Author Topic: Watch out,, Ladies..  (Read 4513 times)
« on: Tue, 25 October 2016, 20:46:30 »
Tp4 just spent 12 hours handling the Home Depot Concrete Floor Grinder..
Ended up doing all 1000 sqr feet of the basement concrete.
Easily +15 ...Hand Strength
Rdy to give xcellent massages..
Re: Watch out,, Ladies..
« Reply #1 on: Tue, 25 October 2016, 21:09:57 »
You should give everyone massages
« Reply #2 on: Tue, 25 October 2016, 21:27:34 »
Too many kids on the Geekhack..   Illegal...
« Reply #3 on: Tue, 25 October 2016, 21:30:20 »
18+
Offline alienman82
« Reply #4 on: Tue, 25 October 2016, 21:30:44 »
removed.
« Last Edit: Thu, 01 March 2018, 13:51:26 by alienman82 »
« Reply #5 on: Tue, 25 October 2016, 22:02:56 »
did you rent that one?
yea..  it were $135 total with the grinding wheel + the grinder itself.
Pretty steep learning curve,  not for feint-of-heart..  but it works really fast and well once you figure out how to control it..
Offline noobas4urus
  • Mod Munky of another realm
    • The Mod Zoo
« Reply #6 on: Tue, 25 October 2016, 22:16:13 »
It's all about finding that happy little spot that lets you take it where you want and not violently crash into walls.  Then it's kinda fun.
"You miss 100% of the raffles you don't enter."
-Wayne Gretzky
« Reply #7 on: Tue, 25 October 2016, 22:18:39 »
yea..  this thing was throwing me in the beginning....   using this type of machine to grind is a bit different from polishing..
grinding really offsets the machine to one side, whereas polishing , it's still relatively pulling in the center..
And with polishing, you can just let it run in place,   but if you do that with the grinder, it's gonna cut a giant donut into the floor..
That said,, tp4 made 2 feint donuts in the floor today.. hahahahaha.. prolly get it out with the chisel.
my hips are pretty sore from all the leaning..
Offline Spopepro
« Reply #8 on: Tue, 25 October 2016, 23:49:16 »
TP has 1000sqft basement. Spopepro lives in 750sqft house. I'm not sure how I feel about this.
« Reply #9 on: Wed, 26 October 2016, 07:41:27 »
Spopepro is young..
Tp4 is ~ bout to die.
Offline ideus
  • Björkö.
« Reply #10 on: Wed, 26 October 2016, 07:46:45 »
Just move to his basement, now it has the flooring grinded.  :))
« Reply #11 on: Wed, 26 October 2016, 07:56:20 »
Going to haz epoxy...
Trying to decide if I need primer..
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #12 on: Wed, 26 October 2016, 08:01:21 »
You have a thousand feet and they're SQUARE?! You need to see a doctor mate :p .
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #13 on: Wed, 26 October 2016, 08:23:50 »
What respirator did you wear? Inquiring minds need to know
« Reply #14 on: Wed, 26 October 2016, 09:11:59 »
I used the Harbor freight one..
Worked great, and I was in a CLOUD of basement concrete / glue dust..
Didn't smell a thing..
From what I can tell though, the harbor freight one is meant to be disposable, even though you CAN buy replacement (PRE-filters) for it..  I don't think they sell the main filter..
Not totally sure,   but I don't do this stuff ~ever.. so... I wasn't going to invest in a super-duper respirator..
It's still good after the 12 hours in the dust cloud though.. so..  def worth the $16
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #15 on: Wed, 26 October 2016, 09:17:52 »
I don't think I'd reuse anything after grinding concrete in an enclosed space for 12+ hours
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #16 on: Wed, 26 October 2016, 09:30:01 »
How much did this workout improve your WPM Tp4
Offline noobas4urus
    • The Mod Zoo
« Reply #17 on: Wed, 26 October 2016, 11:05:06 »
Asking the hard hitting questions the peeps want to know about
-Wayne Gretzky
Offline cribbit
« Reply #18 on: Wed, 26 October 2016, 12:17:47 »
The 1000 sq ft basement is the more impressive part. That's more than my entire apartment. For a basement.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
« Reply #19 on: Wed, 26 October 2016, 13:13:20 »
hahahahaha
well I had 3 boxfans aimed out the 3x vent windows, and one box fan on the 4th window for intake.
Dust cleared out quickly , but it was very cloudy till the very end, because this thing grinds 1.5-2 mm into the concrete.
« Reply #20 on: Wed, 26 October 2016, 13:14:30 »
I have not tested,  but generally Power isn't an issue with typing.. unless we're talking type-writer..
But I don't have any typewriters to test on..
