Author Topic: MX clear or black for responsive spacebar  (Read 2510 times)
Offline AMongoose
  • happy workman user
« on: Mon, 22 August 2016, 08:14:21 »
I have a zowie celeritas with MX browns that I really enjoy but don't use much because the spacebar doesn't go back up very quickly.
I'm thinking about replacing that switch with a heavier one to try and solve the problem.
So what would be best? Mx Clear, Black or something else entirely?
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
Re: MX clear or black for responsive spacebar
« Reply #1 on: Mon, 22 August 2016, 09:35:29 »
are you sure everything is ok with your spacebar?
I have browns on most of my spacebars and it comes up very fast - I type 110+ wpm with no problems with a brown on the space.
Otherwise, clear would be the natural choice as it's tactile where as black is not.
I got boards.
« Reply #2 on: Mon, 22 August 2016, 10:28:25 »
I think probably the space cap stems arn't aligned out of the mold, leading to some tension in the stabilizers.
try to lube the stabilizers, any grease will work,
Offline mathilda
« Reply #3 on: Mon, 22 August 2016, 13:59:47 »
Try another space cap first. Maybe something wrong with your cap (e.g mounts aren't aligned correctly)
Offline Tactile
« Reply #4 on: Mon, 22 August 2016, 14:05:10 »
It seems that Zowie might have persistent spacebar problems - it must have something to with fit or setup.
http://www.teamliquid.net/forum/tech-support/441089-zowie-celeritas-squeaky-spacebar
https://geekhack.org/index.php?topic=16624.0
REΛLFORCE
Offline quake4mhg
« Reply #5 on: Mon, 22 August 2016, 14:32:37 »
I use cherry mx black on my spacebar & Function keys on both office (brown)/gaming (red) keyboard at home :)
Offline klennkellon
  • I like bottoming out
« Reply #6 on: Mon, 22 August 2016, 14:42:38 »
MX Blacks are really springy, they kind of "launch into orbit" if you release them quickly.
Offline AMongoose
« Reply #7 on: Mon, 22 August 2016, 16:01:58 »
It doesn't really interfere with my typing, it comes back up just after the actuation point quickly but then slows down, it's kind of annoying but it works. But I type at 40wpm not 110  O.O
Upon closer look it seems the whole spacebar is warped making it slightly convex D:
Using another spacebar really makes it better but it's still not as springy as my other keys. I'll also try lube it.
Offline Dihedral
  • Mostly Harmless
« Reply #8 on: Mon, 22 August 2016, 16:46:55 »
A hairdryer and a heavy book can straighten a spacebar quite effectively if you're careful.
