Author Topic: MicroSD cards are Ripoffs  (Read 4051 times)
« on: Sat, 10 December 2016, 16:20:55 »
We got  4GB  to  5GB  per dollar on SSDs..
And yet a microsd card is 2-3GB/ 1$
The SSD comes with a Freaking CPU/ Ram and giant pcb relative to Microsd..
These samsung bastards making a killing on Microsd..
Offline Leslieann
Re: MicroSD cards are Ripoffs
« Reply #1 on: Sat, 10 December 2016, 17:47:57 »
They're also slower!
You're paying for the smaller size.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
« Reply #2 on: Sat, 10 December 2016, 23:22:09 »
Size is not what we're paying extra for....
The package on the ssds are just as small, only they're soldered onto the board..
This is clear price fixing..
Offline Leslieann
« Reply #3 on: Sun, 11 December 2016, 03:17:59 »
I've never seen a 256gb ssd with a single chip on it.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #4 on: Sun, 11 December 2016, 07:56:35 »
I recall that's because they need to make um thicker for more parallelism and increased write durability..
The node is just as small.
« Reply #5 on: Sun, 11 December 2016, 08:42:19 »
I think that micro SD cards are amazing and beautiful.
- D Trump 2026-10-24
« Reply #7 on: Mon, 12 December 2016, 18:28:45 »
About to buy a 128gb sd card for $60....
But I haz a very distraught and ANGRY feeling inside...
What do. geekhack.. this feeling is almost as awful as Razer keyboard...
Offline fanpeople
« Reply #8 on: Mon, 12 December 2016, 18:38:24 »
Buy it, having money is for the rich
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #9 on: Mon, 12 December 2016, 18:56:16 »
A 128gb SSD from Samsung is about $60.
I don't actually understand what you are complaining about.
Offline vivalarevolución
« Reply #10 on: Mon, 12 December 2016, 20:12:14 »
It's tp, he needs his daily musing or complaint.
Offline Leslieann
« Reply #11 on: Mon, 12 December 2016, 22:23:50 »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #12 on: Tue, 13 December 2016, 01:52:25 »
« Reply #13 on: Fri, 16 December 2016, 11:05:59 »
What really grinds my gearz..  is that I had to buy a $20 Sd card reader JUST TO TEST and make sure the SD-Card I get isn't a counterfeit..
Offline Leslieann
« Reply #14 on: Fri, 16 December 2016, 15:15:57 »
So your deal on a card wasn't quite a deal after all.
An easier way to test is to just copy as much data as it should hold, or close, it will have massive errors when you do. If for some reason it does take most of the data, try accessing one of the larger files and see if it still works. I believe Linux can also show you the true size if you change the MFT, Windows makes it easier to fake it.
Actually, considering you are worried about it being fake, even though it passed for size, it can still be a counterfeit (even major stores have been ripped off this way) and/or a degraded/defective card that didn't pass a quality check. So while you got a deal on a big card, it may not last long.
« Last Edit: Fri, 16 December 2016, 15:17:57 by Leslieann »
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
« Reply #15 on: Fri, 16 December 2016, 15:25:59 »
Offline dantan
« Reply #16 on: Fri, 16 December 2016, 16:50:30 »
A lot are fake right?
« Reply #17 on: Fri, 16 December 2016, 20:04:58 »
Yup..
they're everywhere ..
gotta test and bench.. and check for corrupt blocks.
Offline alienman82
« Reply #18 on: Fri, 16 December 2016, 20:41:53 »
removed.
« Last Edit: Thu, 01 March 2018, 13:27:57 by alienman82 »
« Reply #19 on: Fri, 16 December 2016, 21:05:07 »
are SD the same price mostly as micro SD?  seems to be a rip there too tp4..
They're all ripoffs...
« Reply #20 on: Wed, 21 December 2016, 21:09:36 »
OMG sd cards only have ~9TB of writes ??
/// What a ripoff..
