Author Topic: Xiaomi/Yuemi Mechanical Keyboard 87 keys  (Read 10612 times)
Offline mick
    • MickBenjamins.com
« on: Sun, 23 October 2016, 18:30:19 »
Hi, Fellow MIUIers,
Mi Home has released Yuemi Mechanical Keyboard in home.mi.com priced at 299 Yuan.The keyboard comes in a white polycarbonate shells that’s backed by an aluminum shell. The inclusion of an aluminum shaft on the inside, however, takes its toll on the weight. The keyboard is quite heavy at 940g. That’s nearly the weight of the 12 inch Macbook Pro.
Nevertheless, the sole aim behind it is to make the keyboard sturdy so that it can survive occasional falls. Yuemi claims that the aluminum frame on the inside has undergone anodized surface blasting that results in a surface hardness of H32. The keyboard is designed to be ergonomic, sporting a stand that props it up to an angle of 6° preventing your hands from aching wen using it for long hours. Its key caps are made of translucent poly-carbonate + ABS resin white color design. The characters printed on the keys are wear resistant and the caps can be replaced, allowing owners customise it to their preference.
The TTC Red Switches can withstand up to 50.000 hits and is suitable for gaming. There is also a 32-bit ARM architecture STMicroelectronic master chip on board with a 1000MHz refresh rate, 1ms response time and support for up to 11 key presses without contradictions.
Up front, the Yuemi Mechanical keyboard packs a total of 87 keys that in turn made up of a combination of polycarbonate and ABS resin. It packs a classic red axis arrangement of keys thereby resulting in an effective life of 50 million hits. The keys have been aptly placing too with a thin line separating one from the other. That aside, there’s LED backlighting too for typing in challenging lighting situations. Yuemi claims that their Yuemi mechanical keyboard comes with 3528 LED lamps that have a color temperature of 6500K and six-speed luminance. Apart from that the Caps Lock, Scroll, and Win keys come with a two-tone orange and white backlight.
The Yuemi Mechanical Keyboard can be connected to any devices especially PC and laptops is priced on the higher side at 299 Yuan ($45 approx.) That said, with the rock solid built and backlit keys, it indeed calls for such a price tag. The product is now available for sale on Xiaomi’s Mijia crowd funding platform.
Source: http://en.miui.com/thread-388416-1-1.html
Direct link: http://home.mi.com/shop/detail?gid=303
151031-0151033-1151035-2151037-3151039-4
Offline mick
    • MickBenjamins.com
Re: Xiaomi/Yuemi Mechanical Keyboard 87 keys
« Reply #1 on: Sun, 23 October 2016, 18:32:43 »
Not much known about it now and the font is beyond horrible but it's nice to see that more manufacturers see potential in mechanical keyboard.
But the price makes it very interesting, specially because of the alu case :)
Offline Coreda
« Reply #2 on: Sun, 23 October 2016, 18:36:24 »
Liking the design quite a bit. Flip stand, aluminum case, backlight (hoping it's toggleable). Not a fan of the keycap typeface but assuming all the keys/stems are standard that's not much of an issue.
Offline YoshiCaps
  • yes, oh god no.
« Reply #3 on: Sun, 23 October 2016, 18:50:06 »
XIOMAI MADE A KEYBOARD?  :-X
hi.
« Reply #4 on: Sun, 23 October 2016, 19:04:01 »
This keyboard will be impossible to beat at that price level..
Xiaomi is extensively vertically integrated..
They can produce something of quality at $50 that NO ONE ELSE POSSIBLY can..
They're also maximum corrupt, bribing government officials is an all day thing
Offline YoshiCaps
  • yes, oh god no.
« Reply #5 on: Sun, 23 October 2016, 19:06:32 »
Hi, Fellow MIUIers,
(Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link) (Attachment Link)
Surely gonna buy.
hi.
« Reply #6 on: Sun, 23 October 2016, 19:08:13 »
Is it real aluminum or a Chinesium alloy?
Offline YoshiCaps
  • yes, oh god no.
« Reply #7 on: Sun, 23 October 2016, 19:10:08 »
I tust xiamoi, their redmi phones are of some of the highest quality I have ever seen. They are not very popular in the US however
hi.
Offline Coreda
« Reply #8 on: Sun, 23 October 2016, 19:18:49 »
Surely gonna buy.
yoshi likes something else as well
and it's not just this kb •₃•)
Offline YoshiCaps
  • yes, oh god no.
« Reply #9 on: Sun, 23 October 2016, 19:19:48 »
hi.
Offline pr0ximity
« Reply #10 on: Sun, 23 October 2016, 21:08:54 »
What's an TTC
« Reply #11 on: Mon, 24 October 2016, 00:35:19 »
If anything,  aluminum IS chinesium alloy..
hahahahahaha
Contrary to popular belief, Aluminum is a low-tier material..  The only reason they're building keyboards out of aluminum instead of other metals, is because of how much softer and weak it is..   greatly reducing machining time..
