approaching that limit.
you have to go outside and start talking to people
*shudders*
Offline Vittra
  • Airflow Optimizer
*shudders*
throwing my filco out, nothing is worth this
Filco MJ Linear R LE TKL
I think I did a calculation like this a couple of years ago.  CBF searching for it though, yours will do as an approximation :)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
I've never come across a broken switch due to just age, but like other people I'd have to assume the contact points would just degrade or the leaves would break in some way.
They actually do have a machine just to press the switches
Offline Blaise170
  • ALPS キーボード
    • XYZ
Offline piemancoder
They won't immediately magically stop working, the 50m measure is a very safe measure.
Was just about to link this video.
Yoda grammar best has
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
Maybe the Germans know?
Offline ander
  • I type, therefore I am
I had a Cherry MX blue quit on me once. Well, it didn't exactly quit. It stopped generating characters, that's true. But the strangest stuff did happen whenever I pressed it—for example:
  • Our doorbell rang.
  • All the automatic garage doors on our street opened.
  • Scarlett Johanssen called and asked me out for coffee. ("Aw, come on," she said, "it's just coffee!")
  • The Florida Panthers won the Stanley Cup.
  • A dozen NIB Space Cadets appeared on eBay for $100 each OBO (+ $17.50 shipping).
  • Some of the more Asperger-y people here on GH suddenly started getting my jokes.
Okay, I realize that last one was a bit of a stretch.
So testing for 50 million keystrokes - how long would that take?
Assuming 10 presses per second (which might be a bit high depending on how long the switch takes to return to rest), that is 5,000,000 seconds.
Which is around 57 days, 20 hours, 53 minutes, 20 seconds.
So about 2 months to test a switch?  Does that sound right?
The above video mentioned that some switches were tested to 100M presses - 4 months continual bashing?
Offline vincentk14
my friend once told me that his keyboard will reach 50M key press
he said he will press it until 50M key press and see what happening
after few days, some people in suit come to his house
and after that i never see him again
rumour said if you press the 50,000,001 times, you will get abducted and sent to area 51 for alien research
i miss my friend :-[
Offline Blaise170
  • ALPS キーボード
    • XYZ
50,000,001 - 000,000 = 51
Math checks out
Offline Malenky
This
Offline merlin64
    • MechMerlin
We should start a "50 million key press tour" in which we take one brand new switch and mail it to the list of people. Everyone who receives it has to press on it a number of times and post results haha.
When we get close to the last 100 presses, the last person needs to make a live feed so we can all watch. Once it reaches 50 million, everyone watching gets to bet on when they think the switch will break. All proceeds go to GeekHack, but the person who gets closest to the number of times before the switch fails, will have GeekHack buy them a keyboard of their choice using a portion of the proceeds. =).
Offline knowsnokb
Can't verify but I've heard they evolve to the switch of a different kind, like a Pokemon.
Depends how your pressed it over the course of its 50,000,000 presses.
Blues could turn to greens
cherrys could turn to topres
Really depends how you treated it
Still can't verify though.
Offline piemancoder
Is this how a Novatouch is made?
Offline Capnmycraw
The nova era of evolution.
Offline captsis
  • Formerly matt2dlg
I'd imagine BS have a rating as well, no?
Dunno about a rating - most of those keyboards are 25+ years old and still going strong!
A bit of discussion about it here.
Offline chyros
  • a.k.a. Thomas
25 M membrane, >100 M capacitive. It's not the springs or the plastic, it's the contacts.
Offline Zeal
    • Zeal Generation Inc.
Nothing happens, the switch continues to work. Companies realistically test the switch actuations way past 50M, then cut their results a bit to a nice round number.
Offline pr0ximity
Hall Effect have alledgedly been tested up to 30 billion keypresses, though how that could have veen done is a mystery I think.
Offline klennkellon
Maybe the Mormons know?  :))
