Author Topic: Verifying the authenticity of Gateron (black) switches on a board...  (Read 4457 times)
Offline Row009
Hi,
I just placed an order for a generic board with Gateron black switches from china;
However I would like to make sure the switches are indeed Gateron's originals.
There is a at least one store that I know of that sells only tops of Gateron switches (https://zealpc.net/products/gateron) - which can imply companies may place Gateron tops on other types of switches.
Do you think Gateron switches are often counterfeited?
How can I be sure they are genuine?
Offline Geroximo
Re: Verifying the authenticity of Gateron (black) switches on a board...
« Reply #1 on: Fri, 19 August 2016, 06:04:37 »
No.
« Last Edit: Fri, 19 August 2016, 06:08:52 by Geroximo »
Offline kawasaki161
« Reply #2 on: Fri, 19 August 2016, 06:39:20 »
Looking at the price you can get Gateron switches at I don't think it would even remotely be worth it to use other switches and put Gateron tops on them.
Offline klennkellon
  • I like bottoming out
« Reply #3 on: Fri, 19 August 2016, 10:20:10 »
I've never heard of fake Gaterons before, I'm pretty sure you're safe.
Offline sony
  • Formerly ultraidiot
« Reply #4 on: Fri, 19 August 2016, 15:16:57 »
Maybe he got the cherry blacks that were swapped out for those "cherry" yellows. Lol
« Reply #5 on: Sun, 21 August 2016, 15:23:13 »
Hahahahaha
I think you're pretty safe..  Don't worry bro... no one is counterfeiting gaterons..
