Author Topic: i-rocks is working on their own switches  (Read 7927 times)
Offline plainbriny
« on: Mon, 23 May 2016, 18:31:53 »
As already mentioned in the ALPS appreciation thread, i-rocks is working on their own switches.
https://uccu.cool3c.com/projects/266
This is a Chinese page, but there are many figures and videos.
They have made 4 types of switches:
137780-0
I am interested in their light linear switch (詭軸).
I don't know how to translate the name: strange? weird? unpredictable?
This is an ultra light switch less than 30g.
137778-1
They should reveal their products in the next couple days.
« Last Edit: Mon, 23 May 2016, 19:33:42 by plainbriny »
Offline alexjd99
  • oozing through the cells of one's own construction
Re: i-rocks is worksing on their own ALPS compatible switches
« Reply #1 on: Mon, 23 May 2016, 18:51:55 »
Looks interesting, but I think they're MX Compatible "alps" switches.
If that's the case I hope they'll have the switches alone, I'd love to make a custom build with these ;D
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Mon, 23 May 2016, 18:59:09 »
They're very different in construction to Alps switches, but they're intriguing nonetheless. If I can buy a few loose ones I'll happily get a few to try them out :) .
Offline jacobolus
« Reply #3 on: Mon, 23 May 2016, 19:15:03 »
Can you change the title here? There’s nothing “Alps compatible” about these. They don’t have a single Alps-interchangecable part, they don’t work with Alps keycaps, plates, or PCBs.
Maybe “Alps-inspired MX-compatible switches”, if you want to push it.
Offline plainbriny
Re: i-rocks is working on their own switches
« Reply #4 on: Mon, 23 May 2016, 19:33:25 »
Title changed as suggested.
However I think the word "compatible" here refers to different aspects:
Key cap compatibility and pin/form factor compatibility.
I believe their PCB pin connection and form factor is not compatible with MX.
Offline QuincyJones
SENT FROM MY TRKA-100-ULTRA-PRO-1R WITH FLASHY MULTI-COLOURED LEDS FOR MEGA ULTRA COOLNESS
(please like me)
Offline supamesican
« Reply #6 on: Mon, 23 May 2016, 20:18:10 »
I want to try them so bad
Offline jacobolus
« Reply #7 on: Mon, 23 May 2016, 20:18:21 »
“OMG, peanut provincial magic, feel this change is amazing .......”
Offline plainbriny
« Reply #8 on: Mon, 23 May 2016, 20:25:11 »
Actually I was thinking whether their switches will work with infinity ergodox, because I can't type on regular keyboards efficiently now.
But it seems there's no plan to release individual key switches any time soon, it will be long before we ever know the answer.
Offline jacobolus
« Reply #9 on: Mon, 23 May 2016, 20:31:15 »
Clicky switch seems promising. The tactile switch looks a bit too MX-brown-like (even with the higher-in-the-stroke actuation point) for my taste.
« Last Edit: Mon, 23 May 2016, 20:33:12 by jacobolus »
Offline plainbriny
« Reply #10 on: Tue, 24 May 2016, 07:43:57 »
They have updated the above page and released what the keyboard look like....
137815-0
So that's why they call this keyboard 'fun'
« Last Edit: Tue, 24 May 2016, 07:55:04 by plainbriny »
Offline saxophone
« Reply #11 on: Tue, 24 May 2016, 07:50:53 »
Total travel 4mm
Nyeh
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #12 on: Tue, 24 May 2016, 07:55:08 »
Switches do look interesting. Hopefully they become available individually in the future.
Offline FoxWolf1
  • 154
« Reply #13 on: Tue, 24 May 2016, 08:29:57 »
*shrug* I like it.
And before the minimalists get all upset, it's worth noting that you could put a normal upper layer on it if you wanted:
Offline MOZ
  • Busy making stuff
« Reply #14 on: Tue, 24 May 2016, 10:17:34 »
Switchable top layer is a fresh concept.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15 on: Tue, 24 May 2016, 10:27:11 »
Appears to have a standard bottom row, that was a smart move imo
Offline Data
« Reply #16 on: Tue, 24 May 2016, 11:41:54 »
Offline Lepidus
« Reply #17 on: Tue, 24 May 2016, 11:47:38 »
That actually looks pretty nice.
