Author Topic: //Ashamed  (Read 2201 times)
//Ashamed
« on: Thu, 10 November 2016, 14:04:36 »
As ya'llz knowes, Tp4 had been attempting some bunker improvement.
Did some dry wall this morning..  screwed it in, mud, tape, everything..
And just now,'ve just come to the realization that 've left the Power drill in the wall.
You'd think that being a Sifo-n-all,  Tp4 would have inherited some wall-building heritage// ability..
Re: //Ashamed
« Reply #1 on: Thu, 10 November 2016, 14:22:13 »
So take this time to create an in wall shelf where the hole needs to be to get the drill out. :thumb:
Re: //Ashamed
« Reply #2 on: Thu, 10 November 2016, 14:23:54 »
I have once destroyed a house for fun with a sledgehammer. Well just the walls in the basement to rip out copper pipe and wire.
Found tools in wall, obviously it happens all the time TP. Feel proud, like a pro contractor!
Offline Blackehart
Re: //Ashamed
« Reply #3 on: Thu, 10 November 2016, 14:52:19 »
hahahahahahAHAHAHAHAHAHAHA!
You da man, Tp!
 ;D
Re: //Ashamed
« Reply #4 on: Thu, 10 November 2016, 16:33:02 »
um...
Those are murder weapons you found...  Prolly should call it in..
Offline fanpeople
Re: //Ashamed
« Reply #5 on: Thu, 10 November 2016, 17:19:30 »
My dads a tradie and i have done a **** ton of labouring for him. About 10% of his toolbox are tools hes found in the roof of buildings. He is also anal as **** about to placing tools in roof cavities when not using them.
Obvioulsy it is a very common occurance. I wouldn't feel bad tp, the person that rips your house down has already got a new drill. They just dont know it yet
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: //Ashamed
« Reply #6 on: Thu, 10 November 2016, 17:21:41 »
...How?
Didn't you need that to screw the drywall in place?
Re: //Ashamed
« Reply #7 on: Thu, 10 November 2016, 17:27:50 »
...How?
no..
power drill is for fixing the distance between the metal wall stud
I have a drywall screw driver for the drywall screws.  It's much more conveniant than a power drill.
---- It basically is a power drill, but it's got this height setting coller and a disengage lock release, so the drywall screw will never be overtightened..
