Author Topic: What Zoom Do you guys browse Geekhack @..  (Read 5322 times)
« on: Thu, 15 September 2016, 15:41:11 »
Tp4 browses Geekhack @ 160% zoom..
Monitor Size, 30"
Monitor Resolution, 1280x800
Viewing Distance, 1.3 meter, 4.2 Feet
Offline joey
Re: What Zoom Do you guys browse Geekhack @..
« Reply #1 on: Thu, 15 September 2016, 15:44:12 »
150%
Glad I'm not the only one.
Offline mike52787
  • Alps Aficionado
« Reply #2 on: Thu, 15 September 2016, 15:44:38 »
100%, yall are so blind
Offline deductivemonkee
  • Professional Lurker
« Reply #3 on: Thu, 15 September 2016, 15:45:55 »
100% and I'm blind af
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
Offline xondat
  • i'm not a star
« Reply #4 on: Thu, 15 September 2016, 15:48:58 »
why would you not use 100% wtf
Offline trizkut
« Reply #5 on: Thu, 15 September 2016, 15:49:48 »
160% zoom AND obnoxiously large font? are you sure you're not blind?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #6 on: Thu, 15 September 2016, 15:50:51 »
75%
Offline meiosis
  • Time
« Reply #7 on: Thu, 15 September 2016, 16:11:57 »
67% I hate scrolling
Keyboards:
Aripeko TKL
« Reply #8 on: Thu, 15 September 2016, 16:14:33 »
« Reply #9 on: Thu, 15 September 2016, 17:05:57 »
It depends on how close ya'll sit to your screen too though..
Tp4 @ 1.3 meters, 4.2 feet.
Offline xondat
  • i'm not a star
« Reply #10 on: Thu, 15 September 2016, 18:10:14 »
True, I'm like 50/60cm away... Probably bad but my room is tiny.
Offline mike52787
  • Alps Aficionado
« Reply #11 on: Thu, 15 September 2016, 19:16:43 »
Why not invest in a better monitor Tp? you can buy brand new 1920x1080 24" monitors for less than 100$.
« Reply #12 on: Thu, 15 September 2016, 19:37:03 »
It's a 3007wfp.
I just run it at 1280x800, because windows 7 does not play nice with Dpi multiplication
Offline mason
  • have fun with her, ryan
« Reply #13 on: Thu, 15 September 2016, 19:51:38 »
27" monitor
2560x1440
100% zoom
viewing distance ~3.5 ft
Offline mike52787
  • Alps Aficionado
« Reply #14 on: Thu, 15 September 2016, 19:53:59 »
It's a 3007wfp.
Do you think it could be your video card drivers? I never had any issues running a monitor at 1080 in win 7.
« Reply #15 on: Thu, 15 September 2016, 20:00:39 »
It's a 3007wfp.
The OS itself scales fine,
But many applications as it works in Win 7 will not render properly with increased dpi
« Reply #16 on: Thu, 15 September 2016, 20:00:53 »
27" monitor
2560x1440
100% zoom
how could you see the small text.
Offline Leslieann
« Reply #17 on: Thu, 15 September 2016, 20:03:29 »
Dual 25inch screens, each 1920x1080 @100%
I'm usually about an arm length away, I don't really like it any closer (obviously this only works on desktops).
That's a driver (or firmware) problem, Win7 can use any resolution supported by the card.
My last laptop had that resolution (12in screen with Intel graphics!), Win7 was fine. Linux on the other hand struggled with the scaling. It was a factor in why I sent it back.
« Last Edit: Thu, 15 September 2016, 20:09:49 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #18 on: Thu, 15 September 2016, 20:14:14 »
It scales everything except many of the back water programs I use..
Not gonna say what those are..  I'm embarrassed..
Offline mason
« Reply #19 on: Thu, 15 September 2016, 21:53:19 »
27" monitor
2560x1440
100% zoom
20/20 I guess and I like small text
« Reply #20 on: Fri, 16 September 2016, 06:10:17 »
125% on surface pro 3, 100% on computer though 110 is comfortable as well.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #21 on: Fri, 16 September 2016, 06:57:14 »
HD, 100%
Offline Coreda
« Reply #22 on: Fri, 16 September 2016, 07:03:10 »
I knew you had a 1280px wide resolution but with a 30 inch display? I wasn't aware they even made monitors that resolution/size, unless of course it's a TV.
Has to be a TV.
For me it's 100% zoom on a 27" 1440p monitor but the AG filter is too strong which can cause a bit of eyestrain. I actually prefer a smaller DPI.
« Last Edit: Fri, 16 September 2016, 07:08:45 by Coreda »
Offline AMongoose
  • happy workman user
« Reply #23 on: Fri, 16 September 2016, 08:11:05 »
100%
1080p 13.3'' screen at about 70cm away.
Y'all blind.
Offline dgneo
  • Supervillain
« Reply #24 on: Fri, 16 September 2016, 08:15:17 »
27" 1080p @ 100% from ~3ft away
Offline joey
« Reply #25 on: Fri, 16 September 2016, 08:23:25 »
pls go away and get ready
« Reply #27 on: Sat, 01 October 2016, 06:18:54 »
At home 24" monitor, 1920x1200, 100%, arm's length away.
« Reply #28 on: Sat, 01 October 2016, 08:18:32 »
100% at 102 PPI, arms length away.
I find the text in the forum to be of the perfect size.
Offline MrRooks
  • Always be knolling
« Reply #29 on: Tue, 04 October 2016, 15:54:49 »
27" display at 2560x1440, distance is 30" I always view at 100%.
« Reply #31 on: Fri, 07 October 2016, 08:58:02 »
tp needs glasses
Tp already wears thick glasses..
Too much Diablo in highschool..
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #32 on: Fri, 07 October 2016, 09:51:20 »
1600x900 100% good sir. Windows 7, 10, Debian, and Mint. Arm's length
Offline mike52787
  • Alps Aficionado
« Reply #33 on: Sat, 08 October 2016, 18:14:27 »
Recently changed to 90% when I went back to 16:9... feels good man
