Author Topic: Gahh... Wifi is so Laggy  (Read 3244 times)
Re: Gahh... Wifi is so Laggy
« Reply #1 on: Tue, 26 July 2016, 16:18:44 »
What router/AP are you using? I have an 802.11ac router (TP-LINK Archer C7), and my wifi speeds are great.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #2 on: Tue, 26 July 2016, 16:19:54 »
802.11AC is pointless unless you're using the A radio for meshing/bridging..
« Reply #3 on: Tue, 26 July 2016, 16:27:39 »
2.4GHz is so crowded around here. :|
And my previous n router was only 150 Mbps.
Offline digi
  • elite af tbh
« Reply #4 on: Tue, 26 July 2016, 16:29:29 »
If your devices support 5Ghz (A radio), use it. Enterprise-level AP's have band-steering so it will automatically move clients to the A radio (if they support it) just for that very reason.
« Reply #5 on: Tue, 26 July 2016, 17:50:37 »
My throughput is fine... I can get upwards of 10MB/s across the house.. But the latency is still there, it doesn't FEEL snappy..
Whereas,  Wired is like,  Click.... Boooom...
« Reply #6 on: Thu, 28 July 2016, 00:07:41 »
Every time I click something. I feel like the click is not traveling as a smooth signal..
As if it's going through space at a different rate and getting back to me at a different rate..
Offline MykB77
« Reply #7 on: Fri, 29 July 2016, 23:08:04 »
Were you eating a rice crispy square?
Sent from my SGH-I337M using Tapatalk
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #8 on: Fri, 29 July 2016, 23:11:59 »
I had some really odd issues with latency in games and my torrents or high downloads in general locking up the usb devices on the computer. It took some experimenting but eventually swapping out my wireless card did the trick. I ended up grabbing this guy off amazon and i'm extremely happy with it: https://www.amazon.com/gp/product/B00JDVRCI0/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
-Dana
« Reply #9 on: Fri, 29 July 2016, 23:45:06 »
Haha
Yea, some cards on some systems cause high dpc latency which leads to stuttering.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #10 on: Sat, 30 July 2016, 01:34:57 »
[SOLVED]
next..
