Author Topic: How do YOU fix a mouse switch?  (Read 7387 times)
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« on: Thu, 21 April 2016, 17:36:16 »
Seriously, how do you fix them? I spent the last 30mins cursing my clumsy fingers, and little pieces of metal were flying everywhere. I'm a mess lol, but the two Omron switches are like new now. I fixed mine by straightening out the metal that makes the clicky noise. Next time I'll either pay for new switches or buy a new mouse!  :)):blank:
Edit - Whoa, I posted this in the wrong section :-[
« Last Edit: Thu, 21 April 2016, 17:41:29 by csmertx »
Offline Olumin
  • "Guy walks into a doctor's office..."
Re: How do YOU fix a mouse switch?
« Reply #1 on: Thu, 21 April 2016, 18:13:01 »
I once fixed a RAT 7 mouse, one clicker was broken so I used a spare one from a old mouse I don't use any more and replaced it. It was more then fiddly, and took ages. These RAT mouses are of terrible quality, especially the metal which corrodes in a matter of a few months, therefore is was a pain to get the screws out and disassemble the thing.
« Last Edit: Thu, 21 April 2016, 18:15:12 by Olumin »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #2 on: Thu, 21 April 2016, 18:26:57 »
I've read a few things about the Rat mice. Mostly about unfavorable build quality, I think it would be cool to see a bunch of mice with the same kind of length/width adjustments though. I've had my Logitech Marble Trackman for a few years now, not the best trackball but I like it enough to open up the switches. Next time I'll do what you did haha
Offline Parak
« Reply #3 on: Thu, 21 April 2016, 18:34:38 »
I order new ones, desolder the old ones, and solder in the new ones :)
Got new omron switches on the cheap from ebay at $1 per a while back, and misread the spec sheet that they were lighter than usual... now my mouse buttons are extra trigger happy :p
« Reply #4 on: Thu, 21 April 2016, 18:52:02 »
You can get old high-quality ball mice at the 2nd-hand store for $1 and harvest good switches from them.
- D Trump 2026-10-24
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #6 on: Thu, 21 April 2016, 19:47:03 »
you need at least 1 tweezer.
The metal on the first switch flew off and thankfully landed on the desk. I used tweezers on the second switch haha. I should have worn some gloves though. I didn't take into account all of the oils I might leave behind
Offline Leslieann
« Reply #7 on: Thu, 21 April 2016, 20:23:41 »
You just delayed the inevitable.
The spring bent because it weakened, when you bent it back, yes, it straightened, but you also weakened it more.
Get some new switches on order quick before they die again. If you can get the Japanese made Omrons instead of Chinese, do that, they last longer.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #8 on: Thu, 21 April 2016, 20:56:28 »
Luckily my logitech trackball has become my backup mouse. Thank you, I had a feeling that bending a little piece of metal was not going to resolve the issue. I have another cheapo wireless mouse that has life in it still that I could use if the trackball fails.
I've read that the Ducky Secret mouse has Japanese Omron switches. Perhaps I could give that mouse some thought :)
Offline Leslieann
« Reply #9 on: Thu, 21 April 2016, 21:35:06 »
Probably wasn't what you wanted to hear, but at least now you know.
Some mice are easier to change than others, the construction of the Logitech G700 series makes it quite difficult.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #10 on: Fri, 22 April 2016, 03:13:15 »
Solder Newb....
Offline Leslieann
« Reply #11 on: Sat, 23 April 2016, 01:55:37 »
Solder Newb....
It certainly made feel like one.
14 hard pins connect the upper deck to the lower deck, all with ROHS solder, they're very close together, so not only is it hard to get a sucker on there good, but even if you do, the other pins suck the heat out almost as soon as you put it in. I've tried three different solder suckers (one with a built in heater) and have yet to separate them without doing damage. I killed one mouse and I'm trying to be more careful and get it right on the second.
I think I found a way though, cut the pins, and replace them with wires.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #12 on: Sat, 23 April 2016, 03:46:45 »
I think I saw a russian video where the guy used the Chipquik...  Kinda cheating, but i mean,, it works... so.. hahahahaha...
Russians got the best soldering skills on youtube.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #13 on: Tue, 26 April 2016, 04:23:34 »
This is how you fix your mouse switch http://goo.gl/uIeQKg or you know just replace the switch.