If you tried to cut something out of steel, for example,  everything would take between 3-5x as long.. and that's only WEAK steel..
Offline menuhin
« Reply #12 on: Mon, 24 October 2016, 05:21:59 »
Xiaomi got distracted from their Smartphone business?!
... Flip stand, aluminum case ...
I second these are very nice features combination I've seen on the market.
But most importantly, I want ErgoClear or Gateron Black on this design.
I don't care about anything red, and not the unknown TTS if it's producing just red.
With the weight of red, I'll just bottom out; but with black, I'm hovering between keystrokes. :cool:
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
« Reply #13 on: Mon, 24 October 2016, 08:52:03 »
hahahahahaha
It's still not uncommon for Chinese aluminum products to be made of pot metal that's mostly aluminum or some aluminum/cheap metal mix that you can't anodise.  At the price point, I would assume it's cast aluminum, not milled, which is often harder to anodise.
Offline benderkey
« Reply #14 on: Mon, 24 October 2016, 11:01:30 »
Never heard of Xiaomi.  In any case it would be like saying to buy an Apple keyboard because they make a lot of phones.  ^-^
Offline mick
    • MickBenjamins.com
« Reply #15 on: Mon, 24 October 2016, 12:22:07 »
They make a broad range of products, from laptops and phones to drones and cameras: https://en.wikipedia.org/wiki/Xiaomi
« Reply #16 on: Mon, 24 October 2016, 12:23:31 »
hahahahahaha
Milled aluminum is not inherently better..
And generally, all of the alu keyboards are first Cast to the approximate pocket shape, Then milled..
Those pockets are almost 2 centimeters,  having to extract 2cm of aluminum from a solid plate is just Silly.. you can do it,  but why..
Pocketing that deeply is also problematic because the heat might cause warping.  aluminum is really like putty , especially when hot,
Offline mick
    • MickBenjamins.com
« Reply #17 on: Sat, 05 November 2016, 13:17:28 »
Offline Erzegovaz
« Reply #18 on: Sat, 05 November 2016, 13:27:23 »
I`ll try to contact xiaomi for a review :D Or I hope someone can have one soon...so curious  :cool:
Offline Giorgio
« Reply #19 on: Sat, 05 November 2016, 13:30:48 »
LOL
" TTC Red Switches can withstand up to 50.000 hits"  :eek:  :))
Maybe they meant 50.000.000? That's what cherry switches are rated for.
Offline Tangtawan
« Reply #20 on: Sat, 05 November 2016, 14:27:19 »
LOL
MTBF of 50,000 ? ... maybe they keyboard will fail within a week.
My boards : Model F AT (6450200), Industrial M (1394950), Model M SSK (1391472), Model M13 (13H6705), Model M (1390131), Focus FK-2001 (ALPS SKCM Blue), HHKB Pro 2, Realforce 87U 55g, KBP V80 Matias Click, TADA68 (Gateron Reds), Filco Majestouch 2 TKL (67g Ergo Clears), Cherry G80-11800 (Ergo Clears), KBT One 108 (MX White), Ducky One TKL RGB (MX Black), Filco Majestouch Tenkeypad (MX Brown), Leopold FC210TP (MX Red)
Offline Erzegovaz
« Reply #21 on: Sun, 06 November 2016, 05:01:11 »
Xiaomi answer me that they dont have more news at the moment, and no sample/reviewer or something for now. So we need to wait a little bit ;)
They will be in touch, when they`ll have some news.  :thumb:
Offline mick
    • MickBenjamins.com
« Reply #22 on: Tue, 08 November 2016, 17:10:25 »
LOL
Yes its 50.000.000. They write the correct number a bit further in the post :)
Offline hurst
« Reply #23 on: Wed, 09 November 2016, 16:56:03 »
Offline Data
« Reply #24 on: Thu, 10 November 2016, 07:26:08 »
Just curious but, what is it about the font that makes it "beyond horrible"?
Looks pretty standard (for shine-thru) to me.
Offline derb2k2
  • Something of a Topre ****..
« Reply #25 on: Fri, 11 November 2016, 04:31:36 »
interesting! I know that Xiaomi puts out some quality headphones on a budget, like their Pistons 2.0 and 3.0. I'll keep my eye out for this keyboard since I'm looking for something new.
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline mll8394
  • I regret joining this hobby :/
« Reply #26 on: Sun, 13 November 2016, 06:24:38 »
Kinda looks like the Whitefox lol :0 :eek:
"Converting Oxygen into CO2 24/7"
Offline Lepidus
« Reply #27 on: Sat, 26 November 2016, 21:06:24 »
Someone posted some videos of the actual keyboard on youtube. It looks really nice IMO, but I still have mixed feelings about the glossy top.
Btw, its already avalible for purchase on gearbest and bangood.
« Last Edit: Sat, 26 November 2016, 21:14:01 by Lepidus »