I wonder if the switches are plate compatible with cherry or alps. The switch "feet" also seem a little bit different from cherry and alps, hope they are compatible with any already avalible PCB.
« Last Edit: Tue, 24 May 2016, 11:56:38 by Lepidus »
Offline Data
« Reply #18 on: Tue, 24 May 2016, 12:00:30 »
Just eyeballing it from the drawings, it looks like they have similar pin placement to ALPS but they also have the classic Cherry center mount stem.
i-rocks
Alps SKCL SKBM
I liked this image especially.  Their o-ring method is pretty creative.
Offline MOZ
  • Busy making stuff
« Reply #19 on: Tue, 24 May 2016, 12:51:31 »
Perfectly designed to go with the MX-Alps boards we are seeing more often now; MX mount, centre stem and RGB LED pin holes, Alps style mounting and hopefully similar clicky switches.
Offline KRKS
  • Your friendly neighbourhood umbrella
« Reply #20 on: Tue, 24 May 2016, 14:18:31 »
Total travel 4mm
Nyeh
Yeah, pretty much. Although they still could turn out to feel good, especially the "seeing mouth standing on sun" ones. ;-P
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline plainbriny
« Reply #21 on: Tue, 24 May 2016, 17:37:56 »
It take me several minutes to figure out that "seeing mouth standing on sun" refers to the blue "韻" version... I think "rhythm" could be a plausible translation for that word.
So it should work with infinity ergodox... Wondering whether they would release the individual switches eventually?
« Reply #22 on: Tue, 24 May 2016, 19:04:19 »
Hrrrrm..... Ok.. so advantage orings..
Good stuff, good stuff...
Hrrrmm... If we got these switches and 1.5mm actuation.. that would make my day.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #24 on: Tue, 24 May 2016, 19:23:27 »
i-rocks
Alps SKCL SKBM
is this plate mountable ?
Yea, from the looks of the diagram there's a little tab or hook that's meant to clip into the plate. It's near the "Mountion Panel"
Offline Data
« Reply #25 on: Tue, 24 May 2016, 20:41:24 »
i-rocks
Alps SKCL SKBM
Yes, the elusive Mountion Panel.  I think this might be an industry first.
Offline jacobolus
« Reply #26 on: Wed, 25 May 2016, 05:06:29 »
Pretty clearly needs its own mounting plate, not compatible with either MX or Alps. Also, with the LED leads sticking down and silly MX-style plastic stem, it looks like it’ll need its own PCB.
« Last Edit: Wed, 25 May 2016, 05:15:47 by jacobolus »
Offline jacobolus
« Reply #27 on: Wed, 25 May 2016, 05:08:53 »
Actuation point is apparently about 1.9mm. But the tactile drop comes at ~1.3–1.8mm on the MX-brown-ish quiet tactile switch. I doubt you can too easily get past the tactile point without actuating the switch, unless you deliberately try.
« Last Edit: Wed, 25 May 2016, 05:13:19 by jacobolus »
Offline MOZ
  • Busy making stuff
« Reply #28 on: Wed, 25 May 2016, 06:05:51 »
Yeah, plate looks to be slightly different, 15.4x13.3, not sure about their tolerances, it might just fit in to the hybrid MX+Alps switch holes. About the LED leads, I'd imagine the design would be so they are easy enough to remove, making them usable with PCBs having MX+Alps support. Lots of speculation.
Offline plainbriny
« Reply #29 on: Wed, 25 May 2016, 07:16:07 »
The 4 pin leds are RGB leds. Single color 2 pin leds should fit with most boards. These leds should be fairly easy to remove from the switches.
I assume they will work with infinity ergodox PCB, because the PCB already have holes for MX stem and 2 pin leds. Of course, the plate/case may not fit, but I think this should be easily fixable.
