Author Topic: Idea of a new hack.  (Read 4311 times)
Offline Eszett
Idea of a new hack.
« on: Fri, 26 August 2016, 00:24:48 »
I clipped the pastic part of the cherry stabs that hold the wire and therefore the wire can move around more freely. I have the impression the type feeling improved, since the rebound time is less. When you press spacebar it immediately rebounces, not that sluggish anymore! A general problem is, that the wire may fall out. However, at my spacebar the keyboard case is so narrow, that it prevents the wire from falling out.
* I'm reffering to the blue part on the picture..
« Last Edit: Fri, 26 August 2016, 00:33:57 by Eszett »
Offline jaffers
Re: Idea of a new hack.
« Reply #1 on: Fri, 26 August 2016, 00:44:18 »
I can't believe you chopped it off
Offline Eszett
« Reply #2 on: Fri, 26 August 2016, 00:49:51 »
Why not, I have a bag full of stabs..
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Fri, 26 August 2016, 03:31:17 »
Tbh the one thing I really love about Cherry is their stabilisers, they absolutely ****ing nailed that design. It stabilises perfectly, it's durable, easy to take the caps off and put them back on, it's fantastic.
Offline jcoffin1981
« Reply #4 on: Sat, 27 August 2016, 10:23:32 »
I have seen this procedure done, but only the ends of the blue line were clipped, not the entire piece so there was a little edge to prevent the wire from sliding out.  People say it improves the feel, but I was worried it would introduce wobble.  If this is an improvement then why weren't the stabilizers designed this way?  If it's clean and well lubricated there is almost no friction.
« Reply #5 on: Sat, 27 August 2016, 11:33:56 »
No, Cherry stabs are inferior to Costar..
Costar is just better engineered,  low contact surface,  CHEAP to produce, Smoother in operation
Cherry stabs may have the properties you mentioned,  but they're too damn german, over-engineered,  more sensitive to keycap warp, overall, they're also significantly more fricative..
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Sat, 27 August 2016, 12:40:24 »
That's not really an issue with keys you have to stabilise, though Oo .
Offline y11971alex
  • Looking for Toronto meetup
« Reply #7 on: Sat, 27 August 2016, 13:21:22 »
Offline Eszett
« Reply #8 on: Sat, 27 August 2016, 21:37:24 »
Quote from: tp4tissues
Ye, they are definitely more fricative, that is why I clipped the blue part :-) I can affirm it removes friction, so it's an improvement. But you must go sure, that the wire doesn't fall out, for example by a very narrow space between wire and keyboard case walls.
« Last Edit: Sat, 27 August 2016, 21:51:50 by Eszett »
Offline klennkellon
  • I like bottoming out
« Reply #9 on: Sun, 28 August 2016, 15:12:29 »
I agree, I love working with Cherry stabs even if they're a bit mushy. Costar are rattly and annoying to work with.
« Reply #10 on: Sun, 28 August 2016, 16:39:53 »
You're totally just Jelly all the cool kidz roll them Costars.
Offline klennkellon
« Reply #11 on: Sun, 28 August 2016, 17:09:00 »
The best stabilized keys I've ever come across are the ones on my SKCL Brown board, they don't rattle at all and go down buttery smooth. I think they're lubed out of the box.
« Reply #12 on: Sun, 28 August 2016, 17:21:10 »
There's an element of LUCK,  to all keyboards,
Because long key caps Warp.. happens all the time..
Costar is not very sensitive to slight warp.
So, even if there's a litttle-extra wobble,  I'd say that's worth the trade off for Smooth operation.
Offline jcoffin1981
« Reply #13 on: Wed, 31 August 2016, 12:15:05 »
I like
wobble
I actually have never used a board with costar stabilizers, so I can't say if they are better or worse.  I understand it can be a pain to insert or remove a keycap with this satabilizer though.
